Latest post Wed, Feb 20 2019 4:14 PM by Bruno M. 3 replies.
  • Mon, Feb 18 2019 5:13 PM
    Cannot See Bottom Of Settings Menu; See Screenshot
    I can't see what it says below where it says
    ("Delay 0.5 Seconds Before Showing")
    in the menu for the interface settings.  I've tried changing a lot o things in Windows and in MC 2018.12.1
    My system is below this screen shot
    I also get this message upon Launching MC (but the screen height is set to 2160)
    Phillips 42" monitor 4K native set to 4K and split to dual monitors
    Windows 10 64-bit Home
    i9-9980XE
    Asus x299 Prime Deluxe II
    DRAM4 128 GB
    Nvidia Titan RTX
    SSD 2TB Samsung
    Media Composer 2018.12.1
    i9-9980XE; Asus Prime x299 Deluxe II; 128GB DRAM4; Nvidia Titan RTX; SSD 2TB [view my complete system specs]
  • Mon, Feb 18 2019 5:30 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 177
    • Points 2,275
    Re: Cannot See Bottom Of Settings Menu; See Screenshot
    What is the percentage setting for you Scale and Layout under Windows 10 Display Settings? If you are a dual monitor setup is the percentage and resolution the same for both monitors?
    HP zBook 17 G3, z220, HP z240, HP z420, HP z440, HP z840, HP Z4 G4, Dell Precision 3430, Dell Precision 7810, Apple iMac i5 27-Inch (5K, Late 2015). 16GB... [view my complete system specs]
  • Tue, Feb 19 2019 2:16 AM In reply to
    yeah, that fixed it.  both were the same at 300% but it works perfect at 225%
  • Wed, Feb 20 2019 4:14 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 851
    • Points 10,900
    225% seems to be the magic number.
    There was also another method used which achieved similar results involving Compatibility Mode.
    What you do is...
    1) Right-click on MC shortcut and choose 'Properties'
    2) Select the 'Compatibility' tab.
    3) Where it says 'Override high DPI Scaling Behaviour', check the box.
    4) Set the 'Scaling Performed by' drop-down from 'Application' to 'System'
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Decklink 4K, Symphony 2020, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color, Avid Transport... [view my complete system specs]
