Latest post Fri, Jul 1 2011 6:19 AM by Lemuriatv. 3 replies.
  • Thu, Jun 30 2011 8:08 PM
    • opie177
    • Joined on Wed, Nov 18 2009
    • Chicago
    • Posts 72
    • Points 1,010
    Memory
    Good day. I have been working on a large project with numerous long-form sequences with hundreds of edits and graphics. I have been doing these shows on AVID for years and normally I have very few problems.
    I realized recently though that the Memory seems to jump way up pretty early in the editing day, and then I start getting error messages, things wont load, renders wont happen... just a lot of little things.
    I am just curiouos what I can do to avoid this or make the system more stable. I read some time ago how you can tell the computer to allocate more than the 2G RAM to MC... but I dont remember all the nitty gritty.
    My specs are below.... thanks!
    MC 5.0.3 running on a HP xw8600, 4G (or 6G) of RAM, Nitris box and 16Tb storage
    HPZ820, 2.6GHz,32G, Win10, NitrisDX, MC12.6 [view my complete system specs]
    Filed under: ,
  • Thu, Jun 30 2011 8:32 PM In reply to
    • Camilo
    • Joined on Fri, Jul 23 2010
    • Virginia
    • Posts 967
    • Points 12,140
    Re: Memory
    What OS are you using?  Win XP is known for not managing memory very well.  Also, you may find this intersting if you have so many edits in your timeline/project....  http://avid.force.com/pkb/LegacySearch?DocId=238681&ssdFilterCommunity15=1408&ssdFilterCommunity13=0&ssdFilterCommunity11=634&ssdFilterCommunity10=368&ssdFilter_SearchKeyWord=precomputes&page=1&ssdSearchOperator=0&ssdFilterCommunity3=0&Hilite=precomputes
    Intel i7-980x Hexacore water cooled by Corsair H-50 on EVGA Classified 762 with 12Gigs RAM and Quadro FX3800 Video Card. Sound Blaster X-fi Titanium Sound... [view my complete system specs]
  • Thu, Jun 30 2011 8:46 PM In reply to
    • Tugger
    • Champaign Illinois USA
    • Posts 676
    • Points 8,770
    Re: Memory
    If your on a 32 bit system (didn't notice which OS you're running) there's a utility that you'll find in the utility folder (where else) called 3GB. Once you've run it you'll have an option on boot up to select an AVID preset dedicating more ram to the ap. Not a lot more, but hey, every little bit helps. If you're using a lot of AVX effects (like BCC), having those timelines open, or even the bins with those timelines open increases memory usage. You can try the "clear bin memory" button under the info tab in the project window.
    If you're on a 64 bit system, MC can already access all the ram it can.
    MediaComposer 2018.X on HP8770 Windows10pro / MediaComposer 5.5 on HP8740.eSATA external media drives. Samsung 24" computer monitors when in office... [view my complete system specs]
  • Fri, Jul 1 2011 6:19 AM In reply to
    • Lemuriatv
    • Joined on Wed, Mar 5 2008
    • Czech Republic
    • Posts 229
    • Points 2,810
    Re: Memory
    I already use 3GB utility but I still have problem with memory as described here
    http://community.avid.com/forums/p/97542/559355.aspx#559355
    Memory usage increased incredibly.
    CPU Intel Core i7-7820X, MSI X299 SLI Plus, 64 GB RAM DDR4-2666 MHz,NVIDIA Quadro K5200, 4 TB for video (2 TB in Raid + 2 TB on SSD), Win10Pro, MC 8.4... [view my complete system specs]
