Latest post Tue, Jan 8 2019 11:36 AM by Zdenek Klusacek. 14 replies.
Page 1 of 1 (15 items)
  • Wed, Jan 20 2010 3:29 PM
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,795
    Command 8
    Does the Command 8 control surface work with current Media Composer software? No mention on the Digi site that I could find.
    (Mac OS 10.6+, MC 4.x)
    - Oliver
  • Wed, Jan 20 2010 3:34 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: Command 8
    I had this conversation with the folks at Digi for a friend over at Criminal Minds and was told that yes, the Command 8 is qualified for use as a control Surface for the Mac version of MC.
  • Wed, Jan 20 2010 9:32 PM In reply to
    • TrevorA
    • Posts 1,256
    • Points 14,185
    Re: Command 8
    But you really need the Command 16 with v4 ;-)
    iMac 5K on High Sierra MC 2020.5, HP z420 MC 2020.4 [view my complete system specs]
  • Thu, Jan 21 2010 3:32 AM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,795
    Re: Command 8
    Thanks for the feedback.
    - Oliver
  • Fri, Jan 22 2010 10:33 AM In reply to
    • St.John
    • UK
    • Posts 269
    • Points 3,335
    Re: Command 8
    Working with 4.0.5, but you do need to select command8 from the controller settings, before it will work
    St.John
    Mac Pro trashcan 3.5ghz 6 core 32 gb Ram Media composer 10.19.12 AJA io4k [view my complete system specs]
  • Wed, Apr 6 2011 7:06 PM In reply to
    Re: Command 8
    BLKDOG:
    any more information on this? I'd like to hook up the one I have under plastic.
    SMA
    Mac 15 inch PowerBook with 2nd monitor, OS 10.6.2 on a 2.33 CPU, 4 gigs of Ram [view my complete system specs]
  • Wed, Apr 6 2011 8:02 PM In reply to
    • Phil.IP
    • Joined on Thu, Nov 25 2010
    • Cologne, Germany
    • Posts 16
    • Points 225
    Re: Command 8
    C8 works, got one at one, my Specs Z400 6core win7 MC5.0.3.8
    Post Production Supervisor / System Support Engineer
  • Wed, Apr 6 2011 8:12 PM In reply to
    Re: Command 8
    AH yes. But you see you are working on a Windows box. I am on my mac.
    Not sure why it would work on one platform and not the other.
    Did you have to install any additional software?
    SMA
  • Wed, Apr 6 2011 8:50 PM In reply to
    • Phil.IP
    • Cologne, Germany
    • Posts 16
    • Points 225
    Re: Command 8
    Yes, there is a driver in the Utilities Folder, should work on Mac but i can try it on my Mac machine at home
  • Sun, Oct 30 2011 8:47 PM In reply to
    Re: Command 8
    OK the Command 8 works well with MC 5.5, but I am still looking for a manual that will help me use it more effectively. For example. I have 8 tracks working OK, I'd like to hit a button or a console command and have the command 8 modify the second 8 tracks (9-16)
    Does anyone know if there is some avid or diigi documentation? The pdf download on the digi site seems quite limited.
    thanks for all your help. Eventually I would like to bet both my MC6 and Protools to talk to it
    SMA
  • Mon, Oct 31 2011 10:33 AM In reply to
    • mark.burton
    • London, UK
    • Posts 924
    • Points 11,265
    Re: Command 8
    In order to control 16 tracks with any of the 8 track faders available, including the Command|8, you need to have the Audio Mixer Window displaying only 8 tracks, then hit the 'Grp 1' or 'Grp 2' button on the Audio Mixer to switch to showing the other 8 tracks and the midi control will switch to controling the other 8 tracks (credit goes to R.Salsbury for that tip!).
  • Mon, Oct 31 2011 11:00 AM In reply to
    Re: Command 8
    I had the command 8 working fine with my MC 5.0.3 on OS 10.5.6
    But since I switched to Lion and MC 5.5. my Command8 is not able to control the faders anymore. I can use the control unit (play buttton etc.) and the display says "avid mode enabled" but the faders stay down...
    Anyone with a hint what I forgot to re-install after upgrading?
    David
    Avid Mediacomposer 5.5.3. with MacOS 10.7 on a MacPro 2x2.66GHz QuadCore Intel Xeon 12Gb RAM with Matrox Mini [view my complete system specs]
  • Mon, Oct 31 2011 1:03 PM In reply to
    • mark.burton
    • London, UK
    • Posts 924
    • Points 11,265
    Re: Command 8
    Have you selected the Command|8 in both the "Port:" and "Gain Controller Port:" options in the Controller Settings?
  • Mon, Oct 31 2011 1:41 PM In reply to
    Re: Command 8
    THANKS!!!
    I just set the controller to command8 but not the gain controller...
    Greetings from Berlin.
    David
  • Tue, Jan 8 2019 11:36 AM In reply to
    Re: Command 8
    I suspect this does not work anymore as in new version of MC (2018.11) you do not have to possbility to limit number of track on your audio mixer?
