Latest post Thu, Mar 11 2010 10:01 PM by jdw. 7 replies.
  • Wed, Mar 10 2010 6:50 PM
    • jdw
    • Posts 363
    • Points 4,435
    NitrisDX I/O
    I am having problems getting the documentation form the knowledge base.  Are the HDSDI A/B outputs on the NitrisDX for dual link?  Or, are those multiple outputs/inputs?  I am concerned that the box only has one HDSDI output.  Also, just need to verify that the 2 ref spigots on the back are for loop through.  If I want to send tri-levl and NTSC sync, I have to add a switch or manually swap the cabling.  Thanks, jdw
    MC 2018.9 OS 10.13.6 ISIS 7000 (2018.6.1) [view my complete system specs]
  • Wed, Mar 10 2010 7:59 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 198
    • Points 2,465
    Re: NitrisDX I/O
    The second (B) HDSDI out works but the input does not. The reference is loop through. I have to manually swap cables for Tri-level and NTSC.
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.7, 16GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 12TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Wed, Mar 10 2010 8:05 PM In reply to
    • Philavid1
    • Joined on Thu, May 11 2006
    • Quebec, Canada
    • Posts 99
    • Points 1,065
    Re: NitrisDX I/O
    I don't work with a second ref signal for now, but I always thought that you could choose between the two refs in the video output settings (internal, loop through, Ref1 or Ref2)
    Am I wrong?
    Phil
    4 Symphony Nitris DX 7 on ISIS 5000 shared storage Z820 workstations 12 core with 16GB of RAM [view my complete system specs]
  • Wed, Mar 10 2010 8:54 PM In reply to
    • jdw
    • Posts 363
    • Points 4,435
    Re: NitrisDX I/O
    Thanks Abeyta, just to be certain, when in an HD project, the NitrisDX outputs from HDSDI A and B and SDI simultaneously?
    EDIT--Just got my hands on a NitirsDX.  HDSDI A anad B output simultaneously while in an HD project.  SDI only outputs when the format is SD--and vice versa.
  • Thu, Mar 11 2010 8:32 AM In reply to
    • momoko
    • Joined on Thu, Feb 4 2010
    • Posts 8
    • Points 90
    Re: NitrisDX I/O
    Nitris DX have two generation.
    First generation have single input, loop through.
    Second generation have multiple input ,available Tri-level and BB both.
    You can find detailed information in v4.03 ReadMe ,p68
  • Thu, Mar 11 2010 3:30 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 198
    • Points 2,465
    Re: NitrisDX I/O
    Thanks for clarifying that. I was not aware of 2 different DX boxes. I purchased my DX in June 08 so I have a first Gen.
    Phoenix, Arizona
  • Thu, Mar 11 2010 3:55 PM In reply to
    Re: NitrisDX I/O
    jdw:
    Not exactly sure what you mean, but there is a built in downconvert for HD project. You need to activate it in the Video Output settings.
  • Thu, Mar 11 2010 10:01 PM In reply to
    • jdw
    • Posts 363
    • Points 4,435
    Re: NitrisDX I/O
    Great news on the gen 2 NitrisDX ref!  I am happy they addressed that issue.  I appreciate everybody's input, jdw
