Latest post Wed, Apr 14 2010 2:25 PM by fididonk. 11 replies.
Page 1 of 1 (12 items)
  • Wed, Apr 14 2010 1:09 PM
    • fididonk
    • Joined on Wed, Apr 14 2010
    • Posts 7
    • Points 0
    Animation seems like dv quality
    Hello,
    I'm sorry if my english is not good. I've a problem when importing clip mov (animation) that created from adobe after effect into avid xpress pro. If i look the quality in quick time player before importing file to avid, the clip is good and sharp. But, after importing to avid the clip quality is poor (seems like dv quality, not in animation quality).
    Is the problem came from a graphic card that i use in my pc? I use nvidia gf 7300 gs graphic card, intel core2duo 2,1 ghz processor, 3 gb mem ddr2. I don't have mojo.
    Thank you very much
    Filed under: , ,
  • Wed, Apr 14 2010 1:12 PM In reply to
    Re: Animation seems like dv quality
    1. What resolution are you working in?
    2. What are you viewing the file on?  In other words, are you checking quality on an external monitor or on your computer monitor?
    3. What kind of project are you working in (HD? SD? Frame rate?)?
    4. What version of Xpress Pro are you using?
    ciao,
    Carl
    Media Composer 2020.12 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Wed, Apr 14 2010 1:16 PM In reply to
    Since you say it looks good before importing, check the resolution display quality icon (the TV screen on the left side of the timeline toolbar) and make sure it is showing full green, which is full resolution display - half yellow, half green, or full yellow are low resolution modes.
  • Wed, Apr 14 2010 1:22 PM In reply to
    • fididonk
    • Posts 7
    • Points 0
    thx before carl.
    1. I create the project on after effect in pal d1/dv 720x576 frame rate 25..and export/render after that in animation mov.
    2. I view in computer monitor.
    3. I work in project DV420 720i frame rate 25
    4. Avid xpress pro 5.1.5
    thx for your attention :)
    camoscato:
    ciao,
    Carl
  • Wed, Apr 14 2010 1:29 PM In reply to
    fididonk:
    DV420 is a DV resolution.  Do you have an option to import the file with a better resolution?  1:1 perhaps?
    ciao,
    Carl
  • Wed, Apr 14 2010 1:38 PM In reply to
    • fididonk
    • Posts 7
    • Points 0
    option 1:1 is not appear when create project. How to appear this option?
    camoscato:
    fididonk:
    ciao,
    Carl
  • Wed, Apr 14 2010 1:48 PM In reply to
    • fididonk
    • Posts 7
    • Points 0
    Hi Larry..yes..display resolution have already set in fully green mode..but still not sharp.
  • Wed, Apr 14 2010 1:53 PM In reply to
    fididonk:
    Sorry, I was not clear.  When you imported the file, what resolution did you choose?  In the Import File dialog box there should be a choice of resolutions.
    ciao,
    Carl
  • Wed, Apr 14 2010 2:05 PM In reply to
    • fididonk
    • Posts 7
    • Points 0
    In the import option, i choose..use the source file resolution
    camoscato:
    fididonk:
    ciao,
    Carl
  • Wed, Apr 14 2010 2:12 PM In reply to
    • fididonk
    • Posts 7
    • Points 0
     l look in media creation..and option 1:1 doesn't appear. I always set to dv 25 420
    fididonk:
    camoscato:
    fididonk:
    ciao,
    Carl
  • Wed, Apr 14 2010 2:16 PM In reply to
    fididonk:
    What other choices are available in your Media Creation settings?
    ciao,
    Carl
  • Wed, Apr 14 2010 2:25 PM In reply to
    • fididonk
    • Posts 7
    • Points 0
    These is a list in import tab on media creation:
    1. dv 25 411 omf
    2. dv 25 420 omf
    3. dv 50 omf
    4. dv 15:1s omf
    camoscato:
    fididonk:
    ciao,
    Carl
