Latest post Sun, Feb 26 2012 7:24 PM by Randall L. Rike. 63 replies.
Page 1 of 5 (64 items) 1 2 3 4 5 Next >
  • Tue, Mar 22 2011 10:12 PM
    xw8400 Upgrade
    I have a xw8400 running xp with 5.1.  I want to upgrade to windows 7.  Do I just do a full install of 7 64 bit premium and how do I save the Avid.  Also how many ram sticks can I put in.  I now only have 3 gigs as XP can only see 3-Thank You
    xw8400 4 gigs ram, fx 1500 composer 6.0 Avid DVD, AVID FX windows 7 [view my complete system specs]
    RS
  • Tue, Mar 22 2011 10:58 PM In reply to
    • Freddy
    • Joined on Sun, Nov 5 2006
    • Sweden
    • Posts 255
    • Points 3,050
    Re: xw8400 Upgrade
    The problem is that HP never qualified the xw8400 with Windows 7, so there aren't any drives/bios updates on the HP page. [:'(]
    http://avid.force.com/pkb/LegacySearch?DocId=269631
    http://www.freddylinks.com <-- Find EVERYTHING Avid and Tutorials there. Probably the most comprehensive Avid only webpage with over 2000+ Links to Avid Video Tutorials and Avid Information for Media Composer, NewsCutter, Symphony, Interplay, ISIS, Unity MediaNetwork, ProTools, Avid Artist Series. Completely free of fees, registrations, and ads.
  • Tue, Mar 22 2011 11:02 PM In reply to
    • Camilo
    • Joined on Fri, Jul 23 2010
    • Virginia
    • Posts 967
    • Points 12,140
    Re: xw8400 Upgrade
    You are always better off doing a clean install of a new OS.  You will want to deactivate AVID before you install the new OS so you can reinstall and reactivate it on the new OS.  YOu should bear in mind that AVID only supports the Professional version of Win 7 64Bit not the Premium version.
    Good Luck!
    Intel i7-980x Hexacore water cooled by Corsair H-50 on EVGA Classified 762 with 12Gigs RAM and Quadro FX3800 Video Card. Sound Blaster X-fi Titanium Sound... [view my complete system specs]
  • Tue, Mar 22 2011 11:22 PM In reply to
    • daapap
    • Germany
    • Posts 523
    • Points 6,895
    Re: xw8400 Upgrade
    this thread might be of interest fo you since you will probably experience difficutlities with the firewire port if you want to work with Mojo SDI or Adrenaline. See Avid's technote.
    Beside that xw8400 and Win 7/64 works flawlessly for me.
  • Wed, Mar 23 2011 4:57 AM In reply to
    Re: xw8400 Upgrade
    The motherboard has 8 RAM slots.  8GB's works well.  There's a chart on the inside of the door that details where the DIMMs go in various configurations.
    (wwld)
  • Wed, Mar 23 2011 5:00 AM In reply to
    Re: xw8400 Upgrade
    "... I now only have 3 gigs ..."
    btw, your system specs currently say 8 GB's :)
    (wwld)
  • Wed, Mar 23 2011 6:06 AM In reply to
    • Cagey
    • Vista, CA
    • Posts 319
    • Points 3,990
    Re: xw8400 Upgrade
    Google how to install the upgrade version of windows 7 as a clean install.  It's really easy once you know the secret, and it saves a lot of time & money, not to mention dealing with possibility of driver update issues.  (Since you have a qualifying version there is no legal issue) I had no problem finding drivers for my xw8400 after the clean install .  Windows 7 has most things handled.  The Intel site has the MB chip drivers and if you check the device drivers for any remaining yellow ! these can be handled by searching for the Vista driver, as most current Vista drivers also support Windows 7.  Definetely go with 64-bit and pump up your memory as much as your wallet/motherboard can handle.  Don't forget to switch to the legacy 1394 driver if you have a Mojo SDI.  One last thing to do is run the System Prep utility.  There is a Windows 7 specific version coming out very soon, but I found that the older version worked great in turning off unnecessary windows features to give MC as much performance as possible.  My system has been rock solid.
    Keith
    MC8.6.1, Z420 Xeon E5-2670, 32GB RAM, GeForce GTX 1080, DIGI002, Win 10 Pro 64-bit [view my complete system specs]
    There are 10 kinds of people in the world, those that get binary, and those that don't.
