Latest post Fri, Dec 24 2010 9:41 PM by MichaelP. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Nov 30 2010 3:55 AM
    • DLpres
    • Joined on Tue, Aug 31 2010
    • Posts 49
    • Points 575
    Capturing 1080p/30
    Is Nitris DX supposed to be able to ingest 1080p/30 via HD-SDI? I couldn't find any literature on it, Avid support says it can, but my experience suggests otherwise. The same 1080p/29.97 signal that looked good on a Panasonic BT-LH1700 brought up nothing in the Symphony, and I got consumer: timeout errors. As soon as I switched the source (and project) to 720p/60, everything was fine.
    Symphony 4.0.5, capturing live (no deck control).
  • Tue, Nov 30 2010 11:25 AM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,258
    • Points 27,890
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: Capturing 1080p/30
    It sounds like you're working with DVCProHD tape. If so I don't believe this technically records a true 29.97. It can record what Panasonic calls 1080/29.97p (over 59.94i) or 720/29.97p (over 59.94p).
    This is technically a 1080i/59.94 or 720p/59.94 HD-SDI signal with pulldown added and can be captured in this frame rate project.
  • Tue, Nov 30 2010 5:27 PM In reply to
    • DLpres
    • Posts 49
    • Points 575
    Hi Bob,
    Sounds like PsF.  My source is actually true 1080p/29.97 - coming from a Doremi DVI/HD-SDI converter. I also got the same results using a Kona3 as a test signal generator, to make sure it's not a Doremi fluke.
    Reference was set to Internal.
  • Tue, Nov 30 2010 7:21 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 198
    • Points 2,465
    I have successfully captured 29.97psf from HDCAM tape to a Nitris DX so I know that works.
    Sounds like it could be the true 29.97 progressive signal that is giving the problems. Have you tried sending a true 29.97p (non psf) reference signal to the DX?
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.7, 16GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 12TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Fri, Dec 3 2010 1:08 AM In reply to
    • John Moore
    • Joined on Fri, Feb 3 2006
    • Studio City, CA
    • Posts 396
    • Points 4,460
    I don't think Avid can output anything but Psf.  This info came from a chart I saw somewhere.  As far as I know all the Panny and Sony decks end up recording the signals Psf on tape.  I know the Nitris DX hardware only like Psf tri level sync.  Perhaps someone can confirm if Avid can do true progressive over HD-SDI.  I know I can import 23.976 progressive QT movies but the Avid probably turns that into some form of Psf internally, just guessing here.
    Symphony Nitris and Nitris DX 4.x and MCsoft 5.x & 5.5x, MCsoft 6, Artist Color [view my complete system specs]
    John Moore Barking Trout Productions bigfish@pacbell.net
  • Fri, Dec 24 2010 9:41 PM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,415
      Avid Employee
      Moderator: Film
      Moderator: MetaFuze
    Avid only supports PsF over HD-SDI and surprisingly over HDMI as well at thsi time. Allowing for a true P is in the backlog for a future release.
    Michael
    24p.com
