Latest post Tue, May 31 2011 12:40 AM by lunalobo75. 4 replies.
  • Sun, Mar 7 2010 5:50 PM
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,250
    CANON 24f Pulldown Progressive Workflow that works for me
    Hey everyone,
    I don't if anyone has posted a way to get progressive frames out of Canon's 24f, but here is my workflow:
    I worked with a a Canon Vixia HV30 over the weekend, and I followed these steps (beginning has been posted before)
    - Created a New Project with 1080i/59.94 settings
    -set raster size to 1440 x 1080
    - Camera Capture settings to XGH1
    -  set capture format to HDV 1080p MXF
    - Captured away
    Second Step:
    - created another project
    - set it to 1080 23.97
    - 1440 x1080
    - copied the bin from my 1080I project to my 23.97 project
    - went back to my 23.97 project
    - dropped a clip on the timeline (motion effect already applied by avid)
    - promoted the motion effect
    - change "Type" to interpolated fields
    - change "source" to Film with 2:3 pulldown
    - choose "detect" under 2:3 pulldown
    - and you now have full progressive frames with the intermittent interlace frame.
    I just find it easier to worj with effect and photos, and not having to guess the fields, when everything is all 1 frame. I know there is more rendering involved with the the motion effect, but at least it's in realtime initially.
    Salud!
    HP Z800 MC 8.3, Adobe CC, Windows 7 Ultimate 64-bit SP1, 2 Hex Core X5650 @ 2.67GHz, 48Gigs Ram, NVidia Quadro K4000, Sandisk Extreme 240 gig SSD System... [view my complete system specs]
    Filed under: , , ,
  • Mon, Mar 8 2010 4:21 PM In reply to
    • bwilhelm
    • Joined on Thu, Mar 19 2009
    • Avid (Burlington, MA)
    • Posts 159
    • Points 2,060
    Re: CANON 24f Pulldown Progressive Workflow that works for me
    If your 59.94i clips contain 2:3 pulldown that you want to remove in 23.976p,
    try modifying their Field Motion column in the bin to "2:3 Film" before editing.
    The default motion adapters will be automatically set to "Film with 2:3 pulldown"
    and the cadence will be automatically detected,
    so you won't have to promote the effects and change them manually.
    If you edited the clips into a sequence before you changed Field Motion,
    you can update the sequence using "Refresh Motion Adapters".
  • Mon, Mar 8 2010 4:54 PM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,250
    Much easier - thank you!!!
  • Tue, May 31 2011 12:22 AM In reply to
    lunalobo75:
    - Captured away
    I only have HDV 1080i MXF listed in the dig tool. I realize this OP is a year old. I thought someone might be able to tell me how I'd enable "HDV 1080p MXF" in a 1080i project?
    Filed under: , ,
  • Tue, May 31 2011 12:40 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,250
    I just sent you an email. I hope it helps...I use a Gh1 and GH2 (AVCHD) via the neoscne method now.
    Salud!
