Latest post Mon, Dec 20 2010 12:24 PM by RADIUS. 7 replies.
  • Sat, Dec 18 2010 2:29 PM
    • RADIUS
    • Joined on Sat, Jun 12 2010
    • Vibo Valentia (Italy)
    • Posts 212
    • Points 2,690
    Problema con timewarp - Problem with timewarp effect
    Salve. Ho un problema con i timewarp. Quando applico timewarp effect e rederizzo la clip il video va a scatti, con qualsiasi impostazione. Usando Vtr Style, Duplicate Fied, Fluid Motion... il risultato è lo stesso .Da cosa può dipendere? Ho anche provato a cambiare HDD per il rendering eper l' acquisizione, ma inutilmente. Ho anche formattato il Pc. Succede sia con Xp che con Seven. Ho aggiornato i drivers della scheda grafica ma non cambia nulla.
    Hello. I have a problem with timewarp effect. When I apply timewarp effect and rende, the clip the video goes in spurts, with any setting. Using Vtr Style, Duplicate Fied, Fluid Motion... the result is the same. May depend on what? I also tried to change HDD for rendering and import the clips, but to no avail. I also formatted the PC.It happens with both XP and Seven. I updated the drivers for my graphics card but nothing changes.
    SW: MC 6  on Seven professional 64 - Liquid 7.2 on Xp Sp3
    HW:  Asus P6t  Cpu Intel i7 930  Ram DDR3 Kingston (4gb x3)  Vga Quadro Fx 1800  Audio Creative SB audigy
    Hd (sistem) Maxtor 320  Hd Western digita(1TBx4)
    Filed under: ,
  • Sat, Dec 18 2010 5:29 PM In reply to
    Re: Problema con timewarp - Problem with timewarp effect
    What version of MC are you running?
    radius:
    You should be running the driver version that is qualified in this version matrix, not necessarily the newest driver.
  • Sat, Dec 18 2010 6:07 PM In reply to
    • RADIUS
    • Posts 212
    • Points 2,690
    Thanks.
    My version is 5.035.
    I tried with 190.38  certified drivers, and even with the new, but the result does not change.
    I find certified drivers  in C:\Program Files (x86)\Avid\Utilities\nVidia\190.38_quadro_win7_winvista_64bit_english_whq
  • Sun, Dec 19 2010 10:15 AM In reply to
    Does video play normally without timewarp effect? Maybe field dominance is wrong? (Check by setting project to interlaced, step half-field-wise with ALT+2 or ALT+1 on the normal keypad, not the numeric one...)
    i7 3.4 GHz | Asus HERO Z170 | 32GB Ram | Quadro k620 | Intensity Pro 4K | WIN7 64bit Pro [view my complete system specs]
  • Sun, Dec 19 2010 10:17 AM In reply to
    Another guess: Maybe you render out at a too high compression to a too slow disk? If you render uncompressed full HD to au unstriped single hdd that could happen... Check media creation settings...
  • Sun, Dec 19 2010 7:02 PM In reply to
    • RADIUS
    • Posts 212
    • Points 2,690
    Thank you, Thomas!
    Yes, video play normally and field dominance is not wrong.
    Here is my  timewarp video effect question
  • Sun, Dec 19 2010 10:13 PM In reply to
    It looks from here that it is a field dominance problem -
    I'm not in front of an Avid at the moment, but try - in timewarp try output as progressive, rather than interlaced, which will give you both fields together, or in BCC effects - de-interlace, try changing the field order.
    Juris
  • Mon, Dec 20 2010 12:24 PM In reply to
    • RADIUS
    • Posts 212
    • Points 2,690
    Hi guys! Now, I think this is really a field dominance problem. MC chooses "DV 25 411 MXF"  for Dv 50i Pal and set " ordered for current format" in options/image. If I select instead "Even (Lower Field First) orderd" timewarp works well, so it seems. Yes
    I will still test to be safer. Thanks again to all
