Latest post Tue, Feb 16 2010 3:19 PM by maryd. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Feb 3 2010 10:17 PM
    • ph.dess
    • Joined on Wed, Dec 9 2009
    • Paris
    • Posts 11
    • Points 150
    XML stream to dekocast
    Hello,
    How can i use a XML stream (with election result) in crawl generate by dekocast or dekoobjex ?
    Phil.
  • Fri, Feb 5 2010 7:39 PM In reply to
    • maryd
    • Joined on Wed, Aug 23 2006
    • Posts 12
    • Points 1,895
    • Moderator: Avid Motion Graphics
    Re: XML stream to dekocast
    DekoCast v.3.6 and earlier uses .txt data, DekoCast v4 and higher can use .txt, ODBC databases, RSS data or iNews data.
    I believe you would need to translate the XML data to one of these sources, then use that in your crawl.
  • Tue, Feb 9 2010 9:40 AM In reply to
    • ph.dess
    • Paris
    • Posts 11
    • Points 150
    Thanks, for your answer.
    How can i do it ? Specific software or option ?
  • Thu, Feb 11 2010 6:49 PM In reply to
    • maryd
    • Posts 12
    • Points 1,895
    DekoCast version 4.x has plug ins that can be used.  If you are not upgraded to that version you can download it from the Avid site:
    http://esd.avid.com/Login.aspx?ReturnUrl=%2fDefault.aspx
    When you install version 4.x you must also install the plug ins (RSS extractor, Database extractor, iNews extractor, Engine Trigger and Image Fetcher).
    You must have a current support contract.  If you do not have a support contract you need to contact your sales representative.
    With DekoCast 3.6 and earlier you can use a Deko object and a .txt file as the Content.
    Either way, you need to somehow translate the xml data to either a text file or a database format that DekoCast can utilize.
  • Tue, Feb 16 2010 1:51 PM In reply to
    • ph.dess
    • Paris
    • Posts 11
    • Points 150
    Hello,
    We use dekocast version 4.2.1, but i can't find this plug ins in the soft or in the CDs. In the dekocast application when i click on plug in button an empty window appears.
    So where i can found the RSS plugin ?
  • Tue, Feb 16 2010 3:19 PM In reply to
    • maryd
    • Posts 12
    • Points 1,895
    Log in to customer support:
    Click Product Search on the right, and search DekoCast.  Click on the top offering Avid DekoCast HD/SD 4.2.1
    You will see the download for the DekoCast Plug Ins at the top of the list.  Each plug in has it's own installer.
