Latest post Sun, Nov 14 2010 11:48 PM by mrzolwik. 24 replies.
Page 1 of 2 (25 items) 1 2 Next >
  • Sat, Nov 13 2010 2:23 PM
    • sam the sham
    • Apple Valley, Ca
    • Posts 924
    • Points 11,790
    Mac OS X update 10.6.5
    10.6.5 is available for download. Anyone installed it? any problems?
    680mb download for me.
    MC 6.0.3.1 thank you very much, FCP X v.10.2.3, MAC Pro, 2 @ Intel Quad-Core Xeon 2.4 GHz,(Westmere),12gb 1066mhz DDR3 ram, ATI RadeonHD 5870 1GB. 3@ 1TB... [view my complete system specs]
  • Sat, Nov 13 2010 2:46 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,345
    Re: Mac OS X update 10.6.5
    You tell us ....   Big Smile
    Tomas
  • Sat, Nov 13 2010 4:38 PM In reply to
    • mrzolwik
    • Joined on Sat, Sep 25 2010
    • Poland
    • Posts 20
    • Points 240
    Finally full support for exFAT! We shall se if avid supports them for media drives, what tranfers etc.
    Macbook Pro Retina, Avid Media Composer 8.3. [view my complete system specs]
  • Sat, Nov 13 2010 4:52 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    mrzolwik:
    Would that mean that we should be able to use external drives for both PC and Mac systems having them formatted as exFat without the need of any extra apps ?
    Tomas
  • Sat, Nov 13 2010 5:18 PM In reply to
    • mrzolwik
    • Poland
    • Posts 20
    • Points 240
    YES! Apple had to start supporting exFAT because of SDXC cards (new SDHC). These cards are in exFAT format.
  • Sat, Nov 13 2010 5:49 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    Nice, have to try a disc
    Tomas
  • Sat, Nov 13 2010 6:17 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    didn´t find the exFat option in the disctools, any clues ?
    Tomas
  • Sat, Nov 13 2010 6:24 PM In reply to
    • mrzolwik
    • Poland
    • Posts 20
    • Points 240
    Will see when update :)
    http://www.macrumors.com/2010/11/11/mac-os-x-10-6-5-notes-exfat-support-airprint-flash-player-vulnerability-fixes/
  • Sat, Nov 13 2010 6:49 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    I am on it, seems to work, a wet dream has come through, using MDV on my PC for organizing  the files and projects that I wish to use on my Mac, or just to consolidate to the disc from the PC and carry it with me using it with the MBP
    Tomas
  • Sat, Nov 13 2010 8:05 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    Seems like this thread became something quite different, sorry Dan, it might be related however.
    I am on 10.6.5 now, MC seems to run well, I have just formatted a Wd My Book Studio 2 TB to exFat and moved my Mediafolders back to it from the MBP after having formatted it, I also copied my project folders to it.
    Then I disconnected it and connected it to my PC station, opened it up and moved the project folders to my PC documents.
    After that, I opened up Avid and went to the " Mac " folder , opened up a project that are only created on my MBP from scratch to finished project, I have it all on my PC now, even the precomputes, all is rendered, I can play it directly.
    So, to summarize, I guess we all want 10.6.5 now
    Tomas
  • Sat, Nov 13 2010 8:25 PM In reply to
    • sam the sham
    • Apple Valley, Ca
    • Posts 924
    • Points 11,790
    "you tell us"
    Being so new to Mac I'm a bit gun shy about this Smile Plus being new new MC that makes me double shy about installing. I guess I could backup everything and try it.
  • Sat, Nov 13 2010 8:47 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    Dan, this isn´t about skill, it is about how brave you are and if you are willing to take the chance to loose a couple of days of work, noone can tell how an uncertified OS will work before having tried it and even if it works for some it might spoil the work for others.
    I was brave this time however, or maybe the word is " dumb enough " the possibilities to maybe use the same drive on both my Mac and my Pc was something I wanted to try.
    It isn´t working perfect however, the screen on my Mac goes black for one or two seconds when opening up and also switching between projects, maybe I will revert back.
    So, now you know, if you want to try it for yourself is up to you to decide.
    Tomas
  • Sat, Nov 13 2010 8:51 PM In reply to
    • Bernhard
    • Joined on Fri, Sep 17 2010
    • Austria
    • Posts 70
    • Points 810
    I updated to 10.6.5 today and after editing for 5 hours I can confirm that there are the same bugs as before (Bus error at Main Thread) which is what I honestly expected (it would be really sad if Avid's core functions would have been programmed in such a bad style so that a minor(!) system update would cause new bugs or application hangs - after all, everything inside an Avid window is pretty far away from "os x" look, feel, guidelines, controls, buttons, fonts, etc).
    I didn't do any exports of timelines or Quicktime related stuff. Because that would be IMHO the most critical part concerning system updates.
    iMac 27", 2.93 GHz i7, 8GB RAM, Mac OS X 10.6.5, Avid MC 5.0.3.5 [view my complete system specs]
  • Sun, Nov 14 2010 7:40 AM In reply to
    • Bernhard
    • Austria
    • Posts 70
    • Points 810
    Here some useful links:
    Apple Release Notes on Mac OS X Update 10.6.5: http://support.apple.com/kb/HT4250
    Security patches in this update should be the same as in Security Update 2010-007.
    Concerning ExFAT used with Harddisks:
    On Microsoft Windows XP SP2 or SP3 you will need the update for the exFAT file system:
    Microsoft Windows XP exFAT Update (Knowledge Base article KB955704)
    I formatted a new external hdd (Western Digital MyBook) with MBR scheme and exFAT partition - works like a charm for data transfer between Mac and PC. :-)
    Much better than FAT or FAT32 - have you ever tried copying a sequence of files (e.g. more than 2000 in a single directory) to an external FAT/FAT32 formatted harddisk connected to a Mac? After 2000-5000 files it becomes really really slow (i.e. less than a file per second)...
    Best regards,
    Bernhard
  • Sun, Nov 14 2010 8:12 AM In reply to
    Just a note: FAT formatted drives - AFAIK - are not supported for use as media drives in Avid. If you want to carry media across platforms, there's still Paragon NTFS-for-Mac and Mediafour MacDrive.
