Latest post Mon, Feb 6 2012 3:42 PM by SpaceCityTom. 7 replies.
  • Wed, Jan 6 2010 9:53 PM
    Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
    Just got to testiing new Z400 system and about 20 sec after capture window  is made active I get this error message:
    I have QT 7.6.4, the correct Nvidia drivers, everything in the suggested slots. Just can't figure it out.
    Anybody have any ideas?
    Thanks.
    System 1: HP Z400, 3.20G Quad Core, Quadro 4000, 250G SSD system drive,Windows 7 64, MojoDX w/active hib, 6G ram, Cal Digit VR ESATA Raid, Recommended... [view my complete system specs]
  • Wed, Jan 6 2010 10:31 PM In reply to
    Re: Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
    Well, in my own rush to test, I hadn't connected any source to the DX. Once a valid HDSDI source was connected, the error message went away. Never did that in earlier versions of MC with the DX, you would just get a NO Signal message. Anyway I hope I'm right and it continues to work well.
  • Thu, Jan 21 2010 5:25 PM In reply to
    Ok, This is aggrivating. Everytime the camera is disconnected from my system with capture enabled, I get the StreamingPlay exception. Is there any way around this other than closing the capture window between scene changes? Anybody out there using a Mojo DX have the same happen when they disconnect the video source with the capture window active? Just checking to see if this is now the default behavior with 4.05.
  • Thu, May 13 2010 9:15 PM In reply to
    • Stephan
    • Joined on Thu, May 13 2010
    • Washington DC
    • Posts 4
    • Points 50
    Hi Clement,
    I get the same error mesasge when I try to capture audio (narration) via analog audio in. I didn't have that problem when I captured video and audio via SDI. And the wired thing about it is when I push the record button right after I set up the capture tool the message doesn't appier only if i wait a few secounds the error will pop up. i actualy had yesterday the problem that the MC sent me always an "no valid input on analog audio" error when I tried to record some voice over. Today I tried again and got the other error but at least I know that the analog audio input works...
    If you figured some solution for that problem - I see you had it a while ago - would be great if you can post it.
    Stephan
    Mac Pro, Snow Leopard 10.6.2, Quad-Core Intel Xenon, 2.93 Ghx, 6GB Ram, NVIDA GeForce GT 120, Avid MC with Mojo DX, QT 7.6.3 [view my complete system specs]
  • Wed, May 19 2010 7:08 AM In reply to
    No solution, just learned to live with it. Now I know that when I see that error I lost sync or the signal entirely. Didn't try with capture set to SDI audio though, always capture with analog audio source. Don't know if it makes a diference. Sorry I couldn't be of any real help. It seems MC4 is a bit more picky about capture than 3.X was.
  • Thu, Jun 24 2010 4:54 PM In reply to
    • Editmvp
    • Joined on Wed, Sep 3 2008
    • Billings, Montana
    • Posts 158
    • Points 1,855
    I too am experiencing exactly the same issue recording narration.  In my setup, I have an APHEX preamp with a optical S/PDIF line running to the Nitris box.  But I tested the problem running an analog line and an AES/EBU line as well with exactly the same results. I never had the problem before until I recently updated to MC5/Win 7.  It must be either a bug, or something in our setups.  It's definitely annoying and needs to be resolved.
    Primary System: Media Composer 2018.12.8 w/Symphony Option | Phrase Find | Avid Artist DNxIO | iMac 2019 i9 8-Core 3.6/128GB/2TB-SSD/Radeon Vega 48/OS... [view my complete system specs]
  • Thu, Oct 7 2010 11:29 PM In reply to
    • JasonByfield
    • Joined on Tue, Oct 13 2009
    • Kirkland, WA
    • Posts 11
    • Points 140
    Gotta love the mysterous MC error messages...
    I too have been experiencing these issues lately.  The only way that I can capture analog audio in MC 5 on a PC is by having a live video signal feeding into my Mojo DX via HD-SDI.  This is of course quite annoying if I'm only looking to capture VO and don't need video.  Hopefully we'll see a fix for this soon.
    OS X Snow Leopard (10.6.8), Mojo DX w/ Media Composer 6.0 fibre channel to Unity MediaNetwork 5.1.3, QuickTime 7.6.6, Mid 2010 MacPro:2 x 2.93 GHz 6-Core... [view my complete system specs]
  • Mon, Feb 6 2012 3:42 PM In reply to
    Not sure if anyone is still having this problem but I got round it by unticking "View incoming video on client monitor" in the capture settings.
