Latest post Tue, Mar 8 2011 10:19 PM by George Angeludis. 13 replies.
Page 1 of 1 (14 items)
  • Sat, Jun 12 2010 2:44 PM
    • kostas
    • Joined on Sat, Jun 12 2010
    • Posts 9
    • Points 105
    avid media composer export wide?
    hi
    sorry for my english ..
    i take job in dv , and my capture its ok ,.the work is in 16=9
    i finish my montaze and when i go for the export i see only
     16=9 squere pixel ( 1024 x 576 ) and i searche for 16=9 dv widescreen
     but nothing in.
     i have my job and i dont know  how i put itout...
     any ideas for export?  the dv is in 720-576 pal.
     thank you.
  • Sat, Jun 12 2010 5:24 PM In reply to
    • Jayanta
    • Joined on Fri, Jul 6 2007
    • India
    • Posts 1,504
    • Points 16,255
    Re: avid media composer export wide?
    What is your export setting?
    I am not in front of MC now but If I remember correctly there is a 16:9 seettin inside the Fast export Quick Time PAL setting.
    All Sorts of System as I am a freelance Editor [view my complete system specs]
    "Out of mud the lovely Lotus Blooms, Out of Strife something higher vies "
  • Sat, Jun 12 2010 5:47 PM In reply to
    • kostas
    • Posts 9
    • Points 105
    yes i know but is 16=9 square pixel and tell not 720x576 but 1024x576. only that . is not
    writte anyware dv pal 720x576 widescreen ,. you know like if you go in after or premiere i saw that.
     in avid no..
  • Sat, Jun 12 2010 6:53 PM In reply to
    • Jayanta
    • India
    • Posts 1,504
    • Points 16,255
    Use the Avid DV Codec then you wont see the 1024X576.
  • Sat, Jun 12 2010 7:11 PM In reply to
    • kostas
    • Posts 9
    • Points 105
    you mean in quicktime reference export? because i do that and still 1024x576
    but if i go in quicktime movie export i have the custom - format options-
     i search there but....any idea whats happen?
  • Sun, Jun 13 2010 5:57 AM In reply to
    • Jayanta
    • India
    • Posts 1,504
    • Points 16,255
    No I mean Fast export Quick Time amd in the setting check the Avid DV Codec. and Check the button below that says 16:9.
  • Sun, Jun 13 2010 4:43 PM In reply to
    • kostas
    • Posts 9
    • Points 105
    i put my dv and i make capture with premiere and i have the righit thinks ok i mean..
    i put it and in the sony vegas and still ok ,.
    sorry but maybe with avid i do something wrong? i capture my dv in 25i . but i can not
    do anithing in export,. it is the righit setting the 25i for dv? i put it always in 4-3 and all ok
    but in 16-9 it is the righit please?
  • Sun, Jun 13 2010 5:17 PM In reply to
    • pointer
    • Joined on Fri, Jun 20 2008
    • Greece
    • Posts 11
    • Points 125
    That 's probably because you try to export from the bin. Load your sequence at the composer by doubleclicking it, then try to export either (1) from the composer window or (2) from the timeline window.
    1. Rigth click in the composer window and hit export or
    2. Click to activate the timeline, then click File/Export,
    now if you select Quick time reference you can choose Native dimensions as Display Aspect Ratio.
    Translation in Greek(glish):
    Ayto ginetai mallon epeidh prospatheis na kaneis export apo to bin. Fortwse th sequence sto composer window kanontas doubleclick, meta prospathhse na kaneis export eite (1) apo to composer window eite (2) apo thn timeline.
    1.Kane dexi click sto composer window kai pata export h
    2.Pata sthn timeline gia na energopoihthei kai meta phgaine sto menu File kai pata export,
    twra an epilexeis apo ta options Quick time reference mporeis na epilexeis Native dimensions sto Display Aspect Ratio.
    Elpizw na vohthhsaSmile
    Asus P4P800 deluxe,P4-3.0 GHz Northwood, 2G Ram, Quadro 4 900 xgl driven by 84.26, dual boot XP sp2 both, MC 2.7.7 and MC 3.0, also a Fujitsu-Siemens... [view my complete system specs]
    ...and what happens if I press this button?...
    Filed under: ,
  • Sun, Jun 13 2010 5:34 PM In reply to
    • kostas
    • Posts 9
    • Points 105
    mia pou eisai apo ellada den mou ta grafeis se mun i edw na to katalabw kalitera? plz
  • Sun, Jun 13 2010 6:45 PM In reply to
    • kostas
    • Posts 9
    • Points 105
  • Sun, Jun 13 2010 6:46 PM In reply to
    • kostas
    • Posts 9
    • Points 105
  • Sun, Jun 13 2010 8:10 PM In reply to
    I still haven't understood your problem Kostas.
    There is no flag for DV 16:9 inside MC which is normal because there isn't a real
    16:9 DV. Tell me what you need to do exactly.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Tue, Mar 8 2011 5:30 PM In reply to
    • MirON
    • Joined on Sun, Aug 17 2008
    • Ukraine
    • Posts 14
    • Points 165
    Of course there should be. Sony camcorders shoot anamorfic 16:9. Gravefully  I just came across I cant Export 16x9 project (which plays properly) to QT movie - I get 4:3 all the time even with these settings
    avid newscutter xp [view my complete system specs]
  • Tue, Mar 8 2011 10:19 PM In reply to
    I get fine 16:9 ratio clips using the same settings as yours.
    With a small difference.
    Click on the Rec window and then choose export.
    Desktop PC
