Latest post Tue, Sep 7 2010 5:21 AM by luca.mg. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Jul 26 2010 9:38 PM
    Error starting up Media composer 5 trial
     Hello everyone, I get this error while loading my media composer5 trial:
    "Exception: Can't create a directory, as one of the folders in the path below has insufficient permissions., path:Avid Projects\"
    Does anyone know what to do???
    Thanks in advance
  • Mon, Jul 26 2010 10:41 PM In reply to
    Re: Error starting up Media composer 5 trial
    You don't have sufficient privileges on your: C: drive.  What "exact" version of Windows are you running?  Are you logged in as the Administrator, or an account that has Administrator rights?
    (wwld)
  • Mon, Jul 26 2010 10:42 PM In reply to
    It sounds like a permissions issue, which might be fixable, but we need to know what operating system you're using.  It'd also help to know your processor type & speed, amount of RAM, video card, and what version of Quicktime is installed on the system.
    ciao,
    Carl
  • Fri, Sep 3 2010 5:09 PM In reply to
    Hi Carl,
    The same error is showing when I try to get started with Avid MC5.  I've checked an I am logged in as Administrator.
    I don't have access to email where I'm lodging and I'm desperately trying to get Avid at home to finish editing an MA project. So..  if I try manage to find the answers to the what system?, etc (bearing in mind I am not pc techie literate at all) please would you help if you can?
    Shan
  • Fri, Sep 3 2010 6:16 PM In reply to
    Again, what OS?  If it's any variety that includes "Home" in the name (which Avid does not support), this can be the cause of the permissions issue.
    (wwld)
  • Mon, Sep 6 2010 6:09 PM In reply to
    Thanks for the reply.  Yes, I misread what I needed and have Windows Vista Home Premium.  However, interestingly, by altering the permissions it looks like I can now access the programme.  Not sure how stable it will be though but this is what worked taken from some other kind person's advice:
    Right click on the folder that doesn't have proper permissions (in this case Avid Media Composer 5),
    select Properties, Security tab - click Add, In 'Select Users' window type Everyone
    then click 'Check Names', click OK,
    Go back to the folder, Properties, select 'Everyone', check 'Full Control' so it has a tick by it in the Permissions window, click OK.
    Not sure whether to try get an upgrade to Win 7 Professional - only prob being am not pc literate and will have to run a clean install - I think - which makes me wonder how an upgrade will work if the base system has then been uninstalled.  Grr. why am I poor and running out of time..
  • Tue, Sep 7 2010 5:21 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,669
    • Points 66,515
    Shan, You did the right procedure to fix the permission issue, I didn't know it is possible in Vista home; now if it works leave it alone and edit.
    Symphony 20.04, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
