Latest post Sun, Jun 13 2010 6:50 PM by spreis2002. 3 replies.
  • Sun, Jun 13 2010 11:09 AM
    • spreis2002
    • Joined on Wed, Oct 22 2008
    • UNITED ARAB EMIRATES
    • Posts 26
    • Points 385
    Fly edit with Multicamera
    Dear all avid users..
    When I choose any sorce of my videos on viewer monitor the play is stoping and I should play it again from space bar, and again when i choose another sorce it also stoping, So, is there any way to make my edit on multicamera way as fly edit with out stoping?? Can somebody help me to fix my problem or there is it normal with avid media composer 3.0 .
    Thanks very much;
    Saad.
    system Brand: Hewlett-Packard System Model: HP xw8600 Operating System:Windows Vista Business (6.0.Build 6002) Avid Media Composer Software v5.5.3 ... [view my complete system specs]
    Avid Media Composer Software v3.1.3
    Ram: 8.00GB
    Processor: Intel(R) Xeon(R) CPU X5450@3.00GHz (8CPUs),~3.0GHz
    NVIDIA Quadro FX3700
    DAC Type Integrated RAMDAC
    Approx.Total Memory 1907MB
    Display Mode 1280x1024(32bit)(60Hz)
    Driver: nvd3dum.dll,nvwgf2um.dll
    version 7.15.0011.8267(English)
  • Sun, Jun 13 2010 4:44 PM In reply to
    • pointer
    • Joined on Fri, Jun 20 2008
    • Greece
    • Posts 11
    • Points 125
    Re: Fly edit with Multicamera
    You can map multicam buttons on the keyboard. I map M1,M2,M3,M4 at F5,F6,F7,F8 respectively.
    You can do it by opening Command Palette and doing a "Button to Button" Reassignment. The buttons are at the Mcam tab.
    After that you can hit play and change cams on the fly hitting F5,F6,etc and you can see the result in the composer window.
    Asus P4P800 deluxe,P4-3.0 GHz Northwood, 2G Ram, Quadro 4 900 xgl driven by 84.26, dual boot XP sp2 both, MC 2.7.7 and MC 3.0, also a Fujitsu-Siemens... [view my complete system specs]
    ...and what happens if I press this button?...
  • Sun, Jun 13 2010 5:46 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,745
    • Points 61,895
    When you edit in multicam mode, are you seeing the quad or nine display in the source viewer? You should be able to edit the muiticam source clip to the timeline and then backup your timemark to the beginning, start playing in the record monitor and then tap on one of the quad or nine images in the source viewer. As you do, a cut is introduced into your timeline and the particular camera selected. This does not stop playback in the record monitor (although it also doesn't show you the cuts to each camera until you stop playing).
    You can also map camera selection to buttons as suggested.
    Cheers
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Jun 13 2010 6:50 PM In reply to
    • spreis2002
    • Posts 26
    • Points 385
    Thank you very much my friend for your help..
    Ram: 8.00GB
