Latest post Thu, Jun 6 2013 5:48 PM by Nick. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Mar 10 2011 5:20 PM
    • adj4
    • Joined on Fri, Feb 19 2010
    • France
    • Posts 14
    • Points 190
    issue with an ATI card
    Hello, I have already written about this issue that I have but thanks to someone on this site I know that it is probably caused by the fact that I have an ATI Radeon HD 5750 and that ATI cards aren't supported by Avid.
    So, my software is almost running good but there is a problem when I play a video: there are some horizontal lines "cutting" the screen when there are quick movements in the video. I am wondering if there is no solution to make this issue disappear. Are there some drivers or something else that can improve my Avid-ATI compatibility?
    Acer Aspire Predator g5900-042, Intel Core i5 650 3.20GHz, 8.00 GB RAM, ATI Radeon HD 5750, two 690 GB hard drives, Windows 7 64 bits. Avid Media Composer... [view my complete system specs]
  • Thu, Mar 10 2011 5:27 PM In reply to
    Re: issue with an ATI card
    adj4:
    Is this on the PC screen or on your broadcast monitor?  Or, put another way, do you see this on exported files or DVDs, or only on your PC screen?
    ciao,
    Carl
  • Thu, Mar 10 2011 5:34 PM In reply to
    • adj4
    • France
    • Posts 14
    • Points 190
    No I only see this on my PC screen when running a video in Avid. I think that if I export a video this won't appear on it but I didn't tried it.
  • Thu, Jun 6 2013 3:59 PM In reply to
    • Nick
    • Joined on Tue, Apr 9 2013
    • Posts 18
    • Points 180
    Hi, I have: Avid Media Composer 6.5.2 Macbook Pro Retina Display 2.6GHZ, 16GB ram, SSD And I have the same issue. Horizontal lines across the screen which are more noticeable on pans and fast action. On one commercial I had to export to a quicktime to present to the director every time while on-set. Another strange occurrence is that if I record the screen with quicktime while playing footage in Avid I see the horizontal lines as usual but when I play back the recorded footage in quicktime it looks fine. This automatically tells me that it has something to do with the way Avid and the graphics card/screen respond. I also notice the same problem with Avid Media Composer 5.5 on an older macbook pro years ago. I hope the newer one would get rid of this but I guess not. My last hope would be a simple change of the settings in Avid. Has anyone found a solution to this other than playing out to an external monitor via I/O device?
    Macbook Pro, 2.6 GHz, i7, 16GB DDR3, 500GB SSD, NVIDIA GeForce GT 650M 1024MB [view my complete system specs]
  • Thu, Jun 6 2013 4:45 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,194
    • Points 23,515
    Im using a mbp with a hd display  and do not have the problem at all could it be the refresh rate on monitor
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Thu, Jun 6 2013 5:01 PM In reply to
    • Nick
    • Posts 18
    • Points 180
    I have read else where that it could be the refresh monitor but sadly the MBP Retina doesn't have the option to change the refresh rate that I know of. Thanks for the reply.
  • Thu, Jun 6 2013 5:48 PM In reply to
    • Nick
    • Posts 18
    • Points 180
    Solution for Macbook Pro Retina:
    In the "Settings" tab in Avid, go to "Full Screen Playback" and then check the "Flip on vertical Sync" Box.
