Latest post Sat, May 7 2011 12:23 AM by Bishop_Alex. 27 replies.
Page 1 of 2 (28 items) 1 2 Next >
  • Tue, Jun 29 2010 2:37 AM
    • scoutmedia
    • Joined on Sat, Apr 24 2010
    • Posts 3
    • Points 100
    5.0 Upgrade and AudioSuite won't launch DAE error -9169
    Anyone having problems getting Audio Suite / DAE to launch.. ?
     DAE error -9169
    Mark
  • Wed, Jun 30 2010 10:23 AM In reply to
    • Florian
    • Germany
    • Posts 332
    • Points 4,140
    Re: 5.0 Upgrade and AudioSuite won't launch DAE error -9169
    Yes, it´s the same here
    After launching the suite the error message showed up once
    and when the suite started there are no effects in the palette
    I wonder if the patch will solve this?
    6TB LaCie 2big, QT X, QT 7.6.6, Squeeze 8.5, BCC 8.2 MacBook Pro Retina 15", 2.5Ghz QuadCore i7, OS Mojave 10.14, Avid MC 2018.5, 16GB Ram, AMD Radeon... [view my complete system specs]
  • Wed, Jun 30 2010 11:49 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,345
    Have you two made clean installs of MC 5 ?
    Tomas
  • Wed, Jun 30 2010 1:00 PM In reply to
    • Florian
    • Germany
    • Posts 332
    • Points 4,140
    On a brand new mac pro.
    Maybe it´s got something to do with the Trial Version wich i used before blasting the dongle.
  • Tue, Jul 6 2010 6:46 AM In reply to
    • tchoupiboss
    • Joined on Tue, Jul 6 2010
    • Paris, FRANCE
    • Posts 23
    • Points 305
    Get the same error message ! On a fresh new Mac OS 10.6.3 system... 2 x 2.8 Quad-Core Xeon and 6 GB memory.
    Did autorisation repairs but didn't fix It.
    MacPro Late 2013 - 3,5 GHz 6-Core Intel Xeon E5 - 32Gb memory - AMD FirePro D700 6144 Mo - MC 2018.12.1 - Working fine :-) [view my complete system specs]
  • Tue, Jul 6 2010 4:06 PM In reply to
    same here and i found about it while trying to export with applied effects. The sequence will not export unless i render and I can't render if the DAE will not open.
    I can't get an answer from Avid on this- but it appears to be universal. What's the deal with this?
  • Tue, Jul 6 2010 9:56 PM In reply to
    This happens every time you launch?
    I have had the DAE not connect a couple of times, but rebooting the system cleared the problem, and I was able to launch the Audio Suite again.
  • Wed, Jul 7 2010 12:10 AM In reply to
    • Bokes
    • Posts 219
    • Points 3,205
    everytime here. I noticed I have two digidesign icons in my system pref: Digidesign Mbox 2 and Digidesign Mbox 2 pro... is this correct? I found a digidesign bundle in my Avid folder but I can't get it to open. Do I need to instal that bundle and if so how?
    FWIW- I had DAE under v4.0.5 without any of these issues.
  • Wed, Jul 7 2010 7:48 AM In reply to
    • tchoupiboss
    • Paris, FRANCE
    • Posts 23
    • Points 305
    Here DAE lauches but when I try to apply an effect MC crashes.
  • Wed, Jul 7 2010 5:32 PM In reply to
    Out of curiosity, what do you guys have in your Library > Application Support > Digidesign folder?
    What is in the Plug-Ins (Unused) folder?
  • Wed, Jul 7 2010 6:57 PM In reply to
    • tchoupiboss
    • Paris, FRANCE
    • Posts 23
    • Points 305
    Empty for me !
  • Wed, Jul 7 2010 7:52 PM In reply to
    I think something went wrong on the install.  Mine looks like the picture below.
    I'd suggest running the Avid Uninstallers, then searching for and deleting any Avid or Digidesign folders left on your system.  (You should be able to leave the Shared folder within the User folder, where your Avid use and projects are stored, but back them up first to be safe.)
    Then reinstall, and check to make sure you have the Digidesign plugins installed.
  • Thu, Jul 8 2010 7:55 AM In reply to
    • tchoupiboss
    • Paris, FRANCE
    • Posts 23
    • Points 305
    Sorry, I was wrong. I didn't look on the right place.
    Here are my Digidesign folders... and the DAE error.
    But I think I've found out why !!!
    It seems crashing when you don't have a sequence in the Timeline window.
    It happend when I was trying to see the new effects provided with MC5... But the Timeline was empty.
    Otherwise AudioSuite is working.
  • Thu, Jul 8 2010 4:20 PM In reply to
    tchoupiboss:
    I hand't noticed that, but it might make sense, since it is looking to apply to a specific track in your sequence.  It shouldn't crash the system, though.
    I'll do some testing and note it to engineering if I can confirm.
  • Fri, Aug 6 2010 11:30 PM In reply to
    • Beckie
    • Joined on Fri, Aug 6 2010
    • Athens, Ohio
    • Posts 3
    • Points 35
    I am not able to open AudioSuite under the 9169 error code.  From this post I gather to:
    1) Restart the computer
    2) Make sure you have clips in the timeline
    If neither of those options work, I should uninstall Avid, hunt down any Digi or Avid files left over, delete them, then reinstall.  Has anyone done this and found the leftover Digi files and then was successful in getting AudioSuite to open?
    Please let me know, I would rather hunt down the corrupted files from a previous version of Avid then go through the entire uninstall/reinstall process, just for it maybe to work.  But I do need my reverb.
    MacBook Pro OSX 10.6.4 Avid v5 Processor: Intel Core 2 Duo Speed: 2.66 GHz Memory: 4 GB Video Card: NVIDIA GeForce 9400M, GPU, PCI and it... [view my complete system specs]
