Latest post Sun, Jul 10 2011 7:57 AM by dreid. 15 replies.
  • Tue, Jun 21 2011 7:39 PM
    • ozzob
    • Joined on Mon, Aug 23 2010
    • Posts 89
    • Points 1,180
    New Windows 7 system configuration
    Greetings,
    This question is about configuration of Windows 7 for use with MC 5.0.x as part of a new build.
    Background: I'm moving from an XP setup that was configured for dual booting. This allowed be to isolate MC 5 from everything else you might find on a computer and this has worked well. I use MC 5 as a hobby so it is a bit of a stretch to dedicate a machine to it exclusively.
    Windows 7 64 is going to be new to me, so I will be learning it as I go.
    One thing I've just learned is that W7 cannot be used in a dual boot system with itself (like I did with XP). Apparently Microsoft considers installation of the same serial number on different partitions on the same computer as multiple machines and will not allow this. Hmmm...
    Obviously I can purchase a second copy of W7, and then configure the dual boot, and maybe that is the best approach. But since I know so little about W7 at this point I'm wondering if there are better solutions.
    Questions:
    1. Do you find MC5 to live and play well with other typical applications? (Office, Quickbooks, normal stuff)
    2. Is there some other means of configuring W7 to achieve the same goal of isolating MC from all/most of the other applications?
    3. Am I asking questions that have already been thorougly addressed somewhere that I can be pointed to?
    I don't post much, but I frequent the board daily for insight and troublshooting.
    Best regards.
    MC latest w/Symphony | 416.34 video driver | Quicktime 7.7.9 | Boris CC 2019 | Squeeze Pro 11 | Sony DVD Architect Pro 6.0 | Windows 10/64 Professional... [view my complete system specs]
  • Tue, Jun 21 2011 8:29 PM In reply to
    Re: New Windows 7 system configuration
    From the time I moved to W7 64bit from Vista I never looked back.
    I love W7.
    I can have MC 5.5.2 and AE and TMPGEnc open at the same time.
    No problems. I am not talking about Office because this is easy.
    But you will need W7 64bit and 8G of RAM or more.
    At the next upgrade I will go for 12G.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Wed, Jun 22 2011 1:28 AM In reply to
    • ozzob
    • Posts 89
    • Points 1,180
    The system will be running a i7 hex core, 12gigs of memory and a Quadro 2000. Room for another 12gigs of memory if needed, all on a Asus p6x58d-e.
    When you say Office is easy, do you mean it seems to reside on the same partition without difficulty?
    I came from Liquid, and I always found that other software installations could complicate things, even if not in use at the same time. Maybe MC is happy to share the same partition. That would be nice.
  • Wed, Jun 22 2011 3:12 AM In reply to
    • Camilo
    • Joined on Fri, Jul 23 2010
    • Virginia
    • Posts 967
    • Points 12,140
    I run MS Office on my MC system without any problem at all...
    Intel i7-980x Hexacore water cooled by Corsair H-50 on EVGA Classified 762 with 12Gigs RAM and Quadro FX3800 Video Card. Sound Blaster X-fi Titanium Sound... [view my complete system specs]
  • Wed, Jun 22 2011 7:36 AM In reply to
    ozzob:
    Where do you think I came from?
    But I don't have Liquid anymore, it's only AE and other programs.
    I mean if MC can go side by side and at the same time with "heavy" apps like AE or TMPGEnc
    (when encoding) why shouldn't go well with MS Office.
    This I have it open for all the hours I am editing a show, because I look at the script at the same time.
    Desktop PC
  • Wed, Jun 22 2011 9:25 AM In reply to
    Generally the rule should be to minimise the amount of otehr applications you have on your Avid editing system. The more you have the more chances of something going wrong and the harder it is to recover if you have to a clean re-build.
    That said there are more and more apps that you need to access on the same machine and I've not yet had an issue using any of the common ones mentioned.
