Latest post Thu, Nov 4 2010 1:00 AM by noodleinsoup. 3 replies.
  • Sun, Oct 24 2010 11:27 PM
    Avid Media Composer 5.03 crashes when Matrox MX02 Mini is enabled on playback
    Hi All,
    I am running a clean 5.03 system on a Mac Pro with 8 gigs of ram.
    OSX 10.6.4
    Sequence 1080 59.94i at DNX145. Sequence is complex but very cleanly build and I placed a submaster on the top and rendered all.
    I have a Matrox MX02 mini hooked up correctly with the correct 1.92 matrox driver for Avid Users.
    I can play DV25 footage from the cutting copy ref cut fine.
    I try to play the sequence and I crash to "bus error in the main thread at address 0x0"
    I disable the device from within Avid and just select IEEE1394 and I can play no problem.
    Enable it and I crash every time.  There is not other errors and I can scrub through and actually do my colour grade as long as I don't hit play with the device enabled.
    Has anyone heard of such an issue, any suggestions are welcome.
    Jeff
  • Sun, Oct 24 2010 11:59 PM In reply to
    Re: Avid Media Composer 5.03 crashes when Matrox MX02 Mini is enabled on playback
    Jeff:
    When this crash occurs, do you get the window that allows you to create a report? If so, please do that and if you can, in addition, go to the console window in the tools menu and report any recent error you find there.
  • Wed, Nov 3 2010 1:07 PM In reply to
    Have you tried deleting the .pmr and .mdb files from avidmediafiles bin? It usually helps when my projects begin to work in weird ways. I close avid, delete the files and re-open avid.
  • Thu, Nov 4 2010 1:00 AM In reply to
    Open the colour space settings in the format tab of the project window (RGB or YCbCr ) toggle it to what you didn't have before and try again. Not in front of my system now - I use an MX02 box on an (unsupported) 24p project - the wrong colour space setting will crash my system with the ever popular bus error in main thread etc.
