Latest post Mon, Aug 30 2010 11:36 PM by Abeyta. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Aug 27 2010 8:58 PM
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    BCC6 and video level change
    Whenever I use a BCC6 effect (like lens flare for example) over a video layer I am getting a very minor but still noticeable shift in video level when getting in and out of the effect. The decrease in level easily seen on a scope. Anybody else notice this?
    Derrick
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.9, 32GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 24TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Fri, Aug 27 2010 9:04 PM In reply to
    Re: BCC6 and video level change
    I think that by default, BCC clips the image to 16-235.
    If you open the General Controls of any BCC effect, you'll find a "Safe Levels" option, turned on by default. See if it helps to turn that off.
  • Fri, Aug 27 2010 11:29 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    Thanks for the reply Job. Yeah, I tried the safe levels thinking that might be it but it still has the shift. My Project is SD 29.97 2:1 compression.
    I'm on a Mac, is it working on the PC side ok?
    Phoenix, Arizona
  • Mon, Aug 30 2010 5:28 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    I reloaded the older BCC 5 AVX and there is no shift in black levels on that version . For some reason BCC 6 is not working correctly on my system. Can anyone else verify this?
    To test, cut in 1 second of color bars, use add edit to divide the clip in half. Add BCC 6 effect (DVE or Lens Flare) to one side of the edit. Is there a minor level drop on the BCC 6 clip?
    Phoenix, Arizona
  • Mon, Aug 30 2010 5:36 PM In reply to
    • ozbum
    • Posts 114
    • Points 1,500
    I am having the same issue. I did the recommended test & the level drop is obvious.
    Running MC 5.0.1
    Media Composer 7.0.3 Mountain Lion 10.8.4 Model Name: iMac Model Identifier: iMac12,2 Processor Name: Intel Core i7 Processor Speed: 3.4... [view my complete system specs]
  • Mon, Aug 30 2010 11:36 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    Thanks for replying. So it's happening on Media Composer too? Can anybody else confirm this issue?
    Phoenix, Arizona