    But if it's practical to have an app on a seperate machine (and sometimes that means you can work in parallel) then that's the route to take.
    Just watch for anything that tries to update display drivers or other drivers required my MC.
  • Wed, Jun 22 2011 12:03 PM In reply to
    • Lembit Soobik
    • Joined on Sun, Sep 2 2007
    • Freising - Germany
    • Posts 286
    • Points 3,740
    I have Photoshop, Lightroom, Audition 1.5, Sonicfire, Vasco da Gama on the same Win7-64 as MC5 and have seen no problems.
    I don't have Office on this one, however if you want to isolate some Win-XP programs put them in virtual machines. This is easy to do. Just download the XP-mode from Microsoft and you can put up as many virtual machines as you like. Your 12 G RAM should be enough to hold them minimized while you work on MC, or put them in sleep mode. They are all (each) just in a file and have nothing to do with your MC. I have (not on the MC machine) on a W7-64 pro 16 G Ram about 4 XP virtual machines, because my old XP is getting slow and having problems, I cloned it and put it on the W7.
    Lembit
    MC 2018.5 on Windows 10// HP Z800 WS: 2 x Xeon X5570, 48 GB RAM, Quadro M4000 32GB, disks: 1 x 500 GB SATA 7200 = System/ 1 x 1 TB Samsung 840... [view my complete system specs]
  • Wed, Jun 22 2011 3:31 PM In reply to
    • ozzob
    • Posts 89
    • Points 1,180
    Thanks all. I appreciate your comments.
    I think what I will do is partition the boot drive and set aside a piece for possible future installation of another interation of W7. While I'm dissapointed in Microsoft's policy of requiring acquisition of yet another copy for installation on the same machine, it is not an expenive solution in the grand scheme of things. In the mean time I will try a comingled installation, with efforts to keep it to a minimum, and see how it goes.
  • Wed, Jun 22 2011 3:39 PM In reply to
    Pat Horridge:
    Generally the rule should be to minimise the amount of other applications you have on your Avid editing system. The more you have the more chances of something going wrong and the harder it is to recover if you have to a clean re-build.
    And I can tell you from my own hard experience over many years of using Composer, and from issues I've had to deal with on other client's computers loaded to the brim with dozens of other non-media related applications in addition to Composer, that this is very true. You're best off only loading on additional applications that are necessary to support and enhance your workflow in and out of MC. Lean and mean is the best way to go for long term reliability and stability.
  • Wed, Jun 22 2011 3:51 PM In reply to
    I have everything running on one machine with no problems. MC, the Adobe package, sorenson squeeze, email, office, etc.
    Media Composer 2019.11 Home-built Windows 10 Pro Asus Z87-A Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz, 3101 Mhz, 4 Core(s), 4 Logical Processor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Thu, Jun 23 2011 9:39 AM In reply to
    • kd-53
    • Joined on Wed, Apr 28 2010
    • Duesseldorf, Germany
    • Posts 32
    • Points 405
    Hi ozzob,
    when I started with MC5 last year (coming from Liquid) I also had to setup a new computer with W7 64. I did it in the following way: I prepared 3 primary partitions (80 GB) and 1 primary partition for the rest (here 650 GB). On the first partition I installed XP for Avid Liquid. On the second partition W7. The W7 installation left the XP partition as it was. There is a good bootmanager (freeware) to handle this configuration: EasyBCD.
    Then I activated W7 and installed the basic software (Office, pdf, Firefox, Thunderbird,…..). Next step is a backup of this partition (Norton ghost). This backup can be put back on the third partition. EasyBCD will find it and now I have a partition to work with my normal programs and one partition for MC. Another backup of this partition with Norton ghost. I don’t see any problems with Microsoft because it is impossible to run these two instances of W7 at the same time.
    Regards
    Mobo: MSI MPG-Z390 Gaming Edge AC, i9-9900K, 32GB Ram, Win 10 Prof 64, GeForce GTX 2060 Super with 8 GB Ram, BM Intensity Pro 4K, MC 2019.12.1, BCC11,... [view my complete system specs]
  • Thu, Jun 23 2011 10:18 AM In reply to
    Take care with interpretation of license agreements.
