Latest post Sat, Jul 2 2022 7:27 AM by camoscato. 36 replies.
Page 3 of 3 (37 items) < Previous 1 2 3
  • Thu, Apr 25 2013 2:01 PM In reply to
    Re: Timewarp effect does not apply
    Oops, didnt see that. Thank you! :)
  • Thu, Apr 25 2013 2:21 PM In reply to
    You're quite welcome, Simon. Happy editing!Yes
  • Fri, Jul 1 2022 3:57 PM In reply to
    • ergalthema
    • Joined on Sat, Jan 2 2021
    • Posts 5
    • Points 50
    I'm in the same situation as OP, but I don't see any option to do this:
    bwilhelm:
    However, you can promote motion adapters to full timewarp effects in the Motion Effect Editor
    and gain access to all of the parameters (ie: speed keyframes, etc.) of the timewarp that way.
    Try that and please report back whether it works or not.
    In the Motion Effect Editor, I see no option to promote. All settings are greyed-out.
  • Fri, Jul 1 2022 5:02 PM In reply to
    ergalthema:
    bwilhelm:
    Can you post a screenshot? It sounds like you may not be parked on the clip, or maybe the track is not enabled, but it's hard to say without seeing it.
    Media Composer 2022.7 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Fri, Jul 1 2022 5:23 PM In reply to
    • ergalthema
    • Posts 5
    • Points 50
    Clip is a MOV with alpha... in a different frame rate and resolution from the project. Track is enabled, and I'm parked on the clip.  I'll send a screenshot if I can't figure it out soon.
  • Fri, Jul 1 2022 5:29 PM In reply to
    • ergalthema
    • Posts 5
    • Points 50
    I was able to apply Timewarp to the separate tracks after stepping in. Kind of clunky, but it worked. (I would have just edited my reply, but this forum makes all my posts disappear until they are approved, I guess.)
  • Sat, Jul 2 2022 7:27 AM In reply to
    I'm glad you were able to figure it out.
    ergalthema:
    Yes, because you are new to the forum, your posts have to be approved. I set your status to unmoderated, so that should'nt happen any longer.
