Latest post Mon, Apr 12 2010 2:25 PM by George Angeludis. 14 replies.
Page 1 of 1 (15 items)
  • Sun, Apr 11 2010 10:57 AM
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Installing MC 4 on WIN7
    Hi
    I have a full working XP system.
    I am trying to install MC4.05 on a new fresh disk with WIN7 64bit. (I know it is not officially supported yet)
    When I run SETUP I choose to install only MC. I then get list of "Pending" software to install including the sound driver, Sentinal, Mojo 64bit driver and some more.
    But when I hit next I can see that just MC is installed without all other pending programs.
    How can I force SETUP to install all other stuff (including MOJO drivers..)
    MC 2018.4 + MXO2 mini. CPU I7 2600K + 32GB RAM. Nvidia GTX970 driver 388.71. QT.7.7.9 [view my complete system specs]
  • Sun, Apr 11 2010 12:39 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,744
    • Points 61,880
    Re: Installing MC 4 on WIN7
    You'll have to find the individual installers and run them 'as administrator' after you've installed MC 4.0.5 - I've run into the same issue that you describe (although I wouldn't count on MOJO working - but you might as well give it a try).
    So what I've been doing is running MC 4.0.5 installer, then I run the Sentinal installer as administrator, followed by the Digidesign installer 'as administrator' (in this case I downloaded the 8.0.3 digidesign installer but it probably doesn't matter if you just use the 8.0.1 version that ships with MC 4.0.5)
    I'm guessing that you can run the other installers (such as MOJO) as well. You'll find them in a subfolder of the MC installation...
    Good luck - and as a side, you'd really benefit from taking a ghost of your system BEFORE installing MC so that if/when something goes horribly wrong you can quickly roll back to the pre-installed state (I use Acronis TrueImage for this).
    Cheers
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Apr 11 2010 1:54 PM In reply to
    • sad
    • Joined on Fri, Jul 3 2009
    • Posts 11
    • Points 110
    Hi there. Can you tell me if there is any way to install XPress Pro on Windows 7. I tried, but I get msg saying OS is not supported.
    Dell Dimension 8400/XP Pro SP3/Pentium 4 CPU/Nvidia Gforce 8400/2.5G RAM/Avid XPress Pro 5.7.2 [view my complete system specs]
  • Sun, Apr 11 2010 2:39 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    I don't know about Xpress Prom sorry.
    BarkinMadd: I have search a bit more in this foum the found it!
    There is a BUG in MC 4.0.5!
    I have installed first MC 4.0.4 and it went throu all the pending installation. Then I upgraded to 4.0.5
    Now everything looks like it is working including my MOJO!
  • Sun, Apr 11 2010 2:58 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,744
    • Points 61,880
    Hi dor,
    That's very interesting - is the bug in 4.0.5 applicable to Vista 64 as well? I wondered why some people were able to install on Windows 7 without any issues.
    Out of interest - how did you update to 4.0.5 - I'm assuming you only  uninstalled Avid applications but left Digidesign and Sentinal (and MOJO drivers) installed - is that true?
    Normally I uninstall everything Avid-related prior to installing updates so I expect this problem would happen again for a 4.0.5 installation with my workflow (in other words, I would have uninstalled Digidesign and Sentinal before installing 4.0.5).
    Cheer
    Steve
  • Sun, Apr 11 2010 3:48 PM In reply to
    • Hugh
    • Joined on Wed, Nov 30 2005
    • Ontario
    • Posts 178
    • Points 2,565
    Just as a matter of interest.
    As a beginner to MC,  I installed a NEW drive as System disk, and then Windows 7 /32 Pro.   (4gb ram)
    MC 4.05 went on without any problems, and appears to be working fine for me.
    Camcorder:- Panasonic GS400 PC:- ASUS P5K Premium 2.4 - Intel core 2 QUAD Q6602 40GHZ 8MB - 4gb ram - EN8800GT 512 Video Card - 3 x 500gb and 1 x 1tb... [view my complete system specs]
  • Sun, Apr 11 2010 5:20 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    I have  64bit version. Maybe this cause it.
    I have installed MC 4.0.4 and then run the 4.05 setup without removing anything
    There were still all the pending softare in the list.
  • Sun, Apr 11 2010 5:42 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,744
    • Points 61,880
    Hugh:
    Others have noted the same success (I believe even when running a 64-bit version of Windows 7) - Maybe it has something to do with where the installer is launched from (in my case, I launch it from by data drive, not from the system drive or from CD/DVD). This variability in experience is one of the reasons Windows 7 is not yet supported by Avid, I'm sure.
    Cheers
    Steve
  • Sun, Apr 11 2010 7:08 PM In reply to
    • Hugh
    • Ontario
    • Posts 178
    • Points 2,565
    My installation was from the boxed version disk via optic drive.
    Not the download version.
  • Sun, Apr 11 2010 8:16 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    As described in other threads right now, Media Composer 5 is fully certified for Windows 7 as has so much other nice options that you not are wanting to look back any longer to older versions as version 4 seems to already have been ...
    Tomas
  • Sun, Apr 11 2010 8:19 PM In reply to
    Here's a look at Media Composer 5.
  • Mon, Apr 12 2010 10:23 AM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    Yes.. I'll wait for MC5.
    After few hours of work on WIN7 and MC4.0.5 I got the "good old" blue screen from windows, somthing I didn't see for years
    I am back to my XP for now
  • Mon, Apr 12 2010 12:26 PM In reply to
    It might help if you tell us what the BSOD says.
    I use W7 Ultimate 64 with 4.0.5. I used it with 3.1.3.13.
    And it run fine there too. With ProTools installed together.
    W7 is the best PC OS ever build and not even on an SP.
    This is why every company made their products compatible with it so fast already.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Mon, Apr 12 2010 2:01 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    I am new to WIN7.. If you can tell me where to find the report file it was generating I'll be happy to share.
    I have this XP system running AVID for long time and had it on my old computer too, since MC 2.5 was out.
    Thou it is not an "official" system, I can't remember ever having a blue screen crash.
  • Mon, Apr 12 2010 2:25 PM In reply to
    No problem. If you left W7 at the initial state you should find the dump at the root of the C (where C is the OS disk), in form of memory.dmp. You can open this by notepad.
    But if you are comfortable with XP go on and use them till things will come to MC5 and the official support from Avid's part.
    Desktop PC
