Latest post Mon, Feb 14 2011 11:59 PM by RyanR. 6 replies.
Page 1 of 1 (7 items)
  • Sat, Feb 12 2011 8:34 PM
    Bus/Segmentation error main thread when importing video
    Hello,
    I have installed MC5 on a macbook pro
    Model Name:    MacBook Pro
      Model Identifier:    MacBookPro6,2
      Processor Name:    Intel Core i5
      Processor Speed:    2.4 GHz
      Number Of Processors:    1
      Total Number Of Cores:    2
      L2 Cache (per core):    256 KB
      L3 Cache:    3 MB
      Memory:    4 GB
      Processor Interconnect Speed:    4.8 GT/s
      Boot ROM Version:    MBP61.0057.B0C
      SMC Version (system):    1.58f16
      Serial Number (system):    W810328EAGU
      Hardware UUID:    4ED79878-75DD-57B1-A3FD-D6F066B2A590
      Sudden Motion Sensor:
      State:    Enabled
    Whenever I try to import video into a project it crashes at the end of the import showing me "Segmentation error Main Thread adress 0x0"
    I read all the forums and couldn't find anyone with the same exact problem, am going crazy, would truly appreciate any help you can give me. Am getting seriously behind on some work.
  • Sun, Feb 13 2011 12:27 AM In reply to
    • RyanR
    • Joined on Mon, Aug 25 2008
    • Posts 39
    • Points 455
    Re: Bus/Segmentation error main thread when importing video
    Hi AL,
    What version of MC5 & what version of OS X are your running.
    Take a look at the version matrix to make sure you've got the right OS for your version of MC : http://avid.force.com/pkb/LegacySearch?DocId=267087
    What kind of video are you trying to import?
  • Sun, Feb 13 2011 10:19 AM In reply to
    Hello Ryan, thanks for your reply.
    I had MC 5.0.0 and downloaded the editor patch which upgraded it to 5.0.3.5.
    The OS X I am running is 10.6.6 which is the newest version and not included in the matrix, could that be the problem?
    The video I am trying to import is a mov file I downloaded from the internet. Just tried importing an audio file (both wav and mp3) and it gave me the same errors. Both segmentation fault en bus error after which Avid just shuts down.
    Don't know if this helps, here is a part of the crash report.
    Process:         AvidMediaComposer [369]
    Path:            /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
    Identifier:      com.avid.mediacomposer
    Version:         5.0.3.5.21200 (5.0.3.5)
    Code Type:       X86 (Native)
    Parent Process:  launchd [97]
    Date/Time:       2011-02-13 12:58:38.541 +0200
    OS Version:      Mac OS X 10.6.6 (10J567)
    Report Version:  6
    Interval Since Last Report:          599942 sec
    Crashes Since Last Report:           46
    Per-App Interval Since Last Report:  7948 sec
    Per-App Crashes Since Last Report:   8
    Anonymous UUID:                      2B8CAD84-AD1F-498F-A998-E4F361076895
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000ffffffff
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
  • Mon, Feb 14 2011 11:10 PM In reply to
    • RyanR
    • Posts 39
    • Points 455
    Hey AL,
    Yes, 10.6.6 could absolutely be the issue. The latest certified OS is 10.6.5. And there's a footnote at the bottom of Version Matrix (which is very easily missed) that if you're running 10.6.5, you MUST run the v5.0.3.7r patch.
    You should downgrade the OS to a supported version listed in the matrix.
    But as a quick & dirty [possible] solution, you can try downloading and installing that patch (linked to in the matrix footnote). That will still leave you with an unsupported configuration, but it may resolve this error.
    Let us know how it goes.
  • Mon, Feb 14 2011 11:19 PM In reply to
    I will do that now, will let you know how it goes.
    I tried opening a new user account on my mac and gave it all admin permissions. And to my surprise Avid worked perfectly there, I could import video and audio. What does that mean? Could there be something blocking the Avid in my main user account?
    Again, thanks for your help Ryan :)
  • Mon, Feb 14 2011 11:29 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,541
    • Points 64,320
      Moderator: MCA Mac
    You need to run Avid with Administrator account privileges or certain files can't be accessed and it doesn't work correctly.
  • Mon, Feb 14 2011 11:59 PM In reply to
    • RyanR
    • Posts 39
    • Points 455
    As hbrock said, if your main user account didn't have Admin priviledges, that could absolutely have been the issue.
    If you main user does have Admin priviledges, this could be a sign of user corruption or permissions issues. This is especially likely if you migrated the user account from an older computer.
