Latest post Wed, Nov 10 2010 7:56 PM by Neil J. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Nov 10 2010 5:13 PM
    Ending At Cut Dissolve
    This is another strange issue.
    When I use ending at cut the transition must end to that clip.
    BUT if there is another clip after the one I am using the transition the sound takes some frames from it.
    If I move the next clip even one frame then the ending action is good.
    But I think that this is a kind of bug maybe directly connected to the problematic LAST FRAME of video
    appearing, when using the ending at cut dissolve at a video track.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Wed, Nov 10 2010 5:18 PM In reply to
    Re: Ending At Cut Dissolve
    The cure is this but it is definitely wrong.
    I am really ecstatic at how such simple things have never been cured.
    Aren't people using those?
    Desktop PC
  • Wed, Nov 10 2010 6:12 PM In reply to
    • Neil J
    • Posts 576
    • Points 7,390
    A more elegant solution would be to move the incoming audio onto tracks 3 & 4 rather than cut a frame of audio off the outgoing.
    The same issue arises with video dissolves and has always been like that (actually i'm not certain that is the case with v5 i haven't checked but it ceratinly was the case in previous versions).
    I'm not sure i want to get into a debate on this but this involves understanding the function of filler and why it actually makes sense for dissolves to do this.
    BTW George to be ectsatic about something is to be very very happy so i'm not sure that's what you mean!
  • Wed, Nov 10 2010 6:33 PM In reply to
    Yes but it's still wrong.
    It should work as it sounds.
    End.
    Ecstatic is a Greek word.
    It can be used as negative expression also to enhance the feeling you are feeling.
    Desktop PC
  • Wed, Nov 10 2010 6:37 PM In reply to
    Neil J:
    And if this is the case why is behaving like this at the sound also?
    When you set it to end, meaning no other sound beyond this must arise.
    But instead of this, it takes frames from the next clip.
    Meaning it's not acting as an end action but as center action.
    Desktop PC
  • Wed, Nov 10 2010 7:08 PM In reply to
    • Neil J
    • Posts 576
    • Points 7,390
    sverkalo:
    End.
    I agree it's not as it appears but the argument is that it needs to fade/dissolve into "something"in other words silence or as it is also called - filler. This has been debated long and hard before and i fall in favour of the way it is so won't go there again. Sorry.
    I know ecstatic is a Greek word but in English ( the language we are using ...) it doesn't have any negative connotation in modern usage. So to use it in english as you have can only mean you are verrrry happppppy!!!!Big Smile
    Which of course i hope you are !
  • Wed, Nov 10 2010 7:12 PM In reply to
    I use the English language with a Greek attitude some times.
    The same way I would like MC to do in relation with any other simple NLE.
    Some old bugs/glitches/uses must come to an end.
    This is how MC will progress for anyone at the simple things also.
    Then I will be happy Neil.
    Desktop PC
  • Wed, Nov 10 2010 7:32 PM In reply to
    • Neil J
    • Posts 576
    • Points 7,390
    sverkalo:
    I noticed that!
    sverkalo:
    Any other simple NLE? Give me one with balls and attitude not simplicity please.
    sverkalo:
    Well i wish you happiness along the way.
    All the best!
  • Wed, Nov 10 2010 7:41 PM In reply to
    Every other NLE in the world when it says end dissolve it means end dissolve.
    Desktop PC
  • Wed, Nov 10 2010 7:56 PM In reply to
    • Neil J
    • Posts 576
    • Points 7,390
    sverkalo:
    Wow that's a lot of NLEs you've got there George!
