Latest post Sat, Jul 9 2011 8:37 PM by RyanCB. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Jul 2 2011 6:58 PM
    • RyanCB
    • Joined on Sat, Jul 2 2011
    • Posts 18
    • Points 260
    AUTOSYNC audio problems - also bonus INSUFFICIENT MEDIA question!
    Hello all - I've done some searching around on the forums trying to find an answer to this - but no such luck - so I decided to make a thread.
    I'm having some issues with autosync.  I'm working from AMA linked .mov and .mp4 clips from a Sony F3, and imported sound files, and autosyncing them.  Things were going well until seemingly randomly when I autosync'd two sublclips the audio would cut out halfway through.  The audio track I used to autosync is the full length of the clip, so that's not the problem.  Also I can scrub through the clip with the 'blue bar' and hear the audio that way...
    Not sure if this is related, but ever since that's been happening, when I place a sync'd clip in the timeline, I can only hear the audio if it's on A3 & A4, not 1 & 2.  I tried toggling them on/off, solo/mute, etc etc but no luck...
    One last one: sometimes when I autosync and try to play the new clip, it gives me the PMM_INSUFFICIENT_MEDIA error.  I can sometimes still scroll around using the blue bar, but when I try to play, that error shows up and no dice.
    Any help at all would be greatly appreciated!  Thanks!
    PS - I'm running MC 5.5.1
    Filed under: , ,
  • Sat, Jul 2 2011 8:13 PM In reply to
    • Posts 11,323
    • Points 232,550
    Re: AUTOSYNC audio problems - also bonus INSUFFICIENT MEDIA question!
    Hi Ryan,
    First I suggest you update to MC 5.5.2 as there were quite a few area's of the app fixed which will definately help you.  Here is the PDF of the readme so you can see what is fixed....
    http://avid.force.com/pkb/LegacySearch?DocId=406151
    It sounds like something for corrupted.....  to verify - create a new timeline and add a bunch of clips and so a quick test to see if a new one works....   can you go back in time ( attic) and see if works?
    You say you get PMM_INSUFFICIENT_MEDIA  - is there more to that error when you posted?
    marianna
  • Sun, Jul 3 2011 9:52 PM In reply to
    • RyanCB
    • Posts 18
    • Points 260
    Hi Marianna - thanks for the reply!
    I just installed 5.5.2.  Unfortunately I'm still having some problems... I created a new sequence/timeline and just put a bunch of clips in - and sure enough the audio (even the audio that cuts out when viewed in the clip window) works on tracks 1 & 2.  The problem is, I already have a sequence cut together, and when I copy and paste that into the new timeline, the old problem of not hearing anything unless the audio is moved down to tracks 3 & 4 returns.  Do I basically have to redo everything in a new timeline?
    As for the insufficient media error, it happens very inconsistently when I try to autosync.  I make subclips of the video and audio files in a bin, highlight those two, and hit autosync.  Normally of course this works but occasionally it will create the new sync'd clip, but when I try to double click it to view it, I get a pop up window saying "Exception: PMM_INSUFFICIENT_MEDIA" and it won't play.  But the picture shows up in the clip window, and I can use the blue bar to scroll through it (and see the corresponding video) but every time I try to play it, I get that error.
    Do either of these things have to do with the fact that the video clips I'm syncing from already have in-camera audio?  Do I need to adjust something in the autosync window?
    Thanks!
  • Sun, Jul 3 2011 10:29 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,541
    • Points 64,320
      Moderator: MCA Mac
    Check to see if monitoring is turned on for Channels 1 and 2 on your timeline.  Click on the left facing triangle above the audio tracks on the timeline an see if the "power" button is turned on for those tracks.
    The PMM_INSUFFICIENT_MEDIA error means that the underlying clip grossly overstated it's assets and has now been embarrassed publicly.  Try re-importing the audio file(s) and re=syncing the clip(s).
    Yes, it sounds like you've grouped the clips and included the original tracks.  You can also sync the picture and external tracks manually on a timeline and turn that sequence or sub-sequence into a Synced clip that won't have the original camera audio.
  • Sat, Jul 9 2011 7:10 PM In reply to
    • RyanCB
    • Posts 18
    • Points 260
    Thanks for the reply.
    I have been running into some more problems which I think have to do with the audio clips grouping... even though I'm not even sure what grouping means.  I'm getting weird stuff like invisible audio tracks and overlapping audio tracks even though there's only 1 (set of 2) present...
    Is there a way to make a subclip of the IN->OUT of video footage without taking it's audio along?  I've just been holding alt and dragging from the clip monitor into a bin.  Also - how would I turn a section of manually synched footage in a timeline and turn it into a clip in a bin?  It's getting a bit annoying going from one sequence (my movie) to another (the manually synched clips sequence).   Thanks!
  • Sat, Jul 9 2011 7:15 PM In reply to
    RyanCB:
    Deselect the A-track buttons.
    RyanCB:
    Select the subsequence, and choose Bin->AutoSync. It's that easy :D
  • Sat, Jul 9 2011 7:29 PM In reply to
    • RyanCB
    • Posts 18
    • Points 260
    Ah, I didn't know you had to go to the bin level in order to get the Autosync button to work - thanks!
    As for the deselecting of the A-track buttons - you mean in the timeline window, right?  Because when I deselect them there and either alt-click-drag or hit my make subclip shortcut I'm still getting audio on the new subclip.
  • Sat, Jul 9 2011 7:50 PM In reply to
    If you're dragging from the source monitor, make sure to disable the audiotracks on the SOURCE side of the timeline. That selects what you are extracting from the source monitor.
  • Sat, Jul 9 2011 8:37 PM In reply to
    • RyanCB
    • Posts 18
    • Points 260
    Yeah, I deselect the audio tracks on the source side, but when I open the subclip I just made they reappear and there's still audio.  Happens for both dragging and keyboard shortcut.
