Latest post Sat, Dec 7 2013 10:02 PM by Andrew. 32 replies.
Page 3 of 3 (33 items) < Previous 1 2 3
  • Fri, Jan 14 2011 9:18 PM In reply to
    • Andy_DV
    • Joined on Fri, Jun 11 2010
    • Posts 10
    • Points 150
    Re: Nudge, Nudge, ...
    If I have both red/yellow enabled with the smart tool, nudging does not work to the right.
    If ONLY red or yellow is enabled, nudge works! Appears (for me) to be a limitation of the smart tool - if both overwrite and segment tools are enabled and a clip is selected, Avid does not know how to handle the moving clip, so it does nothing.
    One would hope the nudge key commands obeyed whatever tool was enabled when the clip was highlighted, but no. Hovering over the clip with a particular arrow does not help this.
    Personally, I'm disabling segment tool in the smart tool as I rarely use it, while I overwrite/nudge all day long.
  • Sat, Jan 15 2011 4:57 PM In reply to
    • Joe M
    • Joined on Sat, Sep 9 2006
    • Southwestern part of US
    • Posts 952
    • Points 12,715
    Andy... What version of MC are you using (including patches)?
    WinXP,ASUS W6T6 WS Rev.,Intel i7 3.2Ghz8X32,6G Corsair DDR3(low lat.),Quatro FX 3800(190.38),Adaptec 5405 RAID 0 SAS-2 Stripes 2x15K RPM Fujitsu 300G ea... [view my complete system specs]
  • Sat, Dec 7 2013 10:02 PM In reply to
    • Andrew
    • Joined on Wed, Jan 25 2012
    • Texas
    • Posts 18
    • Points 210
    I know this thread is old but I just ran into this problem as well. I am working on MC 7.0.2 & can confirm that if both The Red & Yellow arrows are turned on (even if you select the clip near the top - indicating red) you can not trim to the right. Only when the Red arrow alone is active can you trim to the right.
    27" iMac 3.4 Intel Core i7 (mid 2011 12,2) Media Composer 7.0.3 Pro Tools 1 After Effects CS6 Photoshop CS6 Lightroom 5 [view my complete system specs]
