Latest post Fri, May 13 2011 9:53 PM by Sylvain P. 9 replies.
Page 1 of 1 (10 items)
  • Wed, May 12 2010 9:03 AM
    • Sef
    • Maarssen, The Netherlands
    • Posts 1,008
    • Points 13,650
    Not possible to add Quick transition
    in my Timeline, I have in V1 an AVI clip that has an effect on it. Above, in track V2 there is a crawling title.
    I want to apply a quick transition between the clips in V1 (and if possible also at the end of the V2 clip.
    I position the cursor between the two clips in V1, have track V1 selected and click on the Quick transition button. The popup appears but the Add button is disabled and the duration is 0 and not editable.
    I'm doing something wrong, I know, but what?
    MC6.0.5, QT version 7.7.3, AvidFX 6.2(64bit), Squeeze Pro 8.5.0.41, AvidDVD 6.4.4 (still in my system, but I don't use it anymore), Boris Continuum... [view my complete system specs]
  • Wed, May 12 2010 9:18 AM In reply to
    Re: Not possible to add Quick transition
    It looks like you've used every frame of the A side clip (can't see the clip name, but it looks like it's an imported AVI) and every frame of the B side clip (Amerika tape 1-1), leaving no handles to make a transition from.
    ciao,
    Carl
  • Wed, May 12 2010 9:24 AM In reply to
    • Sef
    • Posts 1,008
    • Points 13,650
    Yep, it is an imported clip. Handles?
    If it is possible to use the quick transition, how?
    • Posts 11,311
    • Points 232,440
    What Carl said, and a tutorial to explain the concept!
    Regards,
    Douglas
  • Wed, May 12 2010 9:31 AM In reply to
    Sef:
     Handles?
    Handles = unused frames at the beginning or end of a master clip.  If you have a 10 minute master clip, and you use the 8 minutes in the middle of it in your sequence, the unused 1 minute at the top and the unused 1 minute at the end are the handles.
    Sef:
    The quick transition requires handles.  If you want, for example, to make a 20-frame dissolve, you'll need 20 extra frames that are not being used in the sequence.  In your situation, you could go into trim mode, trim the A side back 10 frames, trim the B side forward 10 frames, and that would result in 20 extra frames that you could then make a transition out of.
    Or just watch Douglas' tutorial. :)
    ciao,
    Carl
  • Wed, May 12 2010 10:03 AM In reply to
    • gswilson
    • Joined on Thu, Feb 4 2010
    • Belfast, Ireland - now, Frankfurt am Main, Germany
    • Posts 339
    • Points 4,455
    Sef:
    Handles?
    Same as in Liquid Sef, only there the "Handles" were called Leeway.
    Gerry
    MC 2020.06, Win 10 Pro(1909), Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 1080Ti GPU(Studio Driver 451.77),Samsung 850 Pro... [view my complete system specs]
  • Wed, May 12 2010 10:06 AM In reply to
    • Sef
    • Posts 1,008
    • Points 13,650
    O, Oh. Embarrassed
  • Wed, May 12 2010 10:22 AM In reply to
    • Sef
    • Posts 1,008
    • Points 13,650
    Thanks for the tutorial!
    After some trial and errors, I managed this to do on the timeline by trimmode.
  • Fri, May 6 2011 3:09 AM In reply to
    My quick transistion won't even open....just a "error" or beep sound.
  • Fri, May 13 2011 9:53 PM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,489
    • Points 17,600
    Sef, to be sure, deselect any other tracks and only select the required video track.
    You'll sometime get this issue if it's your audio tracks that doesn't have any available handle left.
    Media Composer 2018.12.2 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
