Latest post Sun, Nov 14 2010 9:24 AM by CliveSmith. 4 replies.
  • Sat, Nov 13 2010 11:38 AM
    • Tompowell
    • Joined on Sat, Nov 13 2010
    • Posts 4
    • Points 60
    Importing a quicktime movie into Avid Xpress Pro
    When I am importing a quicktime movie I often only recieve audio but no image. This isnt consistant so I am not sure why this happens - any advice would be great!
    Tom
  • Sat, Nov 13 2010 5:44 PM In reply to
    Re: Importing a quicktime movie into Avid Xpress Pro
    Is the video black or white after import?  Often times, things like this are related to not having the correct codec installed on your system.  You can check the QT file's codec by looking at the "Inspector" in QT Player.
  • Sun, Nov 14 2010 9:07 AM In reply to
    • Tompowell
    • Posts 4
    • Points 60
    the video is white, how would i go about changing to the correct codec?
    thanks very much
  • Sun, Nov 14 2010 9:23 AM In reply to
    • CliveSmith
    • Joined on Thu, Jun 22 2006
    • South Africa
    • Posts 306
    • Points 3,620
    As Kenton has indicated, a white video usually indicates that the codec is missing, which means that you don't have that codec installed.
    Once you have opened the QT in QT itself and gone to the Movie Inspector, have a look to see what codec is being used (it will be indicated under 'format').  This is the one that you need to install.
    Some codecs are free and some require purchase.
  • Sun, Nov 14 2010 9:24 AM In reply to
    • CliveSmith
    • South Africa
    • Posts 306
    • Points 3,620
    ..and to add to this..  it is not a question of 'switching' to a codec.  If the codec is installed, it will play correctly.