    It may seem "morally" ok to have multiple installations of software on the basis that only one can be used at a time but if the license specifically states a limitation to installations of the software then that is the license limitation. If you chose to install more copies you are in breach of license.
    Had had a discussion with another tech person at another facility about the software tool they were using to make Flash encodes. They weren't aware that the license actual limited the number of encodes they were allowed to produce each day. When I pointed them to the license restriction they were surprised as the software allowed them to make an unlimited number of flash encodes and therefore they couldn't see any issues. Technically they were in breach of the license terms but felt that as no physical or technical limitation was in place then it wasn't a problem. Of course the price they paid for their software package was a fraction of the license fee I paid for unlimited Flash encodes from my software package. Which allowed them to produce files at a far lower cost than I could!
  • Fri, Jul 8 2011 9:29 PM In reply to
    • ozzob
    • Posts 89
    • Points 1,180
    Thought I would provide an update:
    I partitioned the machine as planned. XP on a partition for certain old applications. An unused partition for possible second installation of Windows 7. A large partition for Windows 7/64 with SP1, into which I've installed most of my applications.
    Included: Office 2007 (outlook, word, excel, whatever...), Dymo lable v.8, Adobe Acrobat 9 standard, iTunes (for my phone).
    I put MC 5.0.3.8 in near the end. Also AvidDVD 6.1.1. Sorenson Squeeze. Borris Continium. Sonicfire Pro 5, ParticleIllusion 3.0, CrazyTalk V5.1. Used correct divers for Quadro 2000. I am using the current release of QuickTime (iTunes wasn't happy with 7.6.6 so I went to 7.6.9).
    But wait, there is more.... Copernic desktop indexer, Juicer 3, and a few other things, including Avast for antivirus work.
    Yes, I've been ABUSING it. I'm amazed that it is running, but it is. All of it is. It will even run with Avast and Copernic in memory. I've been sucking in AVCHD 1080i files from a Panasonic TM900, editing, making titles with Marquee, inserting clips with an alphas channel from particle illusion, applying various effects, including some of the Borris stuff that seems pretty demanding. I went into Avid DVD from the timeline and burned a DVD (haven't tried a blue ray yet).
    Zero crashes.
    I really can't believe it.  I expected that I would have need to move MC and related products over to another bootable partition by now. I'm posting this while MC is running, Outlook is checking mail, Avast is monitoring everything in sight. I just plugged in my iphone and it is syncing, including a sync with my Outlook data.
    Now, clearly this is madness. And when I'm not feeling abusive I shut down anything I can while using MC. I'm just really surprised. The only quirky feeling thing is that AvidDVD takes pretty long to load. I've never used it before this installation, so I don't know what normal for it is.
    My impression is that controlling automatic updates, using specified drivers, large amounts of memory and sticking to a hardware configuration that very closely resembles the approved system is a big part of this present success. I don't use any external hardware/boxes/decks, so that is probably a factor as well.
    Or maybe just luck.
    That is the update.
  • Sat, Jul 9 2011 12:22 PM In reply to
    • DonR
    • Irving, Mexas
    • Posts 225
    • Points 3,130
    Ozzob,
    What firewire card are you using?
    Thank you.
    Don R.
    SuperMicro Superworkstation 7045A-T Computer Hardware: 1-Supermicro Sys-7045A-TB 4U Xeon 1333FSB FB-DIMM 6XSATA Motherboard X7DAE 2-Intel... [view my complete system specs]
  • Sat, Jul 9 2011 1:45 PM In reply to
    • ozzob
    • Posts 89
    • Points 1,180
    The ASUS motherboard has a firewire implemented onboard. I've not tried it yet with my older digital video tape camera yet. The Panasonic TM900 uses a USB port. I import directly from the camera into a bin.
