Latest post Thu, Dec 24 2009 2:45 PM by meketrefe666. 2 replies.
  • Wed, Dec 23 2009 5:46 PM
    Avid Media Composer & Snow Leopard slow startup & non recognised magic mouse
    Hi everybody! Recently I installed on my new macbook pro the last version of Avid Media Composer. I experimented several problems on startup. This process is during about 70 seconds and when the machine is totally ok for working, the operating system not recognised the magic mouse. This isn´t normal because before i´ve installed the software, the machine switches off in 4 seconds. Now in 20 seconds more or less. I must switch on the mouse manually and isn´t normal the machine seems sleeping booting. I don´t urdestand what happens. I´m looking for a solution but I don´t find nothing. Have you got any idea for this question?
    thank you so much
  • Wed, Dec 23 2009 7:52 PM In reply to
    • Posts 10,682
    • Points 224,120
    Re: Avid Media Composer & Snow Leopard slow startup & non recognised magic mouse
    666...
    First I know some of he mighty mouse issues were resolved in 10.6.2 ( snow leopard).  Make sure that is what you have.
    Secndly... if you uninstall MC does the behavior still continue?
    Lastly, you ou might try making the mouse a favorite:   System preferences>bluetooth. Highlight the mouse and click on the little gear. Select "show more info." Then make it a favorite.
    If that does not help, try trashing a preference file and restarting (com.apple.bluetooth.plist).
    marianna
  • Thu, Dec 24 2009 2:45 PM In reply to
    Thank you for your response. Yes, I´ve got snow leopard 10.6.2, and is uptaded. I tried what you said and it has worked. Also I have restarted the computer several times and it seems that the mouse is recognized from the beginning. What if that does not solve is the time it takes to boot and shutdown that stays the same. I uninstalled the avid and returns to work fine but when I install it gives me that problem and I don´t know what really happens
    thanks
