Latest post Sat, Jul 16 2011 1:04 AM by Jasper Quispel. 14 replies.
Page 1 of 1 (15 items)
  • Sat, Mar 19 2011 5:49 PM
    • Mireille
    • Joined on Wed, Mar 16 2011
    • New York, NY
    • Posts 8
    • Points 90
    MC 5.5.1 crashes on upgrade from 5.0.3
    I've tried to upgrade Avid MC 5 Academic to MC 5.5 Academic. After a successful install and having been able to activate the software with my new serial number via internet connection, the application crashes on launch. I get the following bus error message: "Segmentation fault" in thread "Main Thread", at address 0x0. Before installing MC 5.5, I uninstalled MC 5 as recommended. I tried the procedure twice but it failed both times. I now have reverted to version 5.0.3 which works seamlessly.
    I have a 3 year old Mac Pro Quad core Intel Xeon, 8GB RAM, NVIDIA GeForce GTX285 card, running Snow Leopard 10.6.6, FCP also installed with Matrox MXO2. Is there any know compatibility issue?
    Thank you
    I have a mid-2010 Mac Pro 6-core Intel Xeon, 24GB RAM, ATI Radeon HD 5770 card, running OSX Maverick 10.9.5, and Matrox MXO2 [view my complete system specs]
  • Sat, Mar 19 2011 6:23 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,525
    • Points 64,130
      Moderator: MCA Mac
    Re: MC 5.5.1 crashes on upgrade from 5.0.3
    Will the software launch if you choose the free trial period?
    You need to install the new Matrox 2.2.0028 software from the Matrox site, but otherwise nothing obvious stands out.
  • Sat, Mar 19 2011 7:57 PM In reply to
    • Mireille
    • New York, NY
    • Posts 8
    • Points 90
    Okay. I need to update my version of the MXO2 but for some reason I'm running into trouble uninstalling the previous version. Once done, I'll try your suggestion of launching MC5.5 free trial version and see how it goes. Thank you for your help.
  • Wed, Mar 23 2011 2:04 PM In reply to
    • Mireille
    • New York, NY
    • Posts 8
    • Points 90
    I have updated MXO2 to the latest version and tried to re-install MC5.5. It didn't let me opt for the free trial version as my system ID appeared automatically. MC5.5 crashed on launch same as before. I reinstalled version 5.0.3 which again works fine. Any other suggestions would be much appreciated. Thanks
  • Wed, Mar 23 2011 2:48 PM In reply to
    Check this thread and see if Fendstrat's suggestion works for you...
  • Thu, Mar 24 2011 4:28 AM In reply to
    • Crowderville
    • Malibu, California.
    • Posts 27
    • Points 405
    Had the same issue, also audio scrubbing not working properly...jumps frames without hearing them....
    crashes after about 60 mouse clicks or key strokes.
    reverted back to 5.0.3
    iMac 10.9.2 3.5Ghz Intel Core i7 MC 6.5.4 Sapphire 7 [view my complete system specs]
  • Mon, Apr 4 2011 4:36 PM In reply to
    • Mireille
    • New York, NY
    • Posts 8
    • Points 90
    I finally resolved the issue, kind of. There is a conflict between Matrox MXO2 v. 2.2.1 and MC 5.5.1. Once I de-installed MXO 2 sw, I was able to open MC and run it without problems.
  • Mon, Apr 4 2011 5:00 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,345
    Mireille:
    I am not seeing this when using my certified MBP as in profile below, MM driver 2,2,1 and MC 5,51 works well as expected.
    Could you please give us some more info about your system, your profile seems to be empty
    Tomas
  • Mon, Apr 4 2011 6:40 PM In reply to
    • Mireille
    • New York, NY
    • Posts 8
    • Points 90
    Here is the answer I received from Matrox:
    As for AVID MC 5.5.1 issue, as you know the MXO2 Mini or Mini MAX is only supported with AVID software.
    As a result, if you want to run AVID, you should either disconnect the MXO2 hardware or uninstall the MXO2 software drivers. We are aware of this issue with AVID MC5.5.1 and MXO2 2.2 drivers.
    We apologize for any inconvenience this has placed in your workflow.
    _________________
    Regards,
    Sam
    Matrox Video Technical Support
  • Mon, Apr 4 2011 8:19 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    Mireille:
    and ...
    _________________
    Regards,
    Sam
    Before I ping a friend at Matrox about this, could you please clarify what drivers you are using, including the last three digits after the version number
    Tomas
  • Mon, Apr 4 2011 8:49 PM In reply to
    • Mireille
    • New York, NY
    • Posts 8
    • Points 90
    Here is the MXO2 software version installed on my system:
    2.2.1.0042
    Firmware Version 31.1
  • Mon, Apr 4 2011 9:17 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    Thanks a lot, I have just asked for clarification from Matrox about this as your Matrox support answer was refering to driver 2.2
    Tomas
  • Wed, Jul 13 2011 3:17 AM In reply to
    Any news from Matrox?
    I have the same problem (many crashes) with the MXO2 turned on. I am on the AVID supported driver 2.2.0.00028 with MC 5.5.1 on OSX 10.6.6.
    I just bought the upgrade to MC 5.5 because of 1080 24p support on the MXO2 mini, so hope there is a fix for this.
    Jasper
    Mac Pro late 2013 3,5 Ghz 6-Core, 64Gb, OSX 10.10.5, Avid MC 8.4, Blackmagic Ultrastudio Express Macbook Pro retina 2012 15 inch i7, 16Gb, OSX 10.10.5... [view my complete system specs]
  • Wed, Jul 13 2011 5:02 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    Have you tried driver 221 0042
    Tomas
  • Sat, Jul 16 2011 1:04 AM In reply to
    I have, but the same problem remains.
    It might have something to do with that we are editing some 24p PAL material in a 24p 1080 project, but my neighbor does the same thing with exactly the same setup (only a newer mac pro) without crashes.
    I really need 24p and therefore MC 5.5.1, but I think I need to go back to my MOJO SDI now.
    Cheers,
    Jasper
