Latest post Wed, Nov 21 2012 10:32 PM by anglegrinderUK. 29 replies.
Page 1 of 2 (30 items) 1 2 Next >
  • Fri, Mar 18 2011 10:42 PM
    • nigelw
    • Joined on Wed, Feb 2 2011
    • Posts 9
    • Points 135
    Error -5000 while verifying your authorisation
    I am getting this message when attempting to open v5.5.1 for first time and it wont let me in.  Please help q urgent.
  • Sat, Mar 19 2011 1:41 AM In reply to
    • Chepal
    • germany
    • Posts 538
    • Points 6,305
    Re: Error -5000 while verifying your authorisation
    fendstrad from avid:
    1.  Create a folder on your desktop, you can call it "AIR Plugins"...doesn't really matter
    2.  Go to Mac\Application Support\Digidesign\Plug-Ins and drag out the first 20 plugin files that begin with "AIR" and move to the Air Plugins on the desktop so that they are no longer in this folder.
    3.  Relaunch and you should no longer receive the -5000 error
    good luck
    mac_mc_2020, fibre, sata, ssd [view my complete system specs]
    peace from germany
  • Sat, Mar 19 2011 9:03 AM In reply to
    • nigelw
    • Posts 9
    • Points 135
    Thanks for the reply.  Have searc hed my system and i dont have a digidesign folder in application support.  Any further ideas?
  • Sat, Mar 19 2011 6:26 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,541
    • Points 64,580
      Moderator: MCA Mac
    Library/Application Support
  • Sun, Mar 20 2011 12:24 PM In reply to
    • nigelw
    • Posts 9
    • Points 135
    Thanks very much for your help, worked once plug ins removed.
  • Tue, Mar 29 2011 6:13 PM In reply to
    • fdomago
    • Joined on Fri, Nov 28 2008
    • Posts 3
    • Points 35
    Hi hbrock,
    Thanks for your help, works fine. What do I do with this desktop created folder?
  • Mon, Apr 4 2011 5:28 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,541
    • Points 64,580
      Moderator: MCA Mac
    Delete it.
  • Mon, Jul 25 2011 2:14 PM In reply to
    • mikepat
    • Joined on Mon, Apr 24 2006
    • London, UK
    • Posts 29
    • Points 405
    I'm upgrading from 5 to 5.5.1 and I get this error, but when I look in Library>Application Support there is no Digidesign folder to delete files from - any ideas?
    MC 8.6.1, OS X 10.10.5, 2x2.8 GHz Quad-Core Intel Xeon (Harpertown), 8GB RAM, NVIDIA GeForce 8800 GT [view my complete system specs]
  • Tue, Jul 26 2011 2:01 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,541
    • Points 64,580
      Moderator: MCA Mac
    There are Library folders for the System at the root level as well as a Library folder for each user.  Make sure you're looking in the correct Library folder.  (BTW, if you want to go crazy, try to count how many Font folders there are on your boot disk.)
  • Tue, Jul 26 2011 8:11 AM In reply to
    • mikepat
    • London, UK
    • Posts 29
    • Points 405
    doh! of course.  That fixed it - many thanks
  • Wed, Aug 17 2011 10:50 PM In reply to
    • MikeO
    • Joined on Wed, Jul 25 2007
    • Posts 22
    • Points 320
    I'm having this problem too when I try launching 5.5.2 for the first time.  I don't have a Digidesign folder on my system (I looked in the Application support folder and did a system search for "digidesign."  I also searched for Air plugins -- no luck.  Any thoughts?????
    MikeO
  • Wed, Aug 17 2011 11:02 PM In reply to
    • Posts 11,538
    • Points 254,875
    MikeO
    Spec's would really help us here - flying blind without knowing what Mac, OS etc you have.
    The 5000 error on 10.6.7 and below and 5.5.2 and below was caused by incompatible plug ins.
    On your Mac - go to Maintosh HD then open Library\Application Support\Digidesign\Plug-Ins and get rid of the first 20 plugin files that begin with "AIR".     Either move them to a folder on the desktop or delete them just as long as they are no longer in this folder.   Make sure you dont have any hidden files and folders.
    2.  Relaunch and you should no longer receive the -5000 error.
    Otherwise give us a little bit more info.... did it just happen or did you jsut update?  System Specs should be added to your profile - go to your name in the right hand corner of community and click on it- then edit profile.
    marianna
  • Thu, Aug 18 2011 3:21 PM In reply to
    • MikeO
    • Posts 22
    • Points 320
    I'm on 10.6.6 and just upgraded to 5.5.2.  Haven't been able to get it to launch successfully.  Always get the -5000 error.
    As I said before, I do not have the Digidesign folder nor do I have any AIR plug ins.  I've looked in the appropriate folder location and done a system search to double check.  I've reinstalled Avid, still nothing.  I'm mulling upgrading to 10.6.7 if I can find it somewhere.
  • Thu, Aug 18 2011 3:24 PM In reply to
    Is this the first time you've tried to use MC?  Or did you upgrade and now it doesn't work?
    That being said, as long as you're dealing with this, I would strongly suggest you uninstall 5.5.2, download the OS 10.6.8 v1.1 Combo update from Apple, install, then download 5.5.3 and install that.  Many bug fixes in the latest software.
  • Thu, Aug 18 2011 3:38 PM In reply to
    • MikeO
    • Posts 22
    • Points 320
    No, I've been on Avid for 8+ years.  I upgraded because the version I was in wasn't importing P2 media correctly.
    There's another system in house that's been buggy with 10.6.8, so I'm holding off on that for the moment.  I just upgraded to 10.6.7 and that didn't solve the problem, so I'm trying a reinstall of Avid 5.5.2 again.
