i !
Please help me choose for the best workflow. My assistant transfers the XDCAM EX3 files from a card to a transport hard drive during a shoot. He then transcode the files with XDCAM EX Clip browser to MXF/AAF.
MY QUESTION:
Is it better to copy the MXF files on AVID hard drive in the MXF folder and drag the AAF files into a bin and Bingo !
OR
Is it better to transfert the files from the XDCAM EX3 file card on the transport disk to Avid hard drive and use them with the AMA import option ?
In both ways, the transfert time to the Avid Drive is the same and I have to make a video mixdown of my sequence to create a Qt ref to put in Sorenson.
Thanks !
You don't need to transcode the files if using AMA: You can link to the XDCAM folder structure on the transport hard drive, still You may want to transcode them inside of Avid to work with Avid mediafiles instead of the AMA "virtual" yellow clips.
peace luca
luca.mg:You may want to transcode them inside of Avid to work with Avid mediafiles instead of the AMA "virtual" yellow clips.
Technically speaking, you should Consolidate them - not Transcode.
Transcoding implies that you would be changing the clips from the native XDCam 35 Mbit codec into an Avid codec (ie, DNx145)
When you Consolidate AMA footage, you simply "re-wrap" the native codec into an Avid MXF file.
Kenton.VanNatten: Technically speaking, you should Consolidate them - not Transcode.
Totally right, as both the consolidate and the transcode commands lead to the same window, and one may want to edit at an offline low resolution to go online at a later stage, I wrote transcode, but technically speaking, if importing the clips to create mediafiles rather than working with the AMA clips, it's a consolidate; and thank You Kenton for clarifying that.
