Latest post Thu, Mar 11 2010 10:01 PM by jdw. 7 replies.
  • Wed, Mar 10 2010 6:50 PM
    • jdw
    • Posts 363
    • Points 4,435
    NitrisDX I/O
    I am having problems getting the documentation form the knowledge base.  Are the HDSDI A/B outputs on the NitrisDX for dual link?  Or, are those multiple outputs/inputs?  I am concerned that the box only has one HDSDI output.  Also, just need to verify that the 2 ref spigots on the back are for loop through.  If I want to send tri-levl and NTSC sync, I have to add a switch or manually swap the cabling.  Thanks, jdw
    MC 2018.9 OS 10.13.6 ISIS 7000 (2018.6.1) [view my complete system specs]
  • Wed, Mar 10 2010 7:59 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    Re: NitrisDX I/O
    The second (B) HDSDI out works but the input does not. The reference is loop through. I have to manually swap cables for Tri-level and NTSC.
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.9, 32GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 24TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Wed, Mar 10 2010 8:05 PM In reply to
    • Philavid1
    • Joined on Thu, May 11 2006
    • Quebec, Canada
    • Posts 99
    • Points 1,065
    Re: NitrisDX I/O
    I don't work with a second ref signal for now, but I always thought that you could choose between the two refs in the video output settings (internal, loop through, Ref1 or Ref2)
    Am I wrong?
    Phil
    4 Symphony Nitris DX 7 on ISIS 5000 shared storage Z820 workstations 12 core with 16GB of RAM [view my complete system specs]
  • Wed, Mar 10 2010 8:54 PM In reply to
    • jdw
    • Posts 363
    • Points 4,435
    Re: NitrisDX I/O
    Thanks Abeyta, just to be certain, when in an HD project, the NitrisDX outputs from HDSDI A and B and SDI simultaneously?
    EDIT--Just got my hands on a NitirsDX.  HDSDI A anad B output simultaneously while in an HD project.  SDI only outputs when the format is SD--and vice versa.
  • Thu, Mar 11 2010 8:32 AM In reply to
    • momoko
    • Joined on Thu, Feb 4 2010
    • Posts 8
    • Points 90
    Re: NitrisDX I/O
    Nitris DX have two generation.
    First generation have single input, loop through.
    Second generation have multiple input ,available Tri-level and BB both.
    You can find detailed information in v4.03 ReadMe ,p68
  • Thu, Mar 11 2010 3:30 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    Re: NitrisDX I/O
    Thanks for clarifying that. I was not aware of 2 different DX boxes. I purchased my DX in June 08 so I have a first Gen.
    Phoenix, Arizona
  • Thu, Mar 11 2010 3:55 PM In reply to
    Re: NitrisDX I/O
    jdw:
    Not exactly sure what you mean, but there is a built in downconvert for HD project. You need to activate it in the Video Output settings.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Thu, Mar 11 2010 10:01 PM In reply to
    • jdw
    • Posts 363
    • Points 4,435
    Re: NitrisDX I/O
    Great news on the gen 2 NitrisDX ref!  I am happy they addressed that issue.  I appreciate everybody's input, jdw
