Latest post Tue, Oct 23 2012 9:47 AM by BarkinMadd. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Jun 15 2011 9:19 PM
    • Camilo
    • Joined on Fri, Jul 23 2010
    • Virginia
    • Posts 967
    • Points 12,140
    AVID DVD Question
    When I create a DVD with AVID DVD the DVD starts playing at the begining when inserted as opposed to starting at the menu.  Am I missing a setting somewhere that will make the disk open at the menu and not start playing right away?
    Thanks for any input!
    Camilo
    Intel i7-980x Hexacore water cooled by Corsair H-50 on EVGA Classified 762 with 12Gigs RAM and Quadro FX3800 Video Card. Sound Blaster X-fi Titanium Sound... [view my complete system specs]
  • Wed, Jun 15 2011 9:27 PM In reply to
    • Posts 10,365
    • Points 220,150
    Re: AVID DVD Question
    Camilo:
    It sounds like you have the words (First Play) beside the name of your Movie 1 - on the left side under the TITLES heading.
    You need to make your MENU the "First Play".
    Right click on your MENU and choose "Mark as First Play"
    Regards,
    Douglas
  • Wed, Jun 15 2011 9:54 PM In reply to
    • Atomike
    • Nebraska
    • Posts 731
    • Points 11,160
    Adding to what Douglas said, for me the best workflow is to create your menu first. Drag a graphic onto the top box when you open a project. Later, when you add media, drag your clips into the section below the menu(s) you've created.
    Media Composer version: usually newest release, or 1 behind. Nvidia GTX 1070Ti Windows 10, Core i7 8700K processor, ASRock GA 1151 Z370 Motherboard... [view my complete system specs]
    I spend most of my time between New York and Los Angeles.  In Nebraska.
  • Wed, Jun 15 2011 10:12 PM In reply to
    • Camilo
    • Virginia
    • Posts 967
    • Points 12,140
    Thanks everyone, I'll give those suggestions a try!
    Camilo
  • Wed, Jun 15 2011 11:57 PM In reply to
    • Vidiot Tech
    • Joined on Thu, Apr 6 2006
    • South Carolina
    • Posts 155
    • Points 1,815
    Many thanks to Douglas for his great tutorials!
    After timidly trying AvidDVD for small one menu page projects I jumped in with both feet to author a dance recital DVD with 7 menus, most with 6 chapters per menu along with with a "First Play" FBI warning. As Atomike suggested I created the menus a week or so before I shot the recital using an advance copy of the program to label each chapter box.
    One of Douglas' tutorials talked about replacing the menu backgrounds with another image. I asked the studio owner to email me the background she used for her printed program & I pulled a widescreen ratio jpg from her graphic. I used the same fonts & colors she used on the printed program, so now my DVD menus tie in very nicely with the theme of the recital and the printed program.
    The only major problem I had was with the "Routing" of button pushes for the standard Up/Dow/Right/Left/Enter keys. After rendering the menus and program files to an .iso (this was a widescreen SD project) and burning a DVD-RW disk I discovered that while three of the Chapter Menus worked perfectly, two menus wouldn't let me move the selection up off the "previous page/next page/home" bottom row buttons. So I went back and studied the "Routing" portion of each button as well as the numbering syatem for each button until I finally figured out the routing process. Then it was just a matter of checking the routing sequence for each menu button and checking the function of all the button pushes in "Simulate". After rerendering the project and burning another DVD-RW disk all the button pushes worked as I wanted the to.
    Thanks again to Douglas!
    System Specs: Dell M90, 4GB Ram (3GB Avid Enabled), nVidia FX 1500 w/ driver 8.4.2.9, MC 2.8, QT 7.2, External WD 750 GB eSata Drive [view my complete system specs]
    Steve Godsey, CLVS
    Some producers are like slinkies: Completely useless, but you can't help but smile when you push one down the stairs.
  • Thu, Jun 16 2011 12:09 AM In reply to
    • Posts 10,365
    • Points 220,150
    Vidiot Tech:
    I am happy to hear that yet another "customer" is happy with my products.... Geeked
    The routing of the buttons is, as you described, not so difficult if you check them before burning.
    I cannot even remember what I have in the (over 3 hours) tutorials about button routing. I suspect that I don't even mention it. In that case it is a serious miss on my part.
    Probably I will make a newer - more up to date - version of my DVD/Blu-Ray tutorials at a later date. I will make sure to cover that area too.
    Regards,
    Douglas
  • Thu, Jun 16 2011 9:30 AM In reply to
    • AdamGiles
    • N.E. UK
    • Posts 461
    • Points 5,760
    Vidiot Tech:
    This an issue to watch for when creating menus and then removing media. If you delete a movie that is link to a button, the routing will change to miss this button. Adding new media and linking to the button does not update the routing.
    Easily fixed by clicking the "refresh routing" button.
    HP 8710W 4 Gig Ram. M.C. 6.0.5. [view my complete system specs]
  • Thu, Jun 16 2011 2:09 PM In reply to
    • Vidiot Tech
    • South Carolina
    • Posts 155
    • Points 1,815
    AdamGiles:
    Vidiot Tech:
    Thanks AdamGiles.
    I don't think that was my problem, as I hadn't deleted anything from the project. Really I don't know what the actual problem was, just that it worked after I went through & double checked the routing on all the buttons.
    And remember, "Simulate" is your friend. This allows you to check your button routings as well as chapter points before you spend the time rendering the DVD.
    Steve Godsey, CLVS
  • Tue, Oct 23 2012 3:41 AM In reply to
    • MIT LAB
    • Joined on Tue, Dec 29 2009
    • Posts 90
    • Points 1,535
    How do I start a new thread???????
    Work: HP Z800 8 core, 48Gb Ram, FX4800, 15K SAS, USB 3.0 G Drives, Matrox MXO2 mini, Dell 30 inch monitors displayport, Home:HP XW8200, XP pro SP3,... [view my complete system specs]
  • Tue, Oct 23 2012 9:47 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,630
    • Points 60,480
    You make me laugh!
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
