Latest post Sun, Jun 20 2010 11:58 PM by Rastus Washington. 17 replies.
  • Sun, Oct 18 2009 4:37 PM
    • taylormade
    • Joined on Mon, Jul 20 2009
    • Staunton, Illinois
    • Posts 129
    • Points 1,945
    Canon Vixia HV30
    While I'm waiting for my new panasonic P2 camera to arrive I'd like to capture some footage off my little Vixia HV30 (miniDV, tape) camera and fool around with HD editing in MC4.0.2.  Has anybody had any experience with this?  I shot some 1080 30i and hooked the camera to my computer via firewire (I have no Mojo).  With it listed as a generic device I could control the camera but couldn't get a picture.  When I tried to digitize it flashed red for a few seconds and then I got the "video has unexpectedly stopped coming into the system" message.
    I'm new to HD, so I need a little help with this.  What should my project settings be?  I shot 1080 30i in NTSC.  Im sure this is a setting I'm missing or something idiotically simple that I have, as usual, overlooked.
    Thanks.
    Intel i7 920 V1AX Thermaltake cooler Asus P6T 24GBCorsair 1600 PNY Nvidia Quadro FX 3800 Coolermaster HAF 932 1TB Seagate Barracuda (Boot Drive)... [view my complete system specs]
  • Sun, Oct 18 2009 7:05 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,798
    • Points 62,840
    Re: Canon Vixia HV30
    Select deck type as one of the listed prosumer Canon cameras (cant' remember which one... hang on... Canon XHG1 - I use this setting for my HV20).
    Also - I don't think MC supports the 24f mode of these cameras...
    The first time I used the HV20, I noticed that the Video and Audio 1,2 tracks were not automatically selected in the capture dialog so when I tried playing back the tape, the video did not show on the record monitor. Rookie mistake but I wasn't really paying attention.
    Let us know how it goes...
    MC 2020.12 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.3 | Windows 10 Pro x64 (20H2) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Oct 18 2009 8:04 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,320
    • Points 17,200
    If I'm not mistaken, you also have to create a new project type with HDV selected so the system knows to expect that signal at the firewire port. I'm not at my Avid right now, but I've played with it a few times in the past, and it always seemed to work once you get your settings right.
    Check under the 'format' tab and see if there's an HDV raster setting for your 1080i project? I think that'll do it.
    Chris
    MacPro 3.33Ghz 12 Core (Westmere, MacPro 5,1), 48Gb RAM, nVidia GeForce GTX 680, Intensity Pro (Desktop Video 10.4.3), OS X 10.13.6, MC 2018.12 [view my complete system specs]
  • Sun, Oct 18 2009 9:50 PM In reply to
    • taylormade
    • Posts 129
    • Points 1,945
    The only formats I can find that support HDV are in the 720p list.  None of the 1080 formats list HDV as a supported format.
    I tried the XHG1 setting and it didn't work.  No input, no control of camera.
  • Sun, Oct 18 2009 10:18 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,320
    • Points 17,200
    At my Avid now.
    Create a new project set to 1080i/59.94, then in the 'raster type' pulldown, select HDV. See if that works.
    Chris
  • Sun, Oct 18 2009 10:58 PM In reply to
    On MC4 and possibly MC3.5 Raster type has changed to Raster resolution. Choose 1440 for HDV
  • Mon, Oct 19 2009 2:35 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,798
    • Points 62,840
    taylormade:
    That's odd because I was under the impression that the HV30 is more or less the same as the HV20. Do you have the HV30 setup for HDV output?
    Steve
  • Mon, Oct 19 2009 4:56 AM In reply to
    • taylormade
    • Posts 129
    • Points 1,945
     I got it working thanks to you guys.
    For those who want to try capturing from a Vixia HV30 into Avid MC4.0.2 via firewire (no Mojo)
    Open a new project in 1080i/59.54
    Under Deck configuration, choose XHG1 under Canon
    In the capture window under Res. choose HDV 1080i MFX not DVCpro HD MFX (this made all the difference)
    At this point I could control the camera and capture footage with no problem.
