Latest post Tue, Sep 14 2010 4:38 AM by capt slo-mo. 3 replies.
  • Thu, Sep 9 2010 10:03 PM
    • capt slo-mo
    • Joined on Wed, Dec 14 2005
    • Mooresville, NC
    • Posts 86
    • Points 985
    Decomposing/Consolidating XdCamEX Sequences
    I'm having some serious issues trying to create a workflow to send the media from an XDCamEX sequence off to an external drive, so that I can take the project to a physically separate AVID system.
    The sequence contains material from an EX3 camera on SxS cards, and music from a DVD collection.  In both cases, I originally copied the files to folders on my system drive desktop.  For the EX3 material, I used Sony Clipbrowser and the "export mxf for NLE" option to create the files on the C: drive on my desktop.  For the music, I just did a drag and drop from the DVD into source folder on the C: drive.
    Then in AVID, I imported the media from both folders into the project and edited the sequence.  Now I've got two problems:
    1.  If I try to decompose and batch import the new clip media to the external drive, MC will only reference the files in the original folder on the C: drive...not the imported clips on the AVID editing drives.  This works, but:  this also means I have to maintain double media folders, which would be impractical for a very large upcoming project.  Is there a workaround for this?  Did I make a workflow mistake in the beginning?
    2.  I got the bright idea to do a "consolidate" to the external drive...which makes more sense on paper.  However; when I began the consolidation, I immediately got an error pop-up which said:  "Range specified for Dup is outside range of component."  Not sure what that means, and couldn't find any reference to it in AVID Help.  I thought my external drive/USB connection might be too slow, but received the identical error message when trying it with a very fast esata external drive, as well.
    What am I missing in either of the scenarios?  I'm running MC 3.5 on a Windows XP Pro platform.
    Chipset: X79SABR-A2 - Intel X79-GigabitLAN-SATA III 6.0Gbps--1394a-(9) USB 2.0-(6) USB 3.0- eSATA III CPU: BX80619i73930K - Intel Core i7-3930K 6 Core... [view my complete system specs]
    HDV is not a disease.
  • Mon, Sep 13 2010 5:30 AM In reply to
    • capt slo-mo
    • Mooresville, NC
    • Posts 86
    • Points 985
    Re: Decomposing/Consolidating XdCamEX Sequences
    OK, still having issues.
    1.  The decompose function, while working, still insists on batch importing only from the original folder on my system drive holding the "export mxf for NLE" material I sent out of Clip Browser direct from the SxS card.  Even when I moved that file and its contents off to an external drive, AVID kept insisting it wanted to batch import from the system drive, even though the media for the sequence I wanted to decompose was on the edit drives.
    2.  Still can't consolidate without getting the "Range specified for Dup is outside range of component" error message.  I can consolidate a DV sequence and an HDV 1080i sequence without an issue.  Tried creating a new project and importing the sequence for consolidation...same error.  My buddy FTP'd me some of his EX-3 video in a sequence.  It won't consolidate without the error message either.
    What is that error trying to tell me to do?  Is this a problem with MC 3.5?  Is there a fix?  My friend was able to successfully consolidate that same sequence he sent me on his Mac AVID 5.0.
  • Mon, Sep 13 2010 7:39 AM In reply to
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Tue, Sep 14 2010 4:38 AM In reply to
    • capt slo-mo
    • Mooresville, NC
    • Posts 86
    • Points 985
    Hans:  Thanks for the link.  It was a bit odd trying to match up my PC-based Clip Browser functions with the Mac-based tutorial video provided...and in the end, following what was shown on the video appeared to be a direct contradiction of the printed instructions on the White Page information sheet.
    Specifically, that the AAF files cannot go in the MediaFiles folder, but should go on a remote desktop folder to be imported later, while the SxS media goes directly to the MediaFiles folder.  If you do the workflow off the White Page instructions, you get an error when trying to import the AAF files into the AVID project.
    If, instead, you follow the links as shown on the demo video, and send the AAF exports to the Mediafiles folder on the AVID edit drive, and point the SxS media to the desktop instead, then import those files into AVID, it works as directed.  Although, it gives you both a clip and a sequence for every clip, which is annoying.
    I'm hoping this is something that vanishes in MC 5, if I ever get there.
    But, by bringing in the mxf files and the AAF exports as shown in the tutorial, but not the printed instructions, one gets EX-3 material into the AVID which can then be easily consolidated without the error messages.
    So while confused, I'm now much better off than before, project wise.
