Latest post Tue, Oct 5 2010 8:19 AM by mjolnarn. 12 replies.
Page 1 of 1 (13 items)
  • Thu, Sep 30 2010 8:16 AM
    HDV Digital Cut 101
    Hello,
    I have an HDV project that I'm trying to print to tape via SonyZ1 camcorder.here's what I did:
    1. DigiCut - Clicked on the red arrow, it gives me this format notice. I clicked and followed the the direction, transcoded, but still giving me the same message.
    2. I also tried output/export to device/HDV. It would export the .m2t file (but to the wrong folder). Recorder will start rolling but nothing but blue screen on the whole duration.
    [Project: HDV 1080i; Sources: mixed HDV&DV, mov, jpeg, mp3]
    Ok, here's a little confession. I've never tried it ever since. Back on the DV days, I simply do it manually (press record then play). Now, we're just exporting edit master files.
    Please guide me through the basics, teh proper way of exporting to tape.
    Thanks!
    Ervz Tia | Video Productions
  • Thu, Sep 30 2010 4:18 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,995
    • Points 37,770
    Re: HDV Digital Cut 101
    I can't see in your picture, but I assume you are trying to go out over firewire. If this is the case, you need to have an HDV encoded stream. We don't work via firewire, so I a may be wrong on this but I believe Avid can only output an HDV stream over firewire if it has been converted to one solid MPEG2 Long GOP stream. That would require a mixdown to build it.
    Long GOP (Group Of Pictures) is your enemy here. Think of it as encoding a DVD, you are essentially doing the same thing. There has to be one solid file with the proper keyframes in the proper place all the way through.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Fri, Oct 1 2010 2:41 AM In reply to
    Yes. I'm going out via firewire to a sony Z1 camcorder.
    TCurren:
    I think I did that already (#2)
  • Fri, Oct 1 2010 2:43 AM In reply to
    UPdate: I did a video mixdown, replaced all vide tracks with the mixdwn clip - no success.
  • Fri, Oct 1 2010 3:05 AM In reply to
    Did you try to trasncode the sequence to HDV prior to make the m2t export?
    Try and tell us...
    Sincerely.
    * Media Composer 2019.6 * Interplay | Production 3.8.1 * Media Central 2.10.5 * iNews 2017.2 * Interplay MAM 5.9
  • Mon, Oct 4 2010 11:26 AM In reply to
    Sorry, I think I need a step-by-step here. I just want to record my sequence to an HDV tape via Sony Z1.
    Here are some questions to sum my concern:
    1. Is DigitalCut suitable for DV & HDV? Why is it only showing DVCPRO output?
    2. What is 'Export to Device/HDV' for? How is it different from DigitalCut?
    3. What's the proper settings - format, raster, mixdown?
    diegovillalba:
    Thanks. I did trancode to DNxHD-TR 145 - its the only reslution available on HDV raster setting. Still no good - Blank/blue screen record and still getting the notifications.
  • Mon, Oct 4 2010 11:54 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    tikboy:
    The error message seems to be correct, you are telling that you have made a mixdown to thin raster, that is 1440 x 1080 but I am seeing 1920 written into your error meaasge, you might switch project settings to thin raster.
    Tomas
  • Tue, Oct 5 2010 2:02 AM In reply to
    Thanks.
    wow, it's hard to show but I've been trying those combinations. I just need a step-by-step.
    Here's one combination (screengrab)
  • Tue, Oct 5 2010 2:13 AM In reply to
    Here's my scene number 2:
  • Tue, Oct 5 2010 3:18 AM In reply to
    Scene 3: Output/ExportToDevice/HDV
    1. Created new m2t file but mysteriously saves it to a diferent location from where you pointed it to.
    2. Process stops - get's error messages "cannot find stream..."
    3. So I simply restarted the process, located the m2t file created (stray location), proceeded...
    4. Avid shows it's working, recorder rolls but only blue screen the whole time
  • Tue, Oct 5 2010 4:38 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
     you still have DVCPro HD as output
    Tomas
  • Tue, Oct 5 2010 8:10 AM In reply to
    Thanks everyone! I finally got the right formula. Very ironic that it's not by DigitalCut at all.
    Raster: Standard + Output/ExportToDevice/HDV
  • Tue, Oct 5 2010 8:19 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Yes
    Tomas