    The only problem I noticed is that when viewing the clips in either the source or record monitor there was a banding effect when the camera panned or tilted rapidly. It appears as a kind of stutter or incomplete scan of the frames.  When I click through the timeline a frame at a time all the single frames look fine, so it seems it is some sort of Avid playback issue.  I'll check on my Sony monitor from the camera tomorrow to make sure it's not on the tape, but on the camera LCD during playback I can't see it.
    Thanks for all the help with this!
  • Wed, Oct 28 2009 11:39 PM In reply to
    Similar problems for me with the Vixia HV30, although unlike the original poster, I can't even get it to capture evena  few frames.  As soon as I check the video track in the capture tool, I get an error (no video input present, I think, not in front of it right now) and I get the same error upon selection of the audio tracks.  Running MC 3.5 academic, yet to upgrade to 4.x.
    Tried the above solution but still no luck.  Will try to send from PC to camera via FW to test that idea.  Wondering if anyone else has had similar experiences?  System capturing plain old DV just fine from a JVC BR-DV3000 deck, using all the same connectors and FW ports.  Hmmmm.....
    Gateway LX6810-01, Intel Core 2 quad CPU Q8200 @ 2.33 GHz, 8GB memory, Windows 7 Professional 64 bit, 750GB & 1TB media, NVIDIA GeForce GT 120 [view my complete system specs]
    Douglas Flanagan
    Instructor of Radio-Television Broadcasting
    Herkimer County Community College
    Herkimer, NY  13350
    flanagadp@herkimer.edu
    www.herkimer.edu
  • Wed, Oct 28 2009 11:48 PM In reply to
    • taylormade
    • Posts 129
    • Points 1,945
    I never had MC3.5 - upgraded from XpressPro, so I can't say if my solution above will work for you (I guess not if you already tried it!).  Once I had the settings correct I had no trouble capturing from the Vixia.  Interesting that you can capture from a JVC BR DV3000, I sure can't, no matter what I try.  Are you using the Generic setting?
  • Thu, Nov 12 2009 8:56 PM In reply to
    Just installed the demo for 4.0.2. I made the correct adjustments, as mentioned above, to capture from my HV30. When I try to batch capture a quick 1 minute clip that I logged I get an error stating that Avid had communication with the deck but could not capture footage (something to that effect). When I hit the capture button w/out in or out marks I can cature footage fine. The footage is standard HDV. No 24pf. Anyone else had this problem or know what might be causing it?
    Also, I have my monitors setup where my 16x9 monitor is on the left and an older 4x3 monitor is on the right. Is there a way to move the timeline and source record monitors to the left and have my bins etc. on the right?
    Rastus
  • Thu, Nov 12 2009 9:17 PM In reply to
    I have many times problems capturing with my HV30 and Avid.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Fri, Nov 13 2009 12:30 AM In reply to
    Nope, no generic setting, used the setting for the deck.  We've had good luck in our labs with these decks and Xpress Pro.  Wokrs fine in SD on my MC too.  ?  I've had good luck with the MOJO in Xpress Pro and now it works OK with Mc too.  Wish I knew why!
    Douglas Flanagan
    Herkimer, NY  13350
    www.herkimer.edu
  • Sat, Jun 19 2010 5:40 AM In reply to
    • Dynamic7
    • Joined on Sat, Oct 10 2009
    • Posts 205
    • Points 2,950
    I have had this problem for quite a while also ,has anyone really figured out what the problem is ?
  • Sat, Jun 19 2010 1:11 PM In reply to
    From the time I bought Canon T2i, I haven't touched my HV30.
    I keep it as a deck only. But if you want to minimize capture problems stripe the tapes before shooting.
    This would help a lot.
    Desktop PC
