Latest post Thu, Nov 19 2009 1:13 PM by mjolnarn. 3 replies.
  • Thu, Nov 19 2009 3:46 AM
    Can't capture from any 1394 source after 3.5 to 4.0.3 upgrade
    Had MC 3.5 Academic, was working relatively well, a few issues with capturing from a JVC camera.
    Recently finished the upgrade to 4.0.3 (thanks to Marianna my new hero).  But alas--now I cannot capture from ANY camera or deck.  It is as if the upgrade made my 1394 ports invisible to Avid and other software.  Capture tool simply says NO DECK.  No biggie normally, I'd go into deck configuration, etc.  It "sees" the OHCI channel there, but after "apply" no luck.  I tried new cables, old cables, front and rear ports, and two other DV cameras that worked fine before the upgrade.
    For what it is worth, not even windows Movie Maker or other consumer editing programs see the cameras either.  Of course under device manager windows says the 1394 ports are working fine.  Ha!
    I no longer even get the semi satisfying Windows "hey I see ya plugged somethin' in there" chime when I plug in the cameras via firewire and turn them on in VCR mode.
    Maybe linear editing wasn't so bad after all.  :)
    Could the MC 4.0.3 upgrade have affected the firewire connections that adversely?  'Bout ready to retreat to 3.5.  Anyone else have similar experiences?
    Gateway LX6810-01, Intel Core 2 quad CPU Q8200 @ 2.33 GHz, 8GB memory, Windows 7 Professional 64 bit, 750GB & 1TB media, NVIDIA GeForce GT 120 [view my complete system specs]
    Douglas Flanagan
    Instructor of Radio-Television Broadcasting
    Herkimer County Community College
    Herkimer, NY  13350
    flanagadp@herkimer.edu
    www.herkimer.edu
  • Thu, Nov 19 2009 6:40 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: Can't capture from any 1394 source after 3.5 to 4.0.3 upgrade
    Douglas Flanagan:
    Gateway doesn´t tell in their specs what type of firewire chips they are using, my guess would be that it is Via and that might be your problem, you are also using an uncorrect OS.
    I would start with buying an fw card with a TI chipset to see if that works better.
    edited ...  sorry, you have multiple posts about this, ignore my answer
    Tomas
  • Thu, Nov 19 2009 1:04 PM In reply to
    Yup, knew it was risky on the Gateway but since the trial MC ran fine, I thought I'd give it a try.  Relatively new PC, might run the issue past GW themselves, seeing as it did work fine before.
    "multiple posts"?
    Douglas Flanagan
    Herkimer, NY  13350
    www.herkimer.edu
  • Thu, Nov 19 2009 1:13 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Douglas Flanagan:
    "multiple posts"?
    Yes, will give you multiple answers
    Anyhow, I would start with trying a TI card, a cheap and fast solution if it works
    Tomas
