Latest post Wed, Jan 12 2011 6:46 AM by Bernhard. 31 replies.
Page 1 of 3 (32 items) 1 2 3 Next >
  • Tue, Dec 7 2010 12:03 PM
    "Bus error" in thread "Main Thread", at address 0x0
    Hi there,
    I know I am not the only one with the "Bus error" in thread "Main Thread", at address 0x0....
    But I couldn't find any real help so far in any of the other threads.
    My System: AvidMC 5.0.3.6 with MatroxMini on an OS 10.6.4 (2x2.66GHz QuadCore Intel Xeon with 12 Gb RAM and NVIDIA GeForce GT120)
    I am working on a 1080p/25 Project. We shot with the Sony EX3 in XDCamEX 35.
    First I linked our footage via AMA and I had a lot of problems. Now I transcodes everything into the AvidMediaFiles Folders (same Codec) but I didn't make the trick.
    I am working a lot with multiclips. My Data is stored on an external drive (Lacie Cube) connected via ESata (Lacie PCI Adapter).
    I trashed McState, SiteSettings etc. Made a clean re-install etc...Nothing helped...
    And the "Bus error" in thread "Main Thread", at address 0x0 is not the only Error. I get the "Segmentation fault"  in thread "Main Thread", at address 0x0, an the OUT OF MEMORY, too. And quite often the: exception: std::exception, waht:std::bad_alloc
    On top my Avid crashes everytime I shut it down ( at the end of the shutting down process)
    I is really bad. As my MediaComposer crashes every 30 min at least.
    Has anyone a hint or the same Problems, a workaround? Anything?
    Thanks a lot!
    David
    Avid Mediacomposer 5.5.3. with MacOS 10.7 on a MacPro 2x2.66GHz QuadCore Intel Xeon 12Gb RAM with Matrox Mini [view my complete system specs]
  • Tue, Dec 7 2010 12:08 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: "Bus error" in thread "Main Thread", at address 0x0
    http://community.avid.com/forums/t/91205.aspx
    Tomas
  • Tue, Dec 7 2010 12:43 PM In reply to
    I had the same problems with 5.0.3. befor...
    But I will install the 5.0.3.5 now...
  • Tue, Dec 7 2010 1:38 PM In reply to
    I just downgraded to 5.0.3.5. And I had the bus error again after 20 minutes....
  • Tue, Dec 7 2010 1:46 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Ok , always good to use a version that is known to work before starting doing trouble shooting, you also mentioned a lot of other probs in your first post as for example shutdown errors.
    Is the bus error the only error you are seeing now after installing 5.0.3.5.
    Was it a clean install using Avids uninstaller first.
    Tomas
  • Tue, Dec 7 2010 1:57 PM In reply to
    It was a clean install.
    And the Bus error came back, as did the shutdown error.
    I am still waiting for the segmentation fault and the "exception: std::exception, waht:std::bad_alloc" error to come, but a funny feeling tells me, they will soon show up too...[:'(]
  • Tue, Dec 7 2010 2:06 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    dAVIDgruschka:
    Are your projects stored on your external drive ?
    What errors do you get when closing down ?
    Tomas
  • Tue, Dec 7 2010 2:14 PM In reply to
    As I feared: I just received the "exception: std:exception, what: "Bus error" in thread "SprngBuf Fill thread #4" at address 0x0" Error....
  • Tue, Dec 7 2010 2:21 PM In reply to
    And soon after that I get the "exception: std:exception, what: "Bus error" in thread "SprngBuf Fill thread #4" at address 0x0"
    I can close that error message but seconds afterwards the good old: exception: std::exception, waht:std::bad_alloc pops up...
  • Tue, Dec 7 2010 2:27 PM In reply to
    mjolnarn:
    Yes: My Data is stored on an external drive (Lacie Cube 8Gb) connected via ESata (Lacie PCI Adapter).
