Latest post Tue, May 18 2010 1:00 AM by Dom Q. Silverio. 3 replies.
  • Mon, May 17 2010 5:35 PM
    • woolf2323
    • Joined on Mon, May 17 2010
    • Posts 2
    • Points 30
    Importing Sequencially Numbered Files
    Hi all - I'm trying to import a series of .gif images which are numbered in a row - see some of them below - but my MC does not recognize the sequence - just imports the first frame - of course I have turned on the "Autodetect sequencencially numbered files" Button - please help... Thanks - Wolfgang
  • Mon, May 17 2010 10:22 PM In reply to
    Re: Importing Sequencially Numbered Files
    I never tried it with GIF before. Try another format. If not try renaming it to something simpler. The naming scheme might be confusing the auto detect feature.
    MC 2020.6, W10, MSI X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012 Thunderbolt... [view my complete system specs]
  • Mon, May 17 2010 10:44 PM In reply to
    • woolf2323
    • Posts 2
    • Points 30
    Thanks a lot - but I have tried it with .psd, .jpg and .pct - and also renaming the files to a simpler name convention - nothing worked - I have done it in earlier versions of MC - now I'm on 3.5.1 - can this be a bug?
    I have found another solution now - to export a movie from Flash and then import it to AVID - this works.
    But it is still confusing, that sequentially numered file import does not work - did you try out my files?
    Thanks again and best regards
    Wolfgang
  • Tue, May 18 2010 1:00 AM In reply to
    You are correct - renaming it did not fix it. Saving it as Bitmap or TIFF file fixed it.
