Latest post Tue, Nov 25 2014 2:30 PM by smrpix. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Aug 18 2011 1:32 PM
    • Michael Smith
    • Joined on Sat, Aug 6 2011
    • United Kingdom
    • Posts 43
    • Points 570
    Can't Send to Sorensen Squeeze
    I'm trying to send a time line to Sorensen Squeeze, I know a few days ago I posted about not being able to find it, I know have a copy of the Prodcution Suite.
    When I'e pointed it to the right location for Squeeze, it come up with the following message below.
    An error was encountered while performing Send To export, using Export Setting 1(Sorensen Squeeze) See the console for more information.
    If I click continue, it then comes up with the message:
    Unable to run /applications/Squeeze6/Squeeze.app
    I'm running MC 5.5.2 and version 6.5.0.42 of Squeeze.
    iMac 21.5 Intel Core i3 3.06 GHz, 4 GB 1333 Mhz DDR3, MC 6.0 [view my complete system specs]
  • Thu, Aug 18 2011 2:21 PM In reply to
    Re: Can't Send to Sorensen Squeeze
    There were issues with using "Send to" in 5.5.2.  I believe that has been fixed in 5.5.3.
    If you can upgrade, I'd recommend it...a lot of other bug fixes in there.
    If not, export a QT Reference and just open that in Squeeze itself.
  • Thu, Aug 18 2011 5:31 PM In reply to
    • Michael Smith
    • United Kingdom
    • Posts 43
    • Points 570
    Thanks, i'll download the upgrade.
  • Mon, Aug 22 2011 1:05 AM In reply to
    • gregNZ
    • Joined on Fri, Apr 23 2010
    • Posts 38
    • Points 530
    Hi there,
    I had exactly the same issue. I've just upgraded to MC 5.5.3 and the error is still coming up. Does anyone know what the problem could be? Thanks
    Specs: MC 5.5.3 iMac 3.1. GHz i5, 16GB DDr3
  • Mon, Aug 22 2011 7:59 AM In reply to
    • Michael Smith
    • United Kingdom
    • Posts 43
    • Points 570
    Not sure, I've just updated my version of MC to 5.5.3, and it works fine now.
  • Mon, Aug 22 2011 3:52 PM In reply to
    gregNZ:
    What OS are you on?
  • Mon, Aug 22 2011 4:26 PM In reply to
    • Michael Smith
    • United Kingdom
    • Posts 43
    • Points 570
    I'm having the same problem again, it launched fine last night, hten when I tried it again earlier today, I had the old problem, I"m using 10.6.8.
  • Mon, Aug 22 2011 7:00 PM In reply to
    Can you do a screen grab of the error?
    What version of Squeeze?
  • Mon, Aug 22 2011 10:02 PM In reply to
    • Michael Smith
    • United Kingdom
    • Posts 43
    • Points 570
    Below is the screen shot of the error requested.
    Some additional info I've just discovered, I get t his message, when I send a time that contain a linked AMA file, but when I send a timeline that a file that been imported, through the import menu, it's works fine.
    I only realised while getting ready to take this screen grab that I was using an AMA linked file, and when I did it with a just imported file, it was fine.
    Squeeze Error
  • Tue, Nov 25 2014 1:21 PM In reply to
    • Soleus
    • Joined on Wed, Jul 23 2008
    • Posts 3
    • Points 45
    I just stumbled on same problem. I fixed it by changing Sequence/File name. Apparently there is a problem with some character combination or the name is to long. I do not have time to test it right now.
    MC 3.0 Adrenaline, DNxcel Board HPXW8600 Dual Intel Xeon Quad-Core 3.00 GHz, 1333 MHz FSB RAM 4GB DDR2-667 Nvidia Quadro FX5600 [view my complete system specs]
  • Tue, Nov 25 2014 2:30 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,454
    • Points 17,955
    Soleus:
    If he's really been waiting three years for an answer, a couple more days won't make a difference. Wink