    It is a very long Error message. It starts like this:
    @font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
    Process:         AvidMediaComposer [302]
    Path:            /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
    Identifier:      com.avid.mediacomposer
    Version:         5.0.3.5.21200 (5.0.3.5)
    Code Type:       X86 (Native)
    Parent Process:  launchd [129]
    Date/Time:       2010-12-07 15:24:06.583 +0100
    OS Version:      Mac OS X 10.6.4 (10F569)
    Report Version:  6
    Interval Since Last Report:          1507760 sec
    Crashes Since Last Report:           110
    Per-App Interval Since Last Report:  4702 sec
    Per-App Crashes Since Last Report:   4
    Anonymous UUID:                      477A90B2-2F6A-4544-8420-A7D219A354EE
    Exception Type:  EXC_CRASH (SIGABRT)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    Crashed Thread:  55
    Application Specific Information:
    abort() called
    Thread 0:  Dispatch queue: com.apple.main-thread
    0   libSystem.B.dylib                         0x9333e1d2 swtch_pri + 10
    1   libSystem.B.dylib                         0x933b43dd sched_yield + 18
    2   com.avid.AvidCoreThreads                  0x0299a5ad Threads::ThreadControl::QuitAndWaitGuts(Threads::Message*, Threads::ThreadPtr, char*, long long) + 213
    3   com.avid.AvidCoreThreads                  0x0299a7fc Threads::ThreadControl::QuitAndWait(Threads::ThreadPtr, char*, long long) + 86
    4   com.avid.AvidCore                         0x0272e14f Threads::QuitAndWait(Threads::ThreadPtr, char*, long long) + 63
    5   com.avid.AvidCore                         0x02703a91 ChronServices::~ChronServices() + 73
    6   libSystem.B.dylib                         0x9335d1bf __cxa_finalize + 208
    7   libSystem.B.dylib                         0x9335d0d4 exit + 33
    8   com.avid.mediacomposer                    0x0000344a _start + 224
    9   com.avid.mediacomposer                    0x00003369 start + 41
    Thread 1:  Dispatch queue: com.apple.libdispatch-manager
    0   libSystem.B.dylib                         0x93364942 kevent + 10
    1   libSystem.B.dylib                         0x9336505c _dispatch_mgr_invoke + 215
    2   libSystem.B.dylib                         0x93364519 _dispatch_queue_invoke + 163
    3   libSystem.B.dylib                         0x933642be _dispatch_worker_thread2 + 240
    4   libSystem.B.dylib                         0x93363d41 _pthread_wqthread + 390
    5   libSystem.B.dylib                         0x93363b86 start_wqthread + 30
    Thread 2:
    0   libSystem.B.dylib                         0x9333e14e semaphore_timedwait_trap + 10
    1   ...ple.CoreServices.CarbonCore            0x965c015e MPWaitOnSemaphore + 125
    2   com.avid.AvidCoreThreads                  0x0299dd7b Threads::SemaRepNative::Decrement(char*, long long) + 305
    3   com.avid.AvidCoreThreads                  0x0299d21a Threads::Sema::Decrement(char*, long long) + 42
    4   com.avid.AvidCore                         0x0270c978 MTSemaphoreCoreThreads::Decrement(unsigned long, unsigned long) + 246
    5   com.avid.AvidStorageAPI                   0x06dfe734 StorageAPI::CommandProcessor::Body(StorageAPI::MTThread*) + 54
    6   com.avid.AvidStorageAPI                   0x06e00a22 StorageAPI::MTThread::Run() + 40
    7   com.avid.AvidCoreThreads                  0x029a390e Threads::ThreadImp::StarterFluid(void*) + 272
    8   libSystem.B.dylib                         0x9336b81d _pthread_start + 345
    9   libSystem.B.dylib                         0x9336b6a2 thread_start + 34
  • Tue, Dec 7 2010 3:33 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    dAVIDgruschka:
    Your media should be stored on an external drive, your project files ( = bins ) should not, what happens if you create a new project storing it on your bootdrive ?
    Tomas
  • Tue, Dec 7 2010 3:38 PM In reply to
    I am sorry, I wasn't specific enough. With "my data" I meant of course just my media files. My project is of course on my bootdrive...
  • Tue, Dec 7 2010 3:45 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    And if you unplug that external drive and remove the esata card, testing a small testproject directly stored on your bootdisc , what happens ?
    Tomas
  • Tue, Dec 7 2010 3:48 PM In reply to
    By the way: I just got the:    exception: std::exception, waht:std::bad_alloc - error
    followed by the OUT OF MEMORY message. (at 80%)  Then I usually quit the application which results in the  "Bus error" in thread "Main thread", at address 0x0 Error. (avid finally crashes with this)
    So it wasn't the 5.0.3.6. patch...
  • Tue, Dec 7 2010 3:54 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    dAVIDgruschka:
    That is of minor importance, never troubleshot using a version that is withdrawn by Avid.
    So, how about that internal drive test ?
    Tomas
