Latest post Mon, Apr 26 2010 3:44 AM by scalpita. 2 replies.
  • Fri, Apr 16 2010 12:40 AM
    • scalpita
    • Posts 2
    • Points 20
    Problem with Dekocast Transcode
    I have a DeKoCast, and I need to import a clip.
    With DekoCast I find the software Transcode.exe Vers.1.2.0.144, for converter clip file to clip .mxf for DekoCast
    But this software don't work property.
    When i go with "start transcoding", software stop and create an error log.
    This is the error log:
    Transcode version 1.2.0.144
    Creating transcode job #1.
    Creating job item #1.
    Permit task0, item #1 to execute.
    Source file pathname for item #1: C:\Documents and Settings\lscamperle\Desktop\EntrataUscita.mov
    Destination fill file pathname for item #1: C:\Documents and Settings\lscamperle\Desktop\EntrataUscita_IF_v.mxf
    Compression settings for item #1: format = MPEG 4:2:0, bit rate = 15, Mbits/sec, interlaced = 1
    Starting worker thread for item #1.
    Worker thread for item #1, no longer active.
    Result for item #1 -- TWIXT TRANSCODE ERROR (-1): Twixt Load Error
    Cleaning up for item #1.
    Deleting TwixtHelper for item #1.
    Ending worker thread for item #1.
    Someone may help me?
    Thankyou
    Luca Scamperle
    Cinevideostudio
    Milano
    Italy
    Filed under: , , , ,
  • Sat, Apr 24 2010 5:35 AM In reply to
    • stustustu
    • Joined on Wed, Feb 11 2009
    • Melbourne, Australia
    • Posts 17
    • Points 215
    Re: Problem with Dekocast Transcode
    It looks like you are trying to convert a Quicktime .MOV to .MXF?
    A quick guess here but do you have Quicktime installed on the machine you are doing the transcode on?  You'll need to make sure Quicktime is installed so the Avid Transcode utility can access the Quicktime format.
    Hope this helps!  :)
    Stu.
    Filed under: ,
  • Mon, Apr 26 2010 3:44 AM In reply to
    • scalpita
    • Posts 2
    • Points 20
    I have Quicktime 7.6 installed, but transcode application needs Quicktime 7.1.
    I removed quicktime 7.6 and I had install Quicktime 7.1 and Transcode works.
    Thank you
    Ciao
    Luca
