Latest post Tue, Jun 1 2010 9:02 PM by earthchild. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Jun 1 2010 5:18 PM
    No dongle error
    I've just installed 4.8.4 on a MacBook running 10.4.11 and am getting a 'No Dongle' error. Dongle Dumper doesn't seem to see the dongle either but my other computer (which used to run xpress and now runs MC) does see the Dongle and lists the Avid version at 5.7. I haven't used the Dongle since about 6 months ago when I upgraded my main system to the node-locked MC but the system ID seems valid (it allowed me to download 4.8.4 onto this other computer). My searches of the forum don't offer any clear solutions (I didn't have the dongle connected during installation for example).
    Any leads are much appreciated!
    Brook
    15" Macbook Pro, 2.4GHZ, 4GB RAM... MC 4.0.5 ... QT 7.6.4 [view my complete system specs]
  • Tue, Jun 1 2010 6:20 PM In reply to
    Re: No dongle error
    earthchild:
    What is "node-locked"?
    Either way, when you upgraded you must upgrade your dongle as well.  RIght now, your dongle is blessed for XpressPro v5.7 (and below).
    earthchild:
    You can download any version you like, but if your dongle is not blessed to run it, you will get the "No Dongle Found" message.
    When you upgraded your system to MC did you choose to "keep your dongle" or "use software activation"?  It kind of sounds like you went SLA, which then makes your dongle obsolete.
    Also, it could be that your OS is too "new" for the version you're trying to run.  I seem to recall some issues way back with certain versions not running (or showing No Dongle Found) when using a mismatched OS version.  I believe that with 5.7 the newest OS you could run would've been 10.4.8.  But I can't find the XpressPro Version Matrix right now to verify.
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: No dongle error
    Hi, it's because 10.4.6 was the last OS you could install with 4.8.4. Anything beyond that broke the dongle drivers.
  • Tue, Jun 1 2010 6:21 PM In reply to
    Re: No dongle error
    BLKDOG:
    10.4.6 was the last OS you could install with 4.8.4. Anything beyond that broke the dongel drivers.
    Bingo.
  • Tue, Jun 1 2010 7:12 PM In reply to
    Re: No dongle error
    Thanks BLKDOG. Are than any versions that will work with 10.4.11 or would I need to buy a full upgrade?
  • Tue, Jun 1 2010 7:30 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: No dongle error
    There were later versions of the software that did work. Here is the Version Matrix so that you can see the pairings. However, since 'Pro is now end of life, upgrades to it are no longer available. You'd have to upgrade to Media Composer.
  • Tue, Jun 1 2010 7:52 PM In reply to
    Re: No dongle error
    While going between the two computers I think I got confused between compatibility for 4.8 and 5.8, I'm downloading 5.8 now and hopefully that'll work.
  • Tue, Jun 1 2010 8:01 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: No dongle error
    The only sticking point there is I believe the upgrade from 4.x to 5.x was a paid one. If so, then your dongle will not be updated for it. However, if, as you say, your dongle reports that it is blasted for 5.x, then you should be fine.
  • Tue, Jun 1 2010 9:02 PM In reply to
    Re: No dongle error
    It worked! Sorry to waste your time on what turned out to be insufficient attention to detail between 4s and 5s.
