Latest post Thu, Jul 21 2011 11:41 AM by MAC HOLLAND. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Jul 20 2011 7:14 PM
    How to Import 29.97 footage in 59.94 project
    Hello Everyone!
    I've never tried to do this but I'm having some troubles. I have some 29.97 frame rate footage I'm trying to import into a 59.94 project and I'm having no luck being able to import the media. I thought someone may be able to offer some know how and assistance in this area.
    Thanks in advance!
    - Jared
    MC Version 2020.4 | Windows 10 64 bit | 128 GB DDR4 Ram | ASUS X299-A | Processor: Intel(R) Core(TM) i9-7900X CPU @ 3.30GHz, 3301 Mhz, 10 Core(s), 20 Logical... [view my complete system specs]
    Filed under: , , ,
  • Wed, Jul 20 2011 7:18 PM In reply to
    Re: How to Import 29.97 footage in 59.94 project
    More details please.
    Are these file based clips? If so, what format? Codec? Camera shot on?
    Are these tape based clips? if so, what format? Deck? Camera shot on?
    What version of MC are you running?
    Follow me at www.twitter.com/redarrowryan [view my complete system specs]
  • Wed, Jul 20 2011 7:43 PM In reply to
    Thanks for the offered help!
    The clips are tape based and filmed with a Canon XH A1. I trimmed all the clips in premiere and expoted it as one clip encoding it as a QuickTime and using Avid DNX HD Codec. I tried originally importing the clips into Avid but had no luck so I then rough cut everything down so it was only a few minutes long and just one clip. I'm running Media Composer version 5.0 with whatever the latest update version was to 5.0
    Thanks.
    - Jared
  • Wed, Jul 20 2011 9:16 PM In reply to
    Jared:
    What you need to do is create a 29.97 project, import (or capture) your 29.97 media into that project, then go to your 59.94 project and use the "open bins" command to access the 29.97 material inside that project. As you cut it into the timeline, the system will automatically apply a timewarp algorithm to integrate it into the 59.94 sequence.
  • Wed, Jul 20 2011 10:00 PM In reply to
    • MAC HOLLAND
    • Joined on Fri, Jun 9 2006
    • Holland Landing Ontario
    • Posts 740
    • Points 9,305
    Was your original footage shot as interlaced or progressive -- I am trying to accomplish similar in going from 29.97p to blu ray
    AVID MEDIA COMPOSER 4.08 Asus P6T6 WS Revolution Intel X58 LGA1366 Motherboard Intel Core i7 920 Processor BX80601920 - 2.66GHz, LGA 1366, 4.8GT/s QPI... [view my complete system specs]
    MAC HOLLAND
    YORK REGION - ONTARIO
  • Wed, Jul 20 2011 11:24 PM In reply to
    Thanks Larry!
    That worked beautiful! Much appreciated!
    - Jared
  • Wed, Jul 20 2011 11:26 PM In reply to
    The 29.97 footage is interlaced, the 59.94 media is progressive. I used what Larry mentioned above and that worked great for me...
  • Wed, Jul 20 2011 11:30 PM In reply to
    You're quite welcome, Jared. Always glad to help out.Yes
  • Thu, Jul 21 2011 11:41 AM In reply to
    • MAC HOLLAND
    • Posts 740
    • Points 9,305
    For my own edification, to help undestand this, when you transcode from 29.97 interlaced to 59.94p is this eliminating upper-lower feilds to creat two frames from one?
    MAC HOLLAND
