Latest post Mon, Mar 8 2010 12:41 PM by Mike Shaw. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Mar 8 2010 10:45 AM
    Assistance with liquid (moved)
    I have used Liquid 7 for a number of years - quite successfully and really like the application and it's features.
    Recently I had to replace my computer and get a new system.  I had XP installed and when I loaded Liquid, everything seemed to work OK.
    The program is working well.  Just like before but there is now a problem with exporting to a AVI format or burning to a disk.  Where a transition has been used or the 2d editor has been used to "enhance" some footage (be it movie or still), the effect on the AVI format is not good.
    The result is that where the 2d editor was used, a strobing effect is achieved in the AVI file for an imported photo when the file is zooming,  a photograph imported into Liquid.  Where a transition is used, a green washout of the screen is seen in the AVI format.  Where a blue screen keying is used, a green washout of the screen is seen.  If all 2d editors, keying etc are removed, the program works well in burning to a disk.  In other words, where a 2d, 3d, keying, or transition is NOT used, everything works well.
    I have replaced the program and replaced XP and this does not help.
    I am on tight timeframes to have a project completed and would appreciate any guidance you could give in relation to how I fix this issue.  The playback on the screen is perfect.  The issue is when you export the sequence to an AVI format or burn to a DVD where it all goes "pear shaped".
    I am really hoping you can help with some suggestions.
  • Mon, Mar 8 2010 11:10 AM In reply to
    Re: Assistance with liquid
    You're in the wrong place.  You can find the Liquid forum here:
    http://forums.pinnaclesys.com/forums/default.aspx
    good luck,
    Carl
  • Mon, Mar 8 2010 12:15 PM In reply to
    • Mike Shaw
    • Kent, United Kingdom
    • Posts 1,424
    • Points 19,730
    ... and they'll most likely tell you its a graphic card/driver problem.  First place i'd look ...
    MC6.0.3.2 Gigabyte GA-X58A-UD3R Rev2 MB, Intel i7-950 3.06Ghz, 12GB DDR3 1333Mhz RAM, 1x500GB, 3x1TB HDrives, 2+1TB Network drives, nVidia Quadro FX1800... [view my complete system specs]
  • Mon, Mar 8 2010 12:27 PM In reply to
    This is a friendly reminder that a) this forum is called Chat with Avid, and it is for posting questions for Avid's management, and b) there are forums for Liquid users to post their Liquid questions, and those forums are here:
    I know you're trying to help, Mike, but I don't want to fill the Chat with Avid forum with off-topic posts that belong someplace else.
    thanks,
    Carl
  • Mon, Mar 8 2010 12:39 PM In reply to
    • Posts 11,267
    • Points 231,935
    Thank you for posting the link for questions about Liquid, Carl.
    Now, once again, I would like to ask everyone who has questions about the running and use of Media Composer on a PC to begin posting on the correct Forum - the Avid Media Composer - PC Forum.
    http://community.avid.com/forums/49.aspx
    Please stop posting technical and operating questions on this Forum.
    I thank you all in advance for your co-operation and understanding.
    REgards,
    Douglas
  • Mon, Mar 8 2010 12:41 PM In reply to
    • Mike Shaw
    • Posts 1,424
    • Points 19,730
    Totally understood... (Carl - and Douglas)
    My apologies. Embarrassed