  • Wed, Mar 23 2011 7:40 AM In reply to
    Re: xw8400 Upgrade
    Yup I have 2 Windows 7 64 bit xw8400 and they installed fine. Don't upgrade do a clean install.
    Get a new HDD and set it up on that. You can  then re-install all the apps you need and grab anything you forget off the old drive.
    Then when it's all setup and stable clone the new install back over your old drive and put it away as the emergency spare.
    Watch the firewire card issue that can cause problems. 8GB RAM minimum more if you can afford it.
  • Tue, May 31 2011 10:09 PM In reply to
    Re: xw8400 Upgrade
    I got a quote for an upgrade.  I guess cheaper than a new Avid.  Any suggestions would be appreciated!
    PRICE/UNIT EXTENDED
    Upgrade of Hewlett-Packard 8200 Avid System
    Price Includes:
    AMA-Upgrade Memory with ECC PC2-3200 DDR2 2GB Memory
    for Total of 16GB RAM.
    AMA-Upgrade of Operating System to Windows 7 Professional
    AMA-Upgrade Graphics Card to Nvidia GeForce GTX 590
    w/3GB VRAM
    Avid-Upgrade AVID Media Composer From 3.5 to 5.5
    ADO-Upgrade Adobe After Effects to CS 5
    Installation/Configuration Labor
    $2,325.00
    $800.00
    $2,325.00
    $0.00
    $0.00
    $0.00
    $0.00
    $0.00
    $800.00
    $3,125.00
    $273.44
    $100.00
    $3,498.44
    Subtotal:
    Tax:
    RS
  • Tue, May 31 2011 11:31 PM In reply to
    Re: xw8400 Upgrade
    Who's doing this upgrade?  "Nvidia GeForce GTX 590" isn't supported by Avid.  Only nVidia Quadro FX family cards are.  On the xw8400, how many procs and what speed?
    Check out these guys in Tarzana, CA.  All the systems need is the OS, approx $140 from TigerDirect.com.  They have a large stock of "Avid Qualified" nVidia cards as well.
    xw8400's off lease (No OS)
    http://www.itcreations.com/hp/HP_XW8400_WORKSTATION.html
    xw8600's off lease (No OS)
    http://www.itcreations.com/hp/HP_XW8600_WORKSTATION.html
    I bought an xw8600 from them, bare bones, and installed all new DVD drives, HDD's, SATA cables, CMOS battery etc.  Practically new :)
    (wwld)
  • Wed, Jun 1 2011 5:56 AM In reply to
    Re: xw8400 Upgrade
    I wouldn't recommend buying into 8400's anymore. Better to go for something a bit newer and faster, even if it's just the 8600.
  • Wed, Feb 8 2012 8:10 PM In reply to
    Re: xw8400 Upgrade
    I did a clean install of ultimate 64.  I moved the avid onto a fire wire drive.  Do I just move it back and open it back up?  What about the 32 programs?
    RS
  • Thu, Feb 9 2012 3:27 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,393
    • Points 97,070
    Re: xw8400 Upgrade
    videosmithlaguna:
    No, you will need to reinstall Avid before you can use it, as you must with most other Windows programs.
    You needn't worry about your 32-bit software either.  When you re-install them, Windows will put those programs in the correct directory with the appropriate registry settings for them to run in 32-bit mode on a 64-bit system.
    Of course you can't run 32-bit plug-ins inside 64-bit Media Composer.
  • Sat, Feb 11 2012 9:47 PM In reply to
    Re: xw8400 Upgrade
    I want to have 6.0.  I have a free upgrade to 6.0.   Do I still need to install 5.5 and then upgrade or can i go directly to the avid site and download 6.0 with the serial number.
    RS
    Filed under: ,
  • Sat, Feb 11 2012 10:53 PM In reply to
    Re: xw8400 Upgrade
    You never have to install a previous version (5.x)and work your way up to a more current version (6.0).  However, some "Patch Releases" require they be installed over the original install, but they'll be point releases of that same version.  The ReadMe will explain when to do that.
    Meanwehile, the installer for MC v6.0 and the recently released v6.0.1 are full installers.
    You'll download the installer package.  The new Serial Number will be e-mailed to you, or presented to you during the final phase of the online upgrade process.
    (wwld)
