Latest post Wed, Oct 6 2010 11:07 AM by erik. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Sep 30 2010 1:45 PM
    • erik
    • Joined on Tue, Aug 10 2010
    • copenhagen
    • Posts 15
    • Points 205
    help with importing mpeg 4
    hello
    i am somewhat new to avid.
    shooting a film in denmark for a sustainability film festival contest
    i'm wondering what settings i should specify when i create a new project?  we shot on a canon hf s20 and converted the mts files into mpeg-4 aac files with "miro audio converter"
    i can see from that we need 1920 x 1080 but how do i know what format (i randomly picked 1080p/24).
    imported clips rather than linking them as couldn't figure that out.
    so basically wondering what settings i need for the project -- maybe other settings somewhere else (bin settings or import settings) -- and also some help exporting.
    thanks in advance, you're awesome!
    macbook pro: OS X 10.6.3 avid medica composer 5 Canon hfs 20 camera [view my complete system specs]
    Filed under: , , ,
  • Thu, Sep 30 2010 4:13 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,745
    Re: help with importing mpeg 4
    You are talking about frame rate (23.98, 24, 25, 29.97, 30, 59.94i) since you've settled on frame size (1920 x 1080) already. There are two things to consider. What frame rate are you supposed to deliver and what frame rate did you shoot at?
    Usually, you set the project up for the frame rate you need to deliver. Let's say 23.98 just for fun. Then you import or link to your clips. If they are anything other than 23.98, when you cut them into a timeline, Avid will apply a motion effect to adjust them to 23.98.
    Does this answer the question?
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Thu, Sep 30 2010 6:51 PM In reply to
    • erik
    • copenhagen
    • Posts 15
    • Points 205
    ok great thanks
    the requirements for the film contest are:
    Video format 1: FLV - H.264
    Størrelse: Max width - 640 x 360 pixels
    sound: ACC
    Max file size: 67 Mb
    OR Video format 2: AVI or Quicktime file
    Original film in full resolution
    Max file size: 2 Gb
    so any recomendation for format, raster, resolution when creating new project?
    any then for exporting?
    thanks again!
  • Fri, Oct 1 2010 4:51 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,745
    Since it is just a small frame size with no frame rate requirements, create your project at whatever your source files are. In other words, if you shot 23.98 1920 x1080, make that the project, cut your sequence, then export to Sorenson and compress to the delivery specs above.
    Burbank, Ca
    www.alphadogs.tv
  • Mon, Oct 4 2010 3:51 PM In reply to
    • erik
    • copenhagen
    • Posts 15
    • Points 205
    ok cool, thanks
    so having a lot of problems with the clips still (frames skip and looks pixallated).  they seem to do better if i import them rather than link to files, but still not that great even when imported directly to the bins.  and they look awful when i export to quicktime video (skipping frames).
    have been shooting with recording mode FXP, which is 17Mps. fram rate 60i, and 1920x1080
    the avid project type i specified was product type 1080p/24 with raster dimension 1920x1080 and YCbCr 709 and aspect ratio 16:9
    should i be changing some settings or exporting with particular settings?
    thanks again
  • Mon, Oct 4 2010 4:08 PM In reply to
    erik:
    erik:
    So, you shot 60i and are cutting 24p?
    Try creating a 1080/5994 project and see what that does for you?
  • Mon, Oct 4 2010 4:30 PM In reply to
    erik:
    There's some good information about how screaming fast your system has to be for good AMA performance can be found at this link:
    http://avid.force.com/pkb/LegacySearch?DocId=365919&Hilite=feature+performance
    ciao,
    Carl
    Media Composer 2019.8 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Mon, Oct 4 2010 4:42 PM In reply to
    • erik
    • copenhagen
    • Posts 15
    • Points 205
    ah ok, thanks
    i thought a brand new macbook pro 15" would handle avid, but i guess not (dont see it listed on the link you sent)
    any way i can make this work?
  • Mon, Oct 4 2010 4:43 PM In reply to
    • erik
    • copenhagen
    • Posts 15
    • Points 205
    thanks
    tried a new project, but same problem
  • Wed, Oct 6 2010 11:07 AM In reply to
    • erik
    • copenhagen
    • Posts 15
    • Points 205
    hey last question,
    my project settings are: 1080p/24; 16:9; RGB 709; 1920x1080
    so in the export settings, does this seem ok?:
    width height: 1280 x 720
    compression: H.264
    Key frame rate: 24
