Latest post Fri, Apr 9 2010 1:59 PM by George Angeludis. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Jan 21 2010 3:03 PM
    • gpfan
    • Joined on Thu, Jan 21 2010
    • Posts 4
    • Points 60
    Avid Media Composer (PC) software hangs on exit
    MC Version - 4.0.4
    OS - XP Professional 32 bit
    Memory - 4GB
    CPU - Intel Core i7 940
    Video Card - ATI Radeon HD 4870
    Hi All,
    This is my first post on this board, so please excuse me if I overlook any information that should be posted here. I've been working with Avid Media Composer for a month or so now, for training purposes. Everything seems to work fine with the exception that the program hangs upon exit.
    By "hang" i mean that, I select file>exit and all windows and bins close with the exception of the main program window. The Windows hourglass shows up, and that's basically it. Unless I go into Windows Task Manager, I cannot exit the program. Once I open Windows Task Manager there are two instances of Avid Media Composer listed, both are "not responding". Once I select "end task" for one, both close. This happens even if I open Media Composer, decide not to open/start a project and then try to exit.
    I have tried uninstalling version 4.0.3. and reinstalling version 4.0.4 - the problem existed in both. I've also tried uninstalling and re-installing by video cards drivers.
    Any help, suggestions, work arounds or ideas would be most appreciated.
    Thank you,
    Dan
    Filed under: , , , , ,
  • Thu, Jan 21 2010 3:38 PM In reply to
    • Posts 11,203
    • Points 231,085
    Re: Avid Media Composer (PC) software hangs on exit
    gpfan,
    First, the ATI card isnt a supported graphics card.  This means that Avid didnt test it so we have no idea how it will perform of affect the system.
    Also you didnt mention what version of QT you are running.  You should be on 7.6.2 with MC 4.0.2 nd 7.6.4 with 4.0.3 or 4.0.4.
    How much memory do you have allocated?   How many bins are open and are you in SD or HD?
    Somethign to try.... if this is a lack of memory issue.
    Windows XP limits every program to 2 gigabytes (GB) of address space. It reserves the remaining 2 gigabytes for its own use. Avid provides a utility for setting the boot-time mechanism to extend the process address space.
    Setting the Avid editing system to access a larger virtual address space might improve working with HD projects without running out of memory or prevent performance issues. Even though you might gain more memory space, this can be quickly consumed with bins and complex HD effects.
    Anyone else have any idea's?
  • Thu, Jan 21 2010 3:40 PM In reply to
    • CreativeControl
    • Joined on Mon, Dec 10 2007
    • Edmonton, Alberta, Canada
    • Posts 410
    • Points 5,190
    I had that problem and it was the graphics card setting.  Mine is an Nvidia though so I'm not sure if there is a similar setting.  I had to turn off "Thread Optimization".  I'd check for something similar in the ATI settings.
    2 MC4.0.5 systems, both self built Intel Quad Core PC's. Asus P5n32-e motherboards. One with NV GTX 470 - 275.33 drivers and one with NV 7800GT card... [view my complete system specs]
    Editor/Shooter/Animator - www.creativecontrol.ca
    WWII Aviation Artist - www.actionart.ca
  • Thu, Jan 21 2010 3:51 PM In reply to
    • Posts 11,203
    • Points 231,085
    Good idea creative....
    I forgot about that one.....
    If that is in fact it... report back.  I will have a tech note created for the Knowledge Base so this is somethign easiy found.
    Report back either way though.
    marianna
  • Thu, Jan 21 2010 3:59 PM In reply to
    • gpfan
    • Posts 4
    • Points 60
    Thanks Marianna and Creative. I'll try your suggestions and report back. I appreciate the help.
  • Thu, Jan 21 2010 6:07 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,669
    • Points 66,515
    How many monitors are You using? Do You run in Full Screen Playback mode?
    Symphony 20.04, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Thu, Jan 21 2010 7:56 PM In reply to
    • gpfan
    • Posts 4
    • Points 60
    Hi All,
    I'm still having the problem, but I'd like to answer some of the questions you asked and let you know what I've tried.
    I'm working in SD, I'm only using one small bin and actually just playing around with small files for training purposes. I've upgraded to QT 7.6.5, though I was using 7.6.2. prior to Marianna's first message. I'm only using my computer monitor at the moment and not running full screen mode. As far as memory allocation goes, I've included a jpeg below.
    As far as what I've tried... I've upgraded to QT 7.6.5. and used the Avid Utility to set the boot-time mechanism to extend the process address space. So far, I don't think ATI has a setting that is the same as NVidia's "Thread Optimization" - but I'm continuing to check into that and I'm hoping to turn something up there.
    Thanks again for all the help. If I find it's a setting with the graphics card, I'll post the info here.
    Dan
  • Thu, Jan 21 2010 8:33 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,669
    • Points 66,515
    gpfan, I see that You have just  joined the forum, welcome aboard, You couldn't have had a better start than being taken care of by Marianna anyway. The easy answer to Your problem is that the video card is at fault, that being said I would try a forum search for Ati or Radeon, someone may have already posted relevant tips. Googling for Avid and Ati may be useful too. The easiest answer would be a buy a Quadro card, but don't give up before having tried everything You could possibly think of, like installing a different release of the Ati drivers for example.
    peace luca
  • Thu, Jan 21 2010 11:59 PM In reply to
    • gpfan
    • Posts 4
    • Points 60
    Thanks Marianna, Luca and Creative.
  • Fri, Jan 22 2010 12:07 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,669
    • Points 66,515
    My pleasure, and keep us all informed.
    peace luca
  • Fri, Apr 9 2010 1:38 PM In reply to
    • Jpere
    • Joined on Mon, Dec 5 2005
    • Posts 4
    • Points 60
    CreativeControl:
    Having similar memory issues, and would like to turn off "THREAD OPTIMIZATION", been searching all over for how to do this on a mac? Can't find an answer. How did you do it?
    I'm using a NVIDIA GeForce GT 120
    Thanks for your help, right now I'm not getting any work done, just clicking error boxes.
    JP
    My Specs:
     Model Name: Mac Pro
      Model Identifier: MacPro4,1
      Processor Name: Quad-Core Intel Xeon
      Processor Speed: 2.66 GHz
      Number Of Processors: 1
      Total Number Of Cores: 4
      L2 Cache (per core): 256 KB
      L3 Cache: 8 MB
      Memory: 6 GB
      Processor Interconnect Speed: 4.8 GT/s
    Chipset Model: NVIDIA GeForce GT 120
      Type: GPU
      Bus: PCIe
      Slot: Slot-1
      PCIe Lane Width: x16
      VRAM (Total): 512 MB
      Vendor: NVIDIA (0x10de)
      Device ID: 0x0640
      Revision ID: 0x00a1
      ROM Revision: 3386
      Displays:
    DELL 2005FPW:
      Resolution: 1680 x 1050 @ 60 Hz
      Pixel Depth: 32-Bit Color (ARGB8888)
      Mirror: Off
      Online: Yes
      Rotation: Supported
    DELL 2405FPW:
      Resolution: 1920 x 1200 @ 60 Hz
      Main Display: Yes
      Mirror: Off
      Online: Yes
      Rotation: Supported
    Avid Xpress Pro 4.8 OS 10.4.2 Dual 1Ghrz G4 1.25 GB memory [view my complete system specs]
  • Fri, Apr 9 2010 1:59 PM In reply to
    You have to go to the 3D Settings of the Nvidia Panel.
    This can be done on a PC by right clicking on the desktop and choose Nvidia Panel.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
