Latest post Wed, Jun 30 2021 5:15 AM by fdooman. 21 replies.
Page 1 of 2 (22 items) 1 2 Next >
  • Wed, May 12 2021 11:07 PM
    • fdooman
    • LOS ANGELES
    • Posts 535
    • Points 6,535
    Avid 2021.5 installer chocks ?????
    Windows 10 pro with the latest update. Launching MC 2021.5 installer, After first pop up box asking Avid wants to modify clicking yes nothing happens. what is going on Avid???
    Symphony 6.0 on PC MC 6 on MAC Pro 3.2 GHZ 2008 model, 8 Gig of ram, Nvidia 8800 GT video card. 500 Gig system drive, 320 gig extra drive, Cineraid 2TB... [view my complete system specs]
  • Thu, May 13 2021 9:57 AM In reply to
    Re: Avid 2021.5 installer chocks ?????
    Did you uninstall any previous version of MC before attempting to install 2021.5?  Did you unzip the installer from the route level of your C:\ drive?  FWIW I have had no issues installing and using 2021.5 on the latest version of W10 pro after uninstalling my existing MC version and unzipping the 2021.5 installer on the C: drive.
  • Thu, May 13 2021 10:10 AM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,724
    • Points 30,185
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hello fdooman,
      The downloaded file is zip (Windows) you need to install your choice of unzipping utility/program to extract the file before installing, to avoid corrupted installation
    RalphC
  • Thu, May 13 2021 1:01 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,414
    • Points 54,870
    Logged on Windows as Administrator?
    Using MC 21.5. Win 20H2  Avid FX6.4, Vegas Pro 18/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Thu, May 13 2021 1:45 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,810
    • Points 63,060
    TVJohn:
    Or as a member of the administrators group. And then right-click and select 'Run as administrator' on the Install Media Composer.exe
    I have not had any issues with Avid installers, either. After running Install Media Composer.exe and accepting the dialog to allow the program to make changes, you should see a dialog indicating that it wil install several prerequisites. After the prerequisites are installed the actual Media Composer installer is run and a new installation wizard dialog appears.
    From the sounds of it (to the OP) you aren't even seeing the prerequisites dialog.
    It's worth checking that you unzip the installer into a folder under the root of one of your drives such as C:\Temp (or into the root if possible) to keep the file paths as short as possible. In the past, this has been an issue, I recall.
    I also always uninstall Avid Link, Avid Cloud Client Services and Avid Media Composer before I install a new build - may not be necessary but old habits die hard, lol.
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, May 13 2021 2:16 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 359
    • Points 4,280
    BarkinMadd:
    I used to all that un-installs - but recently been using AVID LINK for the installs and the upgrades have been fine.  I was wondering if I should do a manual un-install but opted to the AVID LINK.  Will I run into problems?   Should I do a complete un-install and then re-install the full version of  2021.5?
    thank you
    Symphony 2021.5 - Win 10 pro (20H2),Gigabyte X299X with i9 10920X CPU, Quadro P2000,driver 461.72; 64gig memory, 1TB NV system drive, WD 4TB, BM Min Monitor... [view my complete system specs]
  • Thu, May 13 2021 5:29 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,810
    • Points 63,060
    LDV20:
    BarkinMadd:
    thank you
    I think you are probably OK using Avid Link. If you find you have an issue that other's aren't having at some point, you can always uninstall / reinstall and see if the issue goes away. If you aren't having any problems (that others aren't reporting) then there's no reason to be concerned.
    Steve
  • Thu, May 13 2021 5:48 PM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 535
    • Points 6,535
    Thank you so much everyone for taking time to help. Sorry for the late reply as I had deadline, working very late.
    I did uninstall MC only not the rest, I may have to do that.
    I did unzip the file first using Win zip. on C drive and other drives with no results.
    I keep getting 2 update one for media composer and one for Avid link,even Avid link won't take the update in Avid link App.
    I will try later today other otions and will post the results.
    Thanks again
  • Fri, May 14 2021 11:34 AM In reply to
    • LDV20
    • Posts 359
    • Points 4,280
    BarkinMadd:
    OK - I think so too.
    Thank you
  • Fri, May 14 2021 2:12 PM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 535
    • Points 6,535
    I did tried ALL of the above advises No luck and I'm about to give up and go back to version 20. Ralph what would be the next step??? Marianna????
  • Fri, May 14 2021 2:21 PM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 535
    • Points 6,535
    I can't even install Avid link 21. I tried version prior, they all worked fine. As I said Avid 2021.5 CHOCKS. And I was not wrong about it.
  • Sat, May 15 2021 7:15 PM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 535
    • Points 6,535
    Where is MARIANNA???? Where is AVID???? to clean this mess. Don't tell me is my system. I have tried many time installing-uninstalling 2020.12.2 with no problem, but when it comes to 2021.5 the Hell breaks loose. I hope I don't have to take this issue all over the social media.
  • Sun, May 16 2021 1:17 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,414
    • Points 54,870
    What does Windows Task Manager show?
  • Sun, May 16 2021 1:31 AM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 535
    • Points 6,535
  • Sun, May 16 2021 1:32 AM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 535
    • Points 6,535
    Thanks TV John, I hopethis helps
