Latest post Thu, Jan 20 2011 7:28 PM by Job ter Burg. 11 replies.
Page 1 of 1 (12 items)
  • Sun, Jan 16 2011 5:05 PM
    • mkeady
    • Joined on Tue, Aug 29 2006
    • Posts 31
    • Points 395
    2.35:1 Anamorphic Reformat in Avid
    Am working on a production where they are shooting with an anamorphic lense (1.3 squeeze) on the Arri Alexa camera, which will give a final aspect ratio of 2.35:1. What avid reformat effect should I be using to make this look 'normal' and squeeze the image for the offline?
    Media Composer 5.5.3 Adrenaline Mac OSX 10.6.8 [view my complete system specs]
  • Sun, Jan 16 2011 6:40 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,525
    • Points 64,140
      Moderator: MCA Mac
    Re: 2.35:1 Anamorphic Reformat in Avid
    I'm not sure if there's a 16:9 (1.77) to 2.35 reformat option.  You might need to just apply a 33% stretch for starters and check it against a known round circle (did they shoot a framing chart?).
  • Sun, Jan 16 2011 7:16 PM In reply to
    • mkeady
    • Posts 31
    • Points 395
    Do you mean apply a squeeze, as the footage looks stretched when it is loadsed into Avid? Can I apply something like a 16:9 reformat and ammend that? They only shot a framing leader, not a chart.
  • Sun, Jan 16 2011 7:44 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,525
    • Points 64,140
      Moderator: MCA Mac
    First off, if you're using MC5, try the settings on the Reformat column in the bin to see if you can get the picture formatted correctly.  If they squeezed the picture on capture, everyone should look like they've grown taller and lost weight rather than the opposite.  Check the size of the image in Quicktime or something and see if it's something other than 1920x1080.
  • Sun, Jan 16 2011 8:03 PM In reply to
    • mkeady
    • Posts 31
    • Points 395
    The ProRes QT's I am receiving from set are stretched so zero's (o) look live ovals (0). The image is 1920x1080, and yes everyone does look taller. I just want to squash the image back down to size. Will a pan and scan work, altering the options on it?
    (I will also try the reformat column.)
  • Sun, Jan 16 2011 9:21 PM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,795
    Are you asking to adjust the size for display or final purposes? Any reformat effect you apply will change the aspect of the final file. I don't think that's what you want to do. Is it? Don't you want it to stay 2.35:1 for the final product?
    - Oliver
  • Sun, Jan 16 2011 10:09 PM In reply to
    • mkeady
    • Posts 31
    • Points 395
    Well , I'm viewing my footage in 16:9 (by turning my monitors to 16:9) and its still anamorphic. Im outputting DVD's and QT's and need them to be 2.35:1 in 16:9 so I need to squeeze them to look 2.35:1.
  • Sun, Jan 16 2011 10:57 PM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,795
    Then you'll need to apply an effect to vertically squeeze the image. This will need to be applied to each clip or a higher, blank video track. The resulting image will be letterboxed within a 16x9 screen. If you are supposed to deliver a final master out of your system that maintains the anamorphic aspect (2.35:1), you will need to remove all such effects prior to final output.
    - Oliver
  • Sun, Jan 16 2011 11:11 PM In reply to
    • mkeady
    • Posts 31
    • Points 395
    Will a 16x9 Reformat effect be OK to use for this? I wasn't sure seeing as I'm dealing with 2.35:1 anamorphic material. I'm not delivering teh final master output from my system. I'm only dealing with the offline and will be conformed/online elsewhere, so teh effect I am adding won't be permanent and can be removed/changed whenever.
  • Mon, Jan 17 2011 12:22 AM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,795
    There is no exact preset. Simply use the Resize effect and adjust vertical until it looks right.
    - Oliver
  • Thu, Jan 20 2011 6:43 PM In reply to
    • mkeady
    • Posts 31
    • Points 395
    Ok thanks. Cheers for help and advice
  • Thu, Jan 20 2011 7:28 PM In reply to
    Not sure, but the 2.35 mode of HDCAM camcorders used to a a double 16x9 squeeze, so applying a 16x9 LTBX reformat within a 16x9 project would result in the right aspect ratio.
    You'd need to find out if the squeeze is indeed 1.30 or that it is in fact 1.33. If the latter, you should be fine using a 16x9 reformat.
