Latest post Thu, Feb 9 2012 1:07 AM by jfv. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Oct 25 2010 1:13 AM
    • asherlewis
    • Joined on Mon, Oct 25 2010
    • Los Angeles, CA
    • Posts 8
    • Points 95
    Title Tool: Unable to save this title. DISK_ACCESS_DENIED
    I've been searching the forums but haven't found a solution.
    I'm running MC5.0.3 on a Mac (OS 10.6.4).
    Whenever i try to save a title made through Title Tool it's coming up with an access denial. I've repaired permissions. I've tried to save it to other drives (including a flash drive) I've tried to save it to other bins, with no success.
    Any and all help is appreciated!
    Thank you.
  • Mon, Oct 25 2010 2:51 AM In reply to
    • Twosheds
    • Joined on Wed, Mar 15 2006
    • Melbourne, Australia
    • Posts 87
    • Points 945
    Re: Title Tool: Unable to save this title. DISK_ACCESS_DENIED
    Check your Media Creation settings, I imagine Avid is trying to render the title to a drive that is not a media drive. I run an editshare network based storage, Avid always defaults to a local drive where I have disabled write access so this is a common error message for me. Even if you set the correct media drive in the save dialogue box the media creation settings will tend to override what you have selected.
    Media Composer with Symphony option v8.10.0, MacOSX 10.11.6, Avid DNxIO [view my complete system specs]
  • Mon, Oct 25 2010 3:01 AM In reply to
    • asherlewis
    • Los Angeles, CA
    • Posts 8
    • Points 95
    thank you for your reply!
    i've got everything set in the media creation settings panel to my GRAID (which is my main media drive, which has all the media for this project on it) with no luck.
  • Mon, Oct 25 2010 6:23 AM In reply to
    • Twosheds
    • Posts 87
    • Points 945
    Hmmmmm. Avid writes a temp file in the Avid Users folder. Maybe check the write permissions for that folder. Folder path is Users/shared/AvidMediaComposer/Avid Users/.
  • Mon, Oct 25 2010 8:33 AM In reply to
    • flaps15
    • Joined on Fri, Apr 7 2006
    • Lancaster UK
    • Posts 202
    • Points 2,700
    Hello,
    I have posted about this before and got no resolution. I have had exactly the same problem and in the end resorted to Marquee for my titles. I think there there is another thread running about this, but I suspect it's a bug in the program.
    Dave
    Imac 27 i5, lacie 1TB firewire 800 drive [view my complete system specs]
  • Thu, Jun 9 2011 8:36 PM In reply to
    • JBrock
    • Joined on Sat, May 21 2011
    • Posts 5
    • Points 45
    I'm going through exactly the same thing. Opened up permissions on all pertinent drives, repaired permissions, checked media creation settings, gone into the Avid Users folder to make sure permissions were open there etc.... My take is that disk_access_denied is a bug. I too have resorted to Marquee..... unless anyone else has an idea?
    Avid Media Composer 5.5.2 OSX 10.6.7 Mac 2 x 2.8 GHz Quad-Core Intel Xeon 6GB 800MHz DDR2 FB-DIMM [view my complete system specs]
  • Thu, Jun 9 2011 8:41 PM In reply to
    • JBrock
    • Posts 5
    • Points 45
    bump
  • Thu, Jun 9 2011 9:16 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,525
    • Points 64,130
      Moderator: MCA Mac
    Could you give us the MC version, OSX version and the format of the drive you're attempting to write to?
  • Thu, Jun 9 2011 9:31 PM In reply to
    And anyone else having this same issue on a supported platform, please report in so we can determine whether to escalate.
  • Thu, Jun 9 2011 10:37 PM In reply to
    • JBrock
    • Posts 5
    • Points 45
    Be glad to. I'll put this in my profile for future reference:
    OSX 10.6.7
    All media drives are formatted Mac OS Extended (Journaled)
    I have
    2 - 1TB internal
    1 - 250GB internal
    One external Firewire800 drive for temp overflow only when needed
    Thanks so much!
    Jonathan
  • Fri, Jun 10 2011 3:19 PM In reply to
    • flaps15
    • Lancaster UK
    • Posts 202
    • Points 2,700
    I Can report that I am still having this problem. Running version 5.0  (cant recall the exact version , am at work)
    with OS 10.6.7.
    Dave
  • Thu, Feb 9 2012 1:07 AM In reply to
    • jfv
    • Joined on Thu, Sep 30 2010
    • Posts 25
    • Points 275
    I experience the same problem on my system :
    Avid Media Composer 5.5.3 (no Mojo or Adrenaline), educational version
    running on A Mac Book Pro 17" with 10.6.8 (Snow Leopard), with OS language set to "French"
    computer equipped with 3.06 GHz Intel Core 2 Duo
    4 Go 1067 MHz DDR3 ram
    logged in as "administrator" on the computer (no other profile exists on this computer)
    Only workaround so far is using Marquee.
    Thanks !
    Avid Symphony 6.0.3.2 Mac Book Pro 17" 3.06 Ghz Intel Core 2 Duo 8 GB RAM 1067 MHz DDR3 [view my complete system specs]
